Old March 31st, 2012, 06:57   #12601
Nighteyes
Picked up my first TDI on Thursday from the dealer. And dropped it off Friday for some window tint. Strange thing, I actually look forward to getting behind the wheel again.
Nighteyes is offline   Reply With Quote
Old March 31st, 2012, 08:58   #12602
Zedbra
Zedbra's Avatar
^ congrats on the TDI. And, that draw can be strong - after 7 years and 170k, I still look forward to getting into my TDI and driving.
yesterday i washed off two weeks of road salt
2005 Jetta TDI GLS: VNT17VB, 3 Bar, Malone Stage 4, BiXenon retros, OEM Fogs, ST Coilovers, OZs
Zedbra is offline   Reply With Quote
Old March 31st, 2012, 09:11   #12603
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
Welcome to the Darkside .......
Voter Responsibility Act: Everyone's vote for President should be recorded. If who they elect runs a deficit, those that voted for them should be solely responsible to pay off that debt from their income and vice versa on any surplus. If you fail to vote, you are defaulted to the victor.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old March 31st, 2012, 09:35   #12604
jrarno02
TDI(s): '02 Golf GLS
Fuel Economy: Low 47-Avg 50-Max 57
Originally Posted by OnePutt View Post
I have no idea how people get this kind of fuel economy...I'd like to see my trip flip 8xx on a tank. Most I've ever seen is 730or so...and calculating fuel economy was 47 mpg or something like that. That was driving down i5 from SF to LA....totally flat lands. Maybe I need a scan gauge.
I just filled up for my second 800+ tank in a row, with about 60/40 Hwy/Cty, and I know my engine is so far out of wack in terms of tuning lol... I go like 58mph everywhere, maybe 60
jrarno02 is offline   Reply With Quote
Old March 31st, 2012, 11:28   #12605
TDI_Votex
TDI_Votex's Avatar
Fuel Economy: 4.2/6.5/9.0 L/100km
Re-installed my a-pillar boost gauge pod on 03 Bora. Didn't like my first install.
80 Rabbit(80-94)
89 Jetta Flair 1.6TD(89-03)
03 Bora Votex TDI GLS(03-??)
96 Golf GL 1.9TD(04-08) RIP Hail Storm
99 NB TDI(06-??)
00 Golf TDI(08-??)
06 NB TDI(08-??)
Volks for life!!!
TDI_Votex is offline   Reply With Quote
Old March 31st, 2012, 14:52   #12606
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Went from this
To this
It's a lot shorter than the OEM one (duh!) and a little tight particularly on the 1-2 and R side. Even with that it's nicer than the stock one by far. It'll break in and loosen up.
My 5 speed one I had for 150k miles and loved it - I was tired of the OEM 6 speed one before 1500 miles
Great product from Diesel Geek!
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP110 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, VNT 17/22, 3 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/50/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ASV Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, Gauges
Fix_Until_Broke is offline   Reply With Quote
Old March 31st, 2012, 15:01   #12607
Whitbread
Whitbread's Avatar
Fuel Economy: mid 40's with mixed spirited driving
I hope you didn't get tired of shifting into 6th before 1500 miles though .
Had a chance to tow with the 6spd yet?
02 Jetta TDI. Part 2
Whitbread Performance Innovations
-Full TDI performance and custom fabrication services. 248-755-8118. Dealer for SBC, TD Tuning, Wavetrac, Peloquin, Venair, and Vibrant.
Whitbread is offline   Reply With Quote
Old March 31st, 2012, 15:21   #12608
Fix_Until_Broke
No - I'm not tired of the right and down shift
I towed my 4x8 trailer with a 4' x 10' x 0.065" sheet of stainless on it 250 miles last weekend and it worked very well. About as light and aerodynamic as it gets so not a big workout. It would pull it in 6th at 60 MPH (1650 RPM), but was not happy with moderate hills so I kept it in 5th (~1975 RPM). Once I got on the 4 lane I could run it in 6th at 70 MPH (~1925 RPM) and it was fine. I got better mileage on that tank (47 MPG) than I did on my break in tank (45 MPG).
Old March 31st, 2012, 15:35   #12609
golftdi140
Fuel Economy: 11 tdi 43. 93 camry 24. 97 cbr600 45-55
Went from this
To this
I did this last year in my 2011 golf and have lovedbit ever since. I did experience an issue with 1 & 2 so I compensated the adjustment slightly from just setting home position and tightening. Wish it was a tad cheaper though. But yes highly recommended.
Sent from my DROID4 using Tapatalk
golftdi140 is offline   Reply With Quote
Old March 31st, 2012, 16:10   #12610
Fix_Until_Broke
The adjustment is fine, it's just stiff to push into gear and stiff to pull out of gear wheras 3rd and 4th kind of fall in and fall out - you can feel the springs on the synchro clips as you push past them and it falls into gear. You have to pull it all the way out of 1st and it will almost stay wherever you let go of it on the left side of the pattern - I'm not sure it's the shifter, but it didn't do it with the OEM one.
$200 is a bit high, but it's a high quality piece - the plastic bearing is much improved over the OEM one, all billet aluminum pieces, stainless hardware, spherical bearings on the pivots - this thing will outlast the car. I'm guessing there is not much middle ground from a design/price standpoint. Once you go custom, you go all the way like the DG unit. I'd rather pay $200 for this than $100-$150 for a modified OEM one or one that only shortens side to side.
Old March 31st, 2012, 16:43   #12611
golftdi140
I agree it is very high quality. I did not hesitate to buy lol. My issue with adjustment was when I went left it would hit the lock for R in the car before the tranny actually got the 1-2 position. I stalled a few times only to realize I was in third. I wonder if that's your problem too. Try taking the side to side cable and pull a couple threads of slack out of it and retighten. That way when u go left it will push the selector farther down before hitting the lock in the car. I believe that's correct its been awhile since I looked at it. Another test is to put in third and measure left right play then put in 1st and see if its really tight left to right. Hope it helps !
Old March 31st, 2012, 18:05   #12612
SoKYTDi
SoKYTDi's Avatar
Fuel Economy: See my signature!
Cool
Originally Posted by jrarno02 View Post
I just filled up for my second 800+ tank in a row, with about 60/40 Hwy/Cty... I go like 58mph everywhere, maybe 60
And THAT's why I'll never turn those kinds of numbers. I like to get where I'm going in a reasonable amount of time.
Just a Geek, trying to make his way in this world.
2003 Golf GL TDi -- Lots o' mods and a whole list of dreams.....
SoKYTDi is offline   Reply With Quote
Old March 31st, 2012, 19:43   #12613
SD26
SD26's Avatar
Fuel Economy: Almost 51MPG
Well, lots of little things... Went and changed to MTL in the trans, playing with thermostats...
Took a trip, and I thought that the engine note sounded a little loud. Looks like the cat has came off the exhaust at the rear of the cat. I'm a thousand miles from home... What's the short answer for a fix, and what's a proper fix for longevity? Is it ultimately an issue with the stainless material used for OEM that eventually rots vs what ID Parts has as a replacement downpipe, then a cat... Looking at MPG as my ultimate goal, is there any reason to go over the stock 2"? Didn't come up with much on the search side...
Dave
1998 Jetta TDI "Jerry" - 5sp,ventectomy
2003 Jetta TDI Wagon - 5sp w/.681 5th, ventectomy, 197* tstat
SD26 is offline   Reply With Quote
Old March 31st, 2012, 20:59   #12614
Fix_Until_Broke
Short/quick fix is whatever you can do with what you've got. It won't hurt anything while it's broke after the cat.
Long term fix has a lot of options. If it's MPG's and cost only, then repair with standard 2" or 2-1/4" aluminized steel pipe at your local muffler shop. The other end of the spectrum is to go full stainless from a few different vendors for significant $$.
Old March 31st, 2012, 22:29   #12615
oldpoopie
oldpoopie's Avatar
Fuel Economy: whats that?
Ordered a solar battery tender.......
Ive been driving the 85 jetta TD so much the battery in the golf went nearly dead from neglect.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Page generated in 0.21867 seconds with 9 queries
[Output: 145.62 Kb. compressed to 123.85 Kb. by saving 21.77 Kb. (14.95%)]
