Old March 25th, 2007, 10:47   #1
miamidiesel
Question 2002 Jetta TDI Losing Water.. Blowing White Smoke
Hi there, here is the car I have:
2002 VW Jetta TDI 64K Miles Automatic
Here is the problem:
The car in the morning blows white smoke from the tail pipe and that continues till the temp guage reaches half way. The Engine runs a little rough when cold but runs perfect when the temp is up. I live in Miami, FL so the weather here is not cold at all. (80 deg today). The car also smokes clouds of white smoke on full accelaration.
The car however does start rite up.. without any problems and never shuts off.
When i first recieved the car (it was shipped) the low coolant light was on. so I added water and filled the container to the top. The water level goes down a few inches in the container when the car stays running for long periods of time.
What should I check for?
I did check the sheredder valve and it seems to be ok.
Could it be timing? how much should i expect to pay for timing adjustment.
miamidiesel is offline   Reply With Quote
Old March 25th, 2007, 10:59   #2
HeAvYfUeL
HeAvYfUeL's Avatar
Fuel Economy: Fuelly signature --->
Hi and welcome to the club.
It seems like you have a leaking head gasket. Get it fixed before you get more damage. You should know you cannot compress water. When you compress water in a cylinder you will get a big problem.
2009 Jetta Wagon Comfortline DSG ESP build 03/09 Graphite Blue
History:
2006 Golf TDI GLS/1992 Jetta 2.slow GL
HeAvYfUeL is offline   Reply With Quote
Old March 25th, 2007, 11:18   #3
miamidiesel
would the car run as good as it does with a leaking head gasket... also i dont really see oil mixed with water? how else can i check for the head gasket problem...
Old March 25th, 2007, 11:27   #4
studebaker
Fuel Economy: 41-42
Head gasket leak is the problem. It will only get worse so you need to get it fixed.
studebaker is offline   Reply With Quote
Old March 25th, 2007, 11:32   #5
HeAvYfUeL
HeAvYfUeL's Avatar
Hi,
You are writing that the engine runs a little rough when cold. This could mean your headgasket is leaking when your engine is cold/stopped. When everything heats up (expansion) it doesn't leak anymore. Also the pressure in the cylinders is higher then in the cooling system, which stops the leaking. Check the colour of your coolant. Fix it before it is too late.
History:
Old March 25th, 2007, 11:42   #6
miamidiesel
how much should i expect to pay for the head gasket replacement ?
Also, should I try to remove the radiator cap and start the car to see if water pops back out?
Old March 25th, 2007, 12:25   #7
miamidiesel
just removed the radiator cap and had some one start the car and accelerate... and i saw watter bubbling in the container... with lots of bubbles....
Old March 25th, 2007, 12:42   #8
HeAvYfUeL
HeAvYfUeL's Avatar
Get it fixed before it is too late !
Get a quote at the dealer or find a local guru.
Don't know about the price.
History:
Page generated in 0.14071 seconds with 9 queries
[Output: 81.66 Kb. compressed to 70.02 Kb. by saving 11.64 Kb. (14.26%)]
