Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Non VW Group Diesels
Non VW Group Diesels This section is for discusion of Non VWGroup Diesels.
Old March 18th, 2007, 06:47   #1
jrock
Fuel Economy: 52.93 MPG MAX
Default 2.8 Powerstroke into a Ford Ranger
Edit: Dieseltoyz.com no longer carries the 2.8 powerstroke engine.
I’m looking for more information on a conversion, 2.8 Powerstroke into a Ford Ranger. If someone has experience or can direct me to information I’d greatly appreciate it.
Here are some of the things I do know:
Direct bolt into US ford ranger pickups
Engine is available from Diesel Toyz
http://www.dieseltoyz.com/
Cost is $5000 shipped. Engine is new with warranty.
Will work with NV series transmissions, AX series transmissions series transmissions series transmissions
True one wire engine (one wire to fuel cut solenoid)
277 ft/lbs torque at 1400 rpm
Direct injection turbo diesel with variable vane turbo
Bosch pump
Intercooled from factory
2 stage injectors
I also know that information is limited compared to Toyota diesel conversions.
2014 RAM Ecodiesel
2012 Passat SEL TDI
2005 Passat TDI (Sold)
2001 Jetta TDI
2000 Corvette (not a TDI but very fast)
jrock is offline   Reply With Quote
Old March 18th, 2007, 18:33   #2
TurbinePower
TDI(s): None
So... does that mean it doesn't have an engine computer? Holy crap, I may toss out everything and go back to a Ranger...
TurbinePower is offline   Reply With Quote
Old March 19th, 2007, 08:24   #3
jrock
It is probably similar to the 12 value Cummins
2014 RAM Ecodiesel
2012 Passat SEL TDI
2001 Jetta TDI
Old March 20th, 2007, 07:13   #4
highflyin250x
I am looking for information on these conversions. All i have found is people putting them in land rovers. Bolt in swap for a Ranger sounds great. From what i have read they can be adapted to many transmissions, but i was really hoping that someone could lay it all out. What else can they be swaped into? How difficult is getting the engine fully functional (guages, A/C, and all)? With all that torque will a stock ranger trans hold up? any 6 speed trans avalible? What trannys do they bolt up to, and which need adapters?
highflyin250x is offline   Reply With Quote
Old March 20th, 2007, 11:12   #5
jrock
Iíve got the same questions. For fun you can check out this powerstroke ranger. Itís the real deal not a conversion.
http://www.blueovalforums.com/forums/index.php?showtopic=6035&st=0&p=81210&#entry81210
2014 RAM Ecodiesel
2012 Passat SEL TDI
2001 Jetta TDI
Old March 20th, 2007, 12:18   #6
mavapa
TDI(s): 2001 golf
That kind of conversion probably couldn't be done legally or at least driven on the road legally in some states. That would (or might) include any state with an emissions test requirement.
mavapa is offline   Reply With Quote
Old March 20th, 2007, 15:20   #7
highflyin250x
I asked dieseltoyz about the warranty on the engine and got the response
"We are currently not offering engines for sale, only conversions. -Todd"
But i have heard that there are other sources for these engines, maybe even a little cheaper. I am trying to track them down. If i only had the info to figure out if i am actually going to try and do this.
Old March 24th, 2007, 20:42   #8
wreaks
TDI(s): None, Yet.
Default ebay
this guy in canada apparently is selling them, for like 6k + 1000 shipping, seems a bit high imo.
http://cgi.ebay.com/ebaymotors/4-cyl...temZ7997424276
wreaks is offline   Reply With Quote
Old March 27th, 2007, 06:46   #9
highflyin250x
i asked the guy on ebay if the motor is a bolt in swap for a ranger and this is the response i got
Hi Hello
They are a direct bolt in when replacing a 300TDI diesel. Some mods to motor mounts. OOPS you mean Ford Ranger. No they are not a drop in but size and power they would make a very nice engine in the truck. In South America they were used for years. They used a Eatom 5 speed that is not sold in North America.
The engine is sold for off road use only or in trucks that are 25 years of age. The engines are not EPA certified. They burn a lot cleaner than some diesels that are certifued.
Stephen
Old April 4th, 2007, 12:32   #10
cbass94
cbass94's Avatar
This is the most popular swap for the Land Rover Defender 90. It's a HS2.8 Liter TGV engine built by MWM-International (same company that makes the Powerstrokes). They can be sourced here and bought to your heart's content: http://www.obwcanada.com/ This is that same guy that was selling the engine on Ebay that is listed above
They are a great engine for a swap because they don't have too many electronics. There is a better engine (IMO) for this swap though, and it's actually the one that is sold in South America currently in the Ford Ranger and F150. It's the 3.0L NGD International engine. I like it better because it's common-rail (with the piezo-electronic actuators, yada, yada, yada) and because it's got a variable geometry turbocharger (similar to the MKIV+ VW TDI's as you know). This provides it with phenomenal torque from very low in the rev range and great driving characteristics. More info about that engine can be found here: http://www.mwm-international.com.br/...ies&idSerie=23
It has been rumored that Ford is putting a version of this 3.0L NGD engine in some delivery trucks this year in the US, but I have yet to get my hands on one of them here in the US. They are all over Brazil though, and were there even 3 years ago.
*EDIT* Read to your heart's content about the 2.8 here: http://d-90.com/forum/showthread.php...ght=diesel+2.8
"You have champagne taste on a beer budget." - Mom
2011 Volkswagen JSW DSG (aka BW)
2003 Volkswagen Jetta TDI GLS 5-speed (aka Jetter)
1994 Land Rover Defender 90 5-speed (aka Landy)
cbass94 is offline   Reply With Quote
Old April 12th, 2007, 06:54   #11
highflyin250x
found another thread on this that is pretty good...
http://www.therangerstation.com/foru...hp?t49128.html
Old April 22nd, 2007, 08:25   #12
redhedbronco
If you want to do it cheaply buy a Frito van. Have 3.9 Cummins can bolt Ford, Chevy or Dodge to them. Last 300-400k before rebuild. A guy called "Mooktank" put one into a newer Ranger and claims close to 40 mpg and all the power you want. You can get these vans for 1000 or less.
redhedbronco is offline   Reply With Quote
Old September 17th, 2008, 07:12   #13
Dieseltoys
Dieseltoys's Avatar
We had a small shipment back in 2005 and quickly sold them all. We no longer carry these engines, know where to get them, or provide information on these engines. Great engines though.
Diesel Toys Oil Pan Armor Kits **$125**
http://store.dieseltoys.com
Dieseltoys is offline   Reply With Quote
Old November 16th, 2012, 14:01   #14
LRTDI
Just thought I'd drop this link in since I'm rebuilding an old Land Rover with new almost everything. My engine is the same 2.8 Powerstroke used in the Ranger above.
It was a development of Land Rover's 2.5 tdi aka 300tdi engine, but much improved.
http://www.mdengineering.co.uk/index.php
LRTDI is offline   Reply With Quote
Page generated in 0.17966 seconds with 9 queries
[Output: 112.19 Kb. compressed to 92.81 Kb. by saving 19.38 Kb. (17.27%)]
