Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old December 28th, 1999, 11:38   #1
CFriedriszik
CFriedriszik's Avatar
Default Biodiesel/Sulfur Content - article
This is the gist of an article in the german magazine mot (1/2000). It gives a brief summary on the need for sulfur in diesel, and the possible solution of replacing the sulfur content with biodiesel and the advantages of biodiesel.
All diesel fuels are NOT the same today. Many engines that could use alternative variations of diesel fuel still are fueled with the standard,
sulfur-containing kind . That is no longer necessary.
Variations in fuel quality were of concern to the drivers of gasoline cars only. Until 1996, when the inferior lubricational qualities of de-sulfurized diesel fuel damaged a lot of injection pumps. In contrast to the outcry in the media about this desaster, the introduction of a standard for Biodiesel (DIN EN 51606) in 1997 didn´t cause that much of a reaction. This standard was necessary to provide the basis for the manufacturers allowance to use biodiesel in their engines. But until now, only Volkswagen allows the use of biodiesel for the majority of their diesel engines:
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>
How car manufacturers and biodiesel figure :
Audi/VW: all TDI since MY 1996, before that date modification is in most cases possible
Seat/Skoda: all TDI since MY 1996
Peugeot: Only 5% biodiesel (like in every French diesel-engine)
BMW: Extra for 525td and 525tds for 330 DM, retrofitting/other engines not possible
Citroen: Up to 30% possible, over that at own risk
Mitsubishi: Not allowed, say that ABE (=the allowance to use the car in public traffic) is void when using biodiesel (absolutely BS of course - Claus)
Mercedes: E-Class 200 and 220 is available with biodiesel-kit, which is standard on all Taxi-models. No retrofitting for older cars possible.
Volvo: S/V 70 TDI and S 80 TDI since January 1998 (these are all Audi engines). V/S 40 not possible (=Renault engines). Retrofitting not possible.
<HR></BLOCKQUOTE>
Nevertheless the interest has steadily increased: today there are over 900 filling stations in Germany that sell biodiesel.
But only few people here know that the low-sulfur diesel produced for Sweden is available here, too. It is called Greenergy. His advantage is that everybody can use it without modifications.The drawback is that it is only available at 32 stations in Germany and while it costs 6 Pfennig more than conventional diesel, there are no taxation benefits for it.
Engine developers favour the general introduction of Greenergy, because only with the low-sulfur-content fuel can low emmissions be achieved.
Warnings, Allowances, Promises: Diesel does not equal diesel any more. What should the diesel-driver fill in today ?
Standard diesel has a maximum sulfur content of 500ppm and has a Cetane number of 49.
From 01.01.2000 the content has to be reduced to 350ppm and from 2005 onwards a maximum of 50ppm is allowed. Cetane # has to be 51 or more.
The low sulfur-content needs to be equalized by the addition of additives, to keep up the lubricational qualities.
Greenergy is a low-sulfur-diesel (&lt;10ppm sulfur) from mineral oil. Special additives enhance lubrication over the minimum HFRR-result of 460 µm. Usually the Greenergy has a HFRR of 400 µm and a Cetane # of 54. It is usable down to -32 degrees Celsius. It can be used in all cars using diesel without any modifications.
Tests at Volkswagen showed, that with Greenergy CH-emmissions dropped more than 25%, CO-emmissions dropped by 30% and particle emmissions were reduced by a third. The low-sulfur-content is good for a better longetivity of the Oxidation-Catalytic Converter and for better emmissions right after cold-start.
Volkswagen issued a clear statement:
"Emmissions of all Otto- and Diesel engines could be reduced immediatedly with the mandatory introduction of low-sulfur-fuel."
Biodiesel however has nothing to do with mineral oil. The name "Rapsmethylester", abbreviated RME, gives a hint to its origin from plants. Currently 100.000 tons Biodiesel are sold in Germany annually. This fuel is usable down to -22 degrees Celsius. RME has a Cetane # of 58, a Oxygene contents of 11% and is nearly free of sulfur. Several tests, including TÜV (southern Germany) and Volkswagen, have shown that this fuel together with a Oxidation-Catalytic Converter can reduce particle emmissions by up to 50%.
Catalyst-retrofitter HJS claims that emmissions of Greenergy and biodiesel are nearly similar. Only CO-emmissions are 1-10% more with biodiesel.
Both fuels are allowed with the retrofitted catalysts.
Biodiesel has a very good lubrication. Tests have proved (http://www.biodiesel.de) that even without additives the wear is reduced. RME can even be used as an additive itself to provide the necessary lubrication for low-sulfur-diesel. RME is non-toxic, biodegradeable and can be mixed with other diesel fuels without any problems. But it is like a solvent which on the one hand keeps the fuel system clean, but on the other hand can be harmful to the paint and can attack gaskets and tubes made from regular materials. This negative feature is the only reason for the trouble with the manufacturers allowing the use of RME in their cars. Only vehicles equipped with a RME-resistant fuel system should be fueled by RME. Most cars though can be converted for cheap money.
(Ingenieurbüro Liphardt, Tel.: 0049 6175 3522)
In contrast to Greenergy, RME is a renewable source of energy. Rapeseed is planted in areas which would be not used otherwise to avoid over-production. The plant covers the ground for 11 months a year, collecting CO2 from the soil and saves the ground from being eroded. (there are negative side effects also - like monoculture and some animals being poisoned thru grazing by the rapeseed - Claus).
Biodiesel is CO2-neutral. Until beeing harvested, the plant has taken the amount of CO2 out of the soil which is emmissioned when the fuel is burned.
Why do we use standard diesel, then ? The answer is simple: If all areas possible in Germany would be used to grow Rapeseed, the average amount of 1500 litres per hectare would lead to a production of 1.200.000 tons of biodiesel per year. That would be only 5% of the diesel fuel used in Germany per year.
In France 5% biodiesel is added to all diesel-fuels already. This reduces emmisions and provides a constant market for the farmers, while the need for government subsidies to the farmers decreases.
Should you want to try biodiesel yourself, two to three tanks later the fuel-filter should be changed. Therefore, it is better to wait until a filter change before the use of biodiesel is begun, to avoid further cost and inconvenience. If you car needs to be converted first, "Ingenieurbüro Liphardt" can provide you with a kit, so you can use biodiesel in older cars, even when the manufacturer doesn´t encourage the use of RME.
One last thought: 5% of biodiesel must be tolerable by all engines, whatever the manufacturer says - or do they forbid you to drive to France at all ?
Sources:
Growing Interest in Biodiesel and low-sulfur diesel (mot 01/2000)
Info on biodiesel: http://www.biodiesel.de (Oilmill Connemann)
http://www.ufop.de (A branch of the German union of farmers)
Retrofitting RME-safe fuel tubes:
´92 VW Polo G40 - 1272ccm / 113bhp
´97 Audi A6 Avant 2.5 TDI - 2461ccm / 140bhp Ad: "Why settle for moving with the times, when you can OVERTAKE them ?"
HP: http://www.planet-interkom.de/CFriedriszik
[This message has been edited by CFriedriszik (edited December 28, 1999).]
CFriedriszik is offline   Reply With Quote
Old December 28th, 1999, 11:40   #2
CFriedriszik
Default Re: Biodiesel/Sulfur Content - article
This is my personal experience with biodiesel:
I have been using biodiesel (RME) from http://www.biodiesel.de for 11.000km now. I have not changed my fuel filter (car was relatively new, only 37.000 km when I started) and didn´t change my oil-interval.
The diesel does smell out of the pump like a combination of engine oil and olive oil and really does smell out of the exhaust like french fries. The smell is in my opinion a vast improvement over standard diesel.
I have no particular starting problems (except for a slightly unstable idle when idling after a cold-start for no longer than 30 seconds).Presently now, daily temperatures are around -10 degrees Celsius.
Driveability, power delivery and fuel consumption haven´t changed. (Perhaps I have a slighty higher consumption when it gets colder. I will know when the winter is past ). Mind you, my famous speedometer picture of 240km/h was taken during one of the first tanks of biodiesel- so no serious power loss here. :-)
There is only one big improvement:
After talking to some folks of Audi AG, I know that I have a slightly misadjusted full-power-enrichment circuit, that causes a white to light greyish mist to blow out of the exhaust at full speed. This smoke has vanished completely with the use of biodiesel. What´s more important, we all know (except Mickey, Gary and SkyPup of course) that when you practise lame driving for several hundred kilometers you will soot everything behind you on the first full-throttle acceleration. This has been greatly reduced by the use of biodiesel.
My experiences with some diesel-folks at the IAA ´99:
I talked to two guys at the IAA show in Frankfurt.
One of them worked for Mercedes-Benz. I don´t know if he was an engineer or just some talking head smooth talking the crowd. He didn´t seem to have straight answers for my question as to why M-B only equips the lesser engines only at extra price with the necessary fuel lines, while VW does this at no extra cost for nearly all models. When talking to him about particle emmissions he
didn´t agree with me that biodiesel gives you less particle emmissions, but then he couldn´t tell me other facts. I got more out of talking to those long-legged hostesses ...
The other however, was a genuine diesel engineer at Audi. They paged him especially for me, when the staff at the Audi-stand became irritated by my questions.
He stated that they have problems with biodiesel that is sold but does not meet the DIN spec EN 51606. Therefore they will not allow the use of biodiesel for their high output engines (V6 with 180 hp and 3.3litre V8). [In fact with introduction of the V6 with 180hp they don´t even allow the use of biodiesel with the 110hp engine, which before and at VW still is perfectly good for using biodiesel].
With lame excuses from this Audi-guy and the regulations for the use of biodiesel allow this as a conclusion: The fact that biodiesel is allowed is just an internal corporate political thing, as long as the manufacturer just spends the few extra cents and uses high-quality fuel-tubes.Otherwise, the company says that your engine just cannot use biodiesel.
[This message has been edited by CFriedriszik (edited January 03, 2000).]
Old December 28th, 1999, 11:44   #3
CFriedriszik
Thanks to James Berry aka "willys" for helping me with this article.
Old December 28th, 1999, 22:17   #4
ThinkDiesel
The Question is... Do US spec A3 & A4 VW's have what it takes to run Biodiesel? I am keenly interested in the stuff, but I am not about to liquify cheap American market rubber fuel lines, when silicone is required. I can only assume VW would cut some corners for US models--especially considering we don't pay $35-40,000 US for a Jetta the way you do in Europe (after Euro taxes) Also VW probably does not expect US drivers to be running "biodiesel" of all things...If I was driving an E class Benz I might be a little more flippant about pouring biodiesel into it (I'd complain vehemently to the dealer if there were any problems)... But I'm not stupid enough to think VWoA will be able to give me any useful information on this issue... Honestly the word of 3-4 knowledgable TDI Forum members is worth 10 X anything my dealer or VWoA tell me on ANY issue...
Ryan
1999.5 New Jetta GL TDI
Atlantic Blue/Gray
ThinkDiesel is offline   Reply With Quote
Old December 29th, 1999, 00:29   #5
Powder Hound
Powder Hound's Avatar
Just one small note on nomenclature: When they talk about 'regular' diesel in Europe, that is equivalent to 'low sulfur' in the USA. 'Low sulfur' in Europe is what they are calling 'ultra low sulfur' in the US.
Always interested in steep & deep
Old December 29th, 1999, 06:18   #6
cars wanted
Fuel Economy: 65/45/38
Yes, ThinkDiesel, this is a very good question, one that I had already asked VWAG. They referred my question to VWoA. VWoA told me to go ask my dealer's service department! I'm sure someone, somewhere within the VW organizations knows what kind of fuel lines we have in North American TDIs, but that person is not accessible to us questioners.
In any case, I have read that if we keep biodiesel concentration to under 10% of total fuel volume, cheap rubber hoses should still survive OK. The reason biodiesel is so hard on rubber is that there can be trace quantities of alcohol left in the final product.
It occurs to me: If someone in Europe can look up VWAG part numbers for TDI fuel lines, we could perhaps see if those part numbers correspond with VWoA TDI fuel line part numbers on North American TDIs.
cars wanted is offline   Reply With Quote
Old December 31st, 1999, 03:54   #7
TooSlick
TDI(s): Audi 100S
I can't imagine that all the rubber parts in the TDI fuel system aren't some type of elastomer (synthetic rubber) that would be compatible with bio-diesel, unless it has a different effect with regards to seal swelling??? Perhaps BKMetz knows the answer to this one? ...my background on fuels (outside of solid rocket motor propellants and Monomethyl hydrazine & Hydrogen) is very limited ....
TooSlick is offline   Reply With Quote
Old December 31st, 1999, 04:31   #8
chudzikb
What would it take to just replace the dam things? This is not a high pressure system from the fuel tank to the injector pump. How hard could it be? Acquire some high quality lines (somebody has got to have these somewhere) and go crazy. I personally have not seen biodiesel in my travels, but, I would be interested in trying it if I ever found some.
BEC
chudzikb is offline   Reply With Quote
Page generated in 0.14880 seconds with 9 queries
[Output: 89.98 Kb. compressed to 78.60 Kb. by saving 11.38 Kb. (12.65%)]
