xbangu
Hello-
this morning when I was driving to work, all sudden the engine start to make lloud clanking sound. Normally when idle you here the sound and when rev increase you hear it less. This is vice-versa and powerloss guessing about 25-40%. Can't hear turbo spool anymore and the the higher rev you go the higher the sound until freeway noise overcome it.
Took it to a mech, he guessing one cylinder died and will take out the iol pan to look at it.
other note: oil replace about 6K ago with timing belt.
any tip or hint to pointout this fix/cause?
thanks in advance.
thanks in advance.
