Old March 8th, 2007, 12:22   #1
harry4x4
TDI(s): 130 tdi golf
Default 01314 Engine Control Module 013 dtc
please help what exectly does this code mean ive read maybe to do with failing maf?
Address 03: ABS Brakes
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 01317
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
golf tdi pd 130
2001 asz
any help would be great
harry4x4 is offline   Reply With Quote
Old March 8th, 2007, 15:42   #2
weedeater
Fuel Economy: 54/43/38
Nothing to do with a failing MAF. Suggest you clear it from both your memory and the car's.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old March 8th, 2007, 15:45   #3
compu_85
Gadget Guy
compu_85's Avatar
The ABS computer is telling you there is (was) a fault in the engine computer.
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old March 8th, 2007, 16:01   #4
MOGolf
MOGolf's Avatar
It tells me you're using an old version of VAG-COM, or something else. The 01314 means the ABS controller is having trouble talking to the ECM. Text should be "Engine control module - No communication"
MOGolf is offline   Reply With Quote
Old March 8th, 2007, 18:48   #5
compu_85
Gadget Guy
compu_85's Avatar
Ahh, I thought that one was familiar... I have that one in my ABS. Something to do with the rocket chip...
-Jason
Page generated in 0.13541 seconds with 9 queries
[Output: 65.99 Kb. compressed to 58.10 Kb. by saving 7.90 Kb. (11.97%)]
