Old February 2nd, 2018, 09:51   #226
I installed this setup (bought piecemeal from Europe) in 2006, along with a PD150 airbox to intake and intake manifold. Still like it, although it's significantly louder than the stock setup. I tend to forget it's not what came in the car, until someone asks me about it.
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old February 2nd, 2018, 13:07   #227
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Originally Posted by [486] View Post
why move weight off of the drive wheels?
I tossed the tube that goes around the battery a long time ago, and went with a VR6 upper filter box long ago to get more MAF range
now I'm finding that I'll need to figure out a new filter setup. Stock one was still doing fine performance wise, just doesn't fit in the engine bay any more. Might even have to go MAP based fueling. :c
Anything under 50mm inducer can be happily fed by the stock airbox, beyond that you might start running into restriction.
more balanced weight distribution for road courses
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old February 2nd, 2018, 14:19   #228
You smile, but the battery is in the worst possible place in these cars if you want to corner balance them. On the heavy side of the car, at the heavy end, at the far corner, in front of the wheels. Swapping the stock battery to a 9 lb. Braille battery for track days made a significant improvement in corner balancing my TDI.
Old February 2nd, 2018, 14:26   #229
TDIJetta99
TDIJetta99's Avatar
yeah it's in a terrible spot.. I have an auxiliary battery tucked in by the spare tire for the sound system, but on track days that aux battery serves as a main battery after the engine is running haha..
Page generated in 0.14495 seconds with 9 queries
[Output: 64.85 Kb. compressed to 57.98 Kb. by saving 6.87 Kb. (10.60%)]
