Old March 14th, 2007, 00:00   #1
oldpoopie
oldpoopie's Avatar
Default upgraded OEM intake snorkle
Well, because I've done so many mods to my intake track, I was pondering upgrading to a larger bore cold air intake. I felt the largest restriction on my setup at this point was the OEM airbox. While hunting for different CAI brands and types, I stumbled on this thread over on vortex talking about a larger intake snorkle that is available only on the european R32 with DSG.
http://forums.vwvortex.com/zerothread?id=2647069&page=1
I ordered the parts and installed them last night. The fit is great, but with the larger TDI battery, the battery box must be removed or trimmed. I trimmed.
The diameter of the new snorkle is tremendous. It makes a nice throaty sound too. Its the best of both worlds. OEM airbox, with the larger flow capacity of all the aftermarket cold air intakes.
I didn't take any pics, but install was fairly simple. Bumper and battery box must be removed, but its only about an hour install.
Here are the pics from the other thread.
Originally Posted by StoicDude
Left R32, Right 1.8T
R32
1.8T top, R32 bottom
R32 left, 1.8T right
Originally Posted by Arizman3
Bought the following two pieces from Impex because they have access to european only parts.
Piece that goes under the headlight: 1J0 805 962 G B41
IMPEX SKU # 332849
Special Order European Part
Price: $16.07
Intake snorkel: 1J0 129 609 G
IMPEX SKU # 331954
Price: $42.27
Following parts came from 1stvwparts (Impex had them too but were more expensive).
Airbox: 1J0129607AK
AIRCLEANER $91.55
piece that goes behind the headlight:1J0 805 965 E B41
ADJUSTER $3.88
Airbox comes with a new filter already installed. Airbox does not have the separator in it and lacks the spring loaded flapper. Has a much larger opening for the snorkel.
The new snorkel makes the stock one look rather small and restrictive.
Rubber sealing rings for the snorkel to headlight and airbox are included.
I believe that IMPEX sells the european airbox that includes the saftey flapper.
Its part # 1J0 129 607 CC
I'll check in in a few weeks and give some reports, but my preliminary impresion is quite positive. Far better than an aftermarket part with a junky cone filter.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old March 14th, 2007, 07:51   #2
Occams_Razor
Occams_Razor's Avatar
What is the piece that goes "under the headlight"?
So you have to change the airbox also?
"When you have two competing trading theories which make exactly the same predictions, the one that is simpler is the better & more profitable one."
Occams_Razor is offline   Reply With Quote
Old March 14th, 2007, 08:01   #3
oldpoopie
oldpoopie's Avatar
the piece that goes under the headlight is the part that the snorkle connects to. You can see it at the top in this pic.
Really these are the only pieces you need. You could modify your existing airbox to fit, but I chose to buy the real thing.
Here is a link to it being done.
http://www.gti25.de/viewtopic.php?t=...r=asc&start=15
Old March 14th, 2007, 10:03   #4
dok
Looks great. Love to see pics of the install. I need to get rid of my K&N filter and go back to at least the stock air box. This looks like a good improvement. Any difference in spool up or egt's?
Thanks,
David K.
dok is offline   Reply With Quote
Old March 14th, 2007, 21:51   #5
delvi__acevedo
Mod'aholic
delvi__acevedo's Avatar
hey justin, I order the parts from impex a few days ago they should be here in like 2 weeks. I'm glad you like it!!!
2015 BMW X5 35d Msport
2015 BMW 535dx Msport
delvi__acevedo is offline   Reply With Quote
Old March 14th, 2007, 21:56   #6
delvi__acevedo
Mod'aholic
I also have this one coming next week
Old March 14th, 2007, 22:10   #7
oldpoopie
oldpoopie's Avatar
Wow! Nice. Is it a tyrolsport unit? Did you get the airbox from impex as well, or from 1stvw?
You'll have to trim the back side of the battery box, but the battery fits ok. Take the bumper and headlight out to install.
-J
Old March 14th, 2007, 22:27   #8
delvi__acevedo
Mod'aholic
is a Boost factory SMIC, I got the aribox from vortex is a US spec R32 which it has the botton that fits the new intake snokel 2.5 x 4.5" I think, and the top that fits the PD150 MAF housing to match the rest of my PD 150 piping going in my car
Old March 15th, 2007, 10:30   #9
Turbosprezarka
Fuel Economy: 56.10/55-50/35.67
Wow this looks to be a great compromise for keeping our stock CAI system, while opening up that restrictive snorkel! I just checked out the CC airbox (1J0 129 607 CC) on Impex and its out of stock, going for $213, ouch. Could very well be worth it though. Someone on the Vortex forum posted airflow increases from 182 g/s to 200 g/s!!
PP520s, RC3 AHF 110, PD Lift Pump, VR6/G60 clutch, VDO boost & EGT gauges, Provent, 2.5" CAT-back & cherry bomb, CAT 2u fuel filter, Koni Sports
245,000 miles and counting
Turbosprezarka is offline   Reply With Quote
Old March 15th, 2007, 11:18   #10
tongsli
Justin,
What kind of modifications did you need to make to the battery box?
RC 3.1,DG pipes,Bosio PP764, Forge SMIC,R32 airbox,FSI/OilLevelSensor,150PDTIP&MAF&Intake Manifold, Bilstein TCs,TT brakes,280mm rears,A3 strut bar,ESP,Folding Mirrors,Aero wipers,Headlight Washers,PDC,Bora Trunk switch,VR6 muffler,4-motion valance, OEM Skid Plate &HIDs,Custom Tails, Zender Spoiler,WE Power,heated Seats,RNS2,MFSW,Anti-dazzle mirror,FIS,IRU,DWA,2nd OBDII,OEM Auto Window,P3 vent gauge, Webasto Thermotop C heater
tongsli is offline   Reply With Quote
Old March 15th, 2007, 11:49   #11
oldpoopie
oldpoopie's Avatar
Originally Posted by tongsli
Justin,
Basically, I cut the entire side of the box out, starting just below the clip that holds the lid on. Ill try and get some pics... I suppose you could get the battery box that goes with a 1.8t or vr6 and run the optima red top so everything would fit, but I don't mind trimming some plastic when its out of sight.
Old March 15th, 2007, 12:03   #12
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: No data yet.
Nice upgrade! So can I buy the old snorkel and headlight thingie from you?
nicklockard is offline   Reply With Quote
Old March 19th, 2007, 07:48   #13
delvi__acevedo
Mod'aholic
I can't wait to get mine!!!
Old March 22nd, 2007, 17:51   #14
gsxr1k
gsxr1k's Avatar
Fuel Economy: 47-53 MPG
Thanks,
David K.
I'd also like to know about this ?
gsxr1k is offline   Reply With Quote
Old March 22nd, 2007, 20:53   #15
Spool up is crazy fast. Big difference. I am still searching for the snorkel in Europe, but have the R32 bottom on the airbox with a VR6 top. The PD150 MAF fits right into the VR6 box.
Another mod that doesn't add power. Right.
Page generated in 0.18492 seconds with 9 queries
[Output: 131.63 Kb. compressed to 109.75 Kb. by saving 21.89 Kb. (16.63%)]
