Old March 23rd, 2007, 06:12   #16
Occams_Razor
Occams_Razor's Avatar
So you are using the PD150 MAF without issue?
So I am guessing that a VR6 MAF Housing with a TDI insert in a VR6 upper airbox, (or does the PD150 Housing fit the R32 upper? ) with the R32 DSG lower airbox and snorkle would be the hot ticket then...
What is the difference between a VR6 airbox and a R32 airbox, (besides the hole for the larger snorkle on the R32)?
Originally Posted by IndigoBlueWagon
Spool up is crazy fast. Big difference. I am still searching for the snorkel in Europe, but have the R32 bottom on the airbox with a VR6 top. The PD150 MAF fits right into the VR6 box.
Another mod that doesn't add power. Right.
"When you have two competing trading theories which make exactly the same predictions, the one that is simpler is the better & more profitable one."
Occams_Razor is offline   Reply With Quote
Old March 23rd, 2007, 08:09   #17
oldpoopie
oldpoopie's Avatar
I'm running an r32 lower with vr6 upper. The vr6 maf housing I have does NOT fit in the R32 upper.... The diameter is nearly the same, but the way it fits in is slightly different.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old March 23rd, 2007, 09:29   #18
oEo
oEo's Avatar
Fuel Economy: mid 40's
Yes, I would like to see photos as well! Very interesting...
makes you think...
http://www.solarviews.com/raw/apo/apo13c.mov
2 0 0 4 I n d i g o B l u e G o l f R C 1 T D I C L U B A D D I C T I O N @ 1 4 9 k R u n n i n g W i t h T 6 U O A
oEo is offline   Reply With Quote
Old March 23rd, 2007, 21:16   #19
The PD 150 MAF seems fine. I will probably put a Pierburg MAF in the holder when I have it re-tuned because I want to be able to not have a tuning issue if my MAF fails. The re-tune is necessary regardless because the air flow in the new intake will be slower, causing the MAF to under-report and therefore reduce fueling at part throttle, as I understand it.
The VR6 and R32 airboxes look the same except for the snorkel size. And I had the same experience as Justin: the VR6 or PD150 MAF won't fit in the R32 airbox top, even though it looks like it should. I've got a lot of random airbox parts around now.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old March 23rd, 2007, 21:24   #20
Occams_Razor
So the bottoms are identical except for the snorkle inlet? COOL! 1 less thing I need to spend money on.
Old March 24th, 2007, 00:30   #21
delvi__acevedo
Mod'aholic
delvi__acevedo's Avatar
[quote=IndigoBlueWagon]The PD 150 MAF seems fine. I will probably put a Pierburg MAF in the holder when I have it re-tuned because I want to be able to not have a tuning issue if my MAF fails. The re-tune is necessary regardless because the air flow in the new intake will be slower, causing the MAF to under-report and therefore reduce fueling at part throttle, as I understand it.
Me too!!!, I will trim mine to make it fit..
2015 BMW X5 35d Msport
2015 BMW 535dx Msport
delvi__acevedo is offline   Reply With Quote
Old March 24th, 2007, 09:02   #22
Honeydew
hopefully an existing airbox modification kit is available from tdiparts soon!
Honeydew is offline   Reply With Quote
Old March 24th, 2007, 20:33   #23
tongsli
Justin,
Looked at the parts at Impex today while fanofalldiesels was installing his ecodes. None of us could figure out where the battery box interference was located.
Hopefully, your install pics will shed some light on the situation.
RC 3.1,DG pipes,Bosio PP764, Forge SMIC,R32 airbox,FSI/OilLevelSensor,150PDTIP&MAF&Intake Manifold, Bilstein TCs,TT brakes,280mm rears,A3 strut bar,ESP,Folding Mirrors,Aero wipers,Headlight Washers,PDC,Bora Trunk switch,VR6 muffler,4-motion valance, OEM Skid Plate &HIDs,Custom Tails, Zender Spoiler,WE Power,heated Seats,RNS2,MFSW,Anti-dazzle mirror,FIS,IRU,DWA,2nd OBDII,OEM Auto Window,P3 vent gauge, Webasto Thermotop C heater
tongsli is offline   Reply With Quote
Old March 24th, 2007, 21:29   #24
oldpoopie
oldpoopie's Avatar
I know it looks like it will fit, but it just didnt, at least on my car.
Pics tomorrow....
Old March 26th, 2007, 04:03   #25
Turbosprezarka
Fuel Economy: 56.10/55-50/35.67
Could you mate the stock TDI upper airbox with the R32 lower airbox, instead of using the VR6 upper airbox?
PP520s, RC3 AHF 110, PD Lift Pump, VR6/G60 clutch, VDO boost & EGT gauges, Provent, 2.5" CAT-back & cherry bomb, CAT 2u fuel filter, Koni Sports
245,000 miles and counting
Turbosprezarka is offline   Reply With Quote
Old March 26th, 2007, 07:37   #26
oldpoopie
oldpoopie's Avatar
yes, that would work without issue.
Old March 26th, 2007, 10:09   #27
tongsli
Justin, is it the VR6 (top portion) airbox that has the interference? Or the lower R32 portion?
Lito
Old March 26th, 2007, 12:55   #28
fishmando
fishmando's Avatar
So does:
Airbox: 1J0129607AK
AIRCLEANER $91.55
...Include the top and bottom or just the bottom?
Also, I want to replace my MAF housing with something bigger since I am about to remap... What is a good combo of airbox top and housing?
fishmando is offline   Reply With Quote
Old March 26th, 2007, 13:08   #29
fishmando
fishmando's Avatar
1J0129607AK $122.15
AIRCLEANER
Uhhh.. did the price go up?
Old March 26th, 2007, 15:35   #30
Turbosprezarka
I happened to notice that too, its been advertised at that price for a week now.
Originally Posted by fishmando
1J0129607AK $122.15
AIRCLEANER
Page generated in 0.16645 seconds with 9 queries
[Output: 129.72 Kb. compressed to 107.89 Kb. by saving 21.83 Kb. (16.83%)]
