Old March 30th, 2007, 02:01   #61
oldpoopie
oldpoopie's Avatar
Interesting. I wonder why my batt box interfered...... Well, my car has been tapped on the front end twice.... maybe its shifted a bit, but everything else seems to be in the right spot. Delvi, can you snap a photo?
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old March 30th, 2007, 02:10   #62
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: No data yet.
I would think that Vortexers would give some of these parts away as they install aftermarket intakes...anyone looked around or posted a WTB over there?
nicklockard is online now   Reply With Quote
Old March 30th, 2007, 08:13   #63
delvi__acevedo
Mod'aholic
delvi__acevedo's Avatar
I will try to take a picture today
2015 BMW X5 35d Msport
2015 BMW 535dx Msport
delvi__acevedo is offline   Reply With Quote
Old March 30th, 2007, 08:17   #64
delvi__acevedo
Mod'aholic
I don't think they have that those parts where only installed on the european R32 with DSG transmission. thats why they have to be ordered from europ.
Old March 30th, 2007, 08:31   #65
tongsli
Originally Posted by delvi__acevedo
I installed the snorkel, the piece under/behind the headlight today and I modified the US spec R32 air box that I had to make the snorkel fit, still have the stock TDI top of the airbox(I will change that soon)
I was able to keep the battery box without trimming
while the bumper was off I also installed the upgraded side mount intercooler
Why did the R32 airbox need to be modified? What did you modify?
RC 3.1,DG pipes,Bosio PP764, Forge SMIC,R32 airbox,FSI/OilLevelSensor,150PDTIP&MAF&Intake Manifold, Bilstein TCs,TT brakes,280mm rears,A3 strut bar,ESP,Folding Mirrors,Aero wipers,Headlight Washers,PDC,Bora Trunk switch,VR6 muffler,4-motion valance, OEM Skid Plate &HIDs,Custom Tails, Zender Spoiler,WE Power,heated Seats,RNS2,MFSW,Anti-dazzle mirror,FIS,IRU,DWA,2nd OBDII,OEM Auto Window,P3 vent gauge, Webasto Thermotop C heater
tongsli is offline   Reply With Quote
Old March 30th, 2007, 08:36   #66
Suns_PSD
TDI(s): none
Originally Posted by Suns_PSD
Does this mod apply to the 2005.5 PD motors?
Thanks.
OK, it does NOT as my snorkel is much different than the older cars.
2005.5 Jetta tdi, White Package 2, 5 sp manual. RC2, gauges, etc. Flat black Oz Ultraleggera rollin' on 18s.
Suns_PSD is offline   Reply With Quote
Old March 30th, 2007, 08:45   #67
oEo
oEo's Avatar
Fuel Economy: mid 40's
Originally Posted by oEo
Even if the snorkle ID is bigger, is everything in FRONT OF THE SNORKLE bigger as well? Doesn't the opening in the grill HAVE TO BE JUST AS LARGE?
It's a great mod, but can someone answer this question?
2 0 0 4 I n d i g o B l u e G o l f R C 1 T D I C L U B A D D I C T I O N @ 1 4 9 k R u n n i n g W i t h T 6 U O A
oEo is offline   Reply With Quote
Old March 30th, 2007, 08:55   #68
tongsli
The front grill intake doesn't change. But the shroud around the headlight has a larger hole/interface that matches the larger snorkle diameter.
If you look at this pic, it does look like the R32 shroud is larger.
Old March 30th, 2007, 09:02   #69
oldpoopie
oldpoopie's Avatar
The rear shroud isnt really larger, but rather it fits the the larger snorkle reciever that goes under the headlight.
Old March 30th, 2007, 09:10   #70
fishmando
fishmando's Avatar
Sorry to do this but bump:
So if I was using the R32 Euro DSG box (top and bottom) and snorkle, what would the MAF and accordion tube situation be? The stock is smaller than the air box outlet right?
Should/could one get an R32 MAF holder ect.? (Yes I know a mini remap would be needed)
fishmando is offline   Reply With Quote
Old March 30th, 2007, 09:14   #71
delvi__acevedo
Mod'aholic
I got a US spec R32 box for a manual transmission, and the hole was not the right size(the us r32 box has a smaller hole for the snorkel)
so I trimmed the opening and I had some gasket material and now is nice and tight
Old March 30th, 2007, 09:17   #72
dkuster
dkuster's Avatar
So, the piece pictured at the top in this photo is the piece that goes behind/below the headlight, and the piece on the lower left is the intake snorkle. But what is that piece on the lower right??
Dan
=========== '03 Golf GLS TDI ===========
RC5 ASV, VNT-17/22, 11mm IP, PP520's,
3 bar MAP, Southbend stage 3 clutch, Tyrol Sport
SMIC, upgraded IC pipes, DG Sigma Shifter, etc...
dkuster is offline   Reply With Quote
Old March 30th, 2007, 09:20   #73
tongsli
Justin,
I will take comparison photos tomorrow. I'm going to do this install.
Old March 30th, 2007, 09:20   #74
oldpoopie
oldpoopie's Avatar
Delvi, did you order the airbox from 1stvw? and was it part # 1J0129607AK?
Thats the one I got and it all fit fine.
Old March 30th, 2007, 09:22   #75
delvi__acevedo
Mod'aholic
the piece on top is the one that goes under the headlight, the one on the lower right is the one that goes behind the headlight
Page generated in 0.17470 seconds with 9 queries
[Output: 133.87 Kb. compressed to 111.43 Kb. by saving 22.44 Kb. (16.76%)]
