Old December 22nd, 2017, 17:04   #18721
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
We're way past all that - I was mostly kidding with my "decide if I want to keep it or not" comment. That decision should have been made 6 years and $20k ago
http://forums.tdiclub.com/showthread.php?t=338260
All things considered, it doesn't owe me anything given all I've asked (and received) of it over the last 12 years, $80k and 250k miles. Currently at $0.315/mile all costs included and it's never left me stranded that I can remember.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old December 23rd, 2017, 05:18   #18722
I'm impressed you know what it's cost you. I just put a battery in my Wagon, it'll need new all-seasons in the Spring. Bought snows last year. No question that I'll keep driving it. We just did the 350K mile maintenance on my son's Golf night before last. He needs a battery, too. And this is the last season for his snows. But we probably have about $3K in that car including purchase and maintenance/repairs, and he's driven it nearly 100K miles in the last three years. Tell me that's not a bargain.
Old December 23rd, 2017, 09:27   #18723
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Bargain
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
Old December 23rd, 2017, 09:35   #18724
2015vwgolfdiesel
Arrow What I am doing for my Mk7 today
There is sand and salt on Tulsa roads this morning
TV reporting many crashes
Both cars are in the garage until roads clear.
.... no fender benders, no salt sand corrosion for us.
Old December 24th, 2017, 08:18   #18725
where2
where2's Avatar
Originally Posted by 2015vwgolfdiesel View Post
There is sand and salt on Tulsa roads this morning .... no fender benders, no salt sand corrosion for us.
No salt/sand/corrosion for us either. It's 75 out on 12/24 , I just mounted the Thule Rapid Crossroad feet I scored off CL yesterday to the Thule Aeroblade 47s I picked up for $25, then cored the feet with the locks off my old Thule square bar crossroad feet. Now, we'll see if I like the Aeroblades as much on the MkIV wagon as I do on my wife's MkV.
'06 Jetta_TDI Pkg_1 5spd (4 wife) Got Boost... 155k
'04 Jetta_TDI_Wagon_GL 5spd (4 daily) Got Miles... 222k!
'90 Corrado_G60 Pkg_2 5spd (4 fun) Supercharged and half the fuel economy of a TDI!
where2 is offline   Reply With Quote
Old December 26th, 2017, 09:54   #18726
SoKYTDi
SoKYTDi's Avatar
Fuel Economy: See my signature!
Just diagnosed a worn bell crank relay socket. Ordered a new 1st Gear Getter from DieselGeek, hope to get it & put it in by the weekend! It's a crappy time of year to be working with plastic bits...
Just a Geek, trying to make his way in this world.
2003 Golf GL TDi -- Lots o' mods and a whole list of dreams..... now in 6 gears!
SoKYTDi is offline   Reply With Quote
Old December 28th, 2017, 12:46   #18727
nokivasara
nokivasara's Avatar
Fuel Economy: 44-49 mpg
On the Golf: Replaced the rear coil springs, both were broken. On the following test drive one of the rear wheel bearings started to groan, on to the third set already, in 230k km...
nokivasara is offline   Reply With Quote
Old December 28th, 2017, 13:18   #18728
neimis
I'm curious how both of your rear springs broke? Very unusual!
92 Passat TD
01 Golf GL TDI
15 Golf Trendline TDI
neimis is offline   Reply With Quote
Old December 28th, 2017, 13:33   #18729
nokivasara
nokivasara's Avatar
Even more strange is that it passed inspection just a few weeks ago. One spring was broken almost in the middle, the other just about half a coil at the lower end.
Either the one that broke in the middle went first, putting the other spring under a different load than usual so that also snapped, or maybe that spring already was broken but not seen at the inspection.
Both looked fresh in the break though.
I had no idea about the other spring being broken until I removed it.
Old December 30th, 2017, 05:53   #18730
red16vdub
red16vdub's Avatar
Not only is unusual for rear broken springs, but also very unusual to be replacing rear wheel bearing 3 times, even is he's using spacers.
Bajan
Mk1 Gti /scIROCco 16v /A6 quattro sport / Mk4 TDI JSW 5spd
17/56 turbo, RC ASV-5+ @ 28psi, 3 Bar Map, 11mm IP, PD Lift Pump, R520's, McNally boost/egt, Euro FIS full screen Cluster, PD 150 Intake/racepipe, PD 150 plastic T.I.P + R32 maf air mods, Kerma 2.5" Fmic, Kerma 3"T-B exhaust/resonator/ Aero turbine muffler, SBC stage 3 Endurance, GLi brakes F/R , GLi axles, H&R Bilstein sports cup kit.
red16vdub is offline   Reply With Quote
Old December 30th, 2017, 11:08   #18731
nokivasara
nokivasara's Avatar
Bajan
No spacers. First wheel bearing changed at 130k km and now again at 230k km, pretty normal for a mkV... The springs were the original ones.
Old December 31st, 2017, 21:53   #18732
narongc73
Maybe in Sweden. i'm still on original rear bearings and springs. 247k miles.
narongc73 is offline   Reply With Quote
Old January 1st, 2018, 06:36   #18733
nokivasara
nokivasara's Avatar
247k on original bearings is very good. Maybe some last longer than others, but it does seem like a bad design. Lot's of threads about bad mkV bearings on the 'net.
Like this:
http://forums.tdiclub.com/showthread...=wheel+bearing
Maybe it's more common in europe , like worn camshafts are a NA thing?
Broken springs are probably caused by corrosion, we use a lot of salt on the roads over here. Mk4's suffered from that also.
Old January 4th, 2018, 16:13   #18734
narongc73
Like this:
You're right it's probably all the salt used. My cams still good too I must be lucky.
Old January 17th, 2018, 22:03   #18735
DI fan
Fuel Economy: 42 city(wife) 44 city(me) 48 highway. Best 52
I just had a broken front spring. I had a set of SRS springs. Seeing as I did not want to pony up for a completely new set of those springs (of which I really loved the handling) I opted for the lift kit springs. When I removed the other front spring I found the end of the bottom of that spring was broken. Well after about 5 days of driving the new springs... I really love em. Also, it will help with towing and kids getting bigger. It's funny switching from a dropped wagon to a lifted wagon. It feels like CUV now.
The SRS springs lasted about 100k miles with the lake sized pot holes and salted roads in my area.
DI fan is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Page generated in 0.31378 seconds with 9 queries
[Output: 137.67 Kb. compressed to 115.66 Kb. by saving 22.01 Kb. (15.99%)]
