Old March 5th, 2007, 13:12   #1
MIGHTYDAD
Default TDI Losing Power
Hello All. This is my first time here. Here we go. My wife has a great little 2000 New Beetle TDI, averages about 42 mpg. Last year she began losing power while traveling down the hiway. Not like the motor stalling, but more like watching her speed drop from 70 mph down slowly to say 60 mph or so while she had it on cruise control. She would then turn cruise off and down-shift to try and get going again, but no such luck. I took it to a local VW mechanic (specializes) and he cleaned the intake manifold out, filled with soot build up. The car had maybe 90k on it, cost me $500. Ran great!!!! Back up to full power. Now a year later it is starting to do it again. She can be trying to go up a hill and not be able to get over 60mph with it floored. Any clues? Surely the soot can't be built up again that fast can it? Also would anyone know a good way to keep soot build up down.
I want to unplug her MAF and let her drive to work and see if it still does it. Can I do that or will it hurt her car to drive it that long with it unplugged?
I would greatly appreciate any advice. Thanks, Mightydad
MIGHTYDAD is offline   Reply With Quote
Old March 5th, 2007, 13:15   #2
dieseldorf
top post dawg
dieseldorf's Avatar
Default Can you say Eye-talian tuneup?
Sure:
  • use ULSD fuel
  • use a low NOACK engine oil
  • don't ride around like an old granny
Old March 5th, 2007, 13:18   #3
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
It sounds like a bad maf. Check that first. Cheap and easy.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old March 5th, 2007, 13:46   #4
MIGHTYDAD
About how much should I expect to spend on a MAF? Will it hurt the car if I let her drive it for a day with the MAF unplugged? She drives about 70+ miles a day.
Old March 5th, 2007, 14:30   #5
TXOILBURNER
Whta kind of oil do you run?
Do you do your own oil changes?
Does she drive like a granny?
All these things could cause rapid buildup in the intake.If the oil change place puts in the wrong type or too much oil is causes rapid build up and can clog the CAT.
Does the Check Engine light or the Glow Plug light come on?A MAF failure will normally set a DTC.An Autozone will run the codes for free if you have one in the area.
TXOILBURNER is offline   Reply With Quote
Old March 5th, 2007, 14:35   #6
TXOILBURNER
Here are a couple that are close to you
500 N Penn
Independence, KS 67301
(620) 331-2877
1307 N. Main St.
Miami, OK 74354
(918) 540-2334
1700 W. Seventh Street
Joplin, MO 64801
(417) 782-9466
2900 East 7th Street
Joplin, MO 64801
(417) 659-9423
Old March 5th, 2007, 17:08   #7
diy_fool
TDI(s): '00 NB
Default Keep up to date on the fuel filter changes
Fuel filters clog too and make the car lose power. Often it will start fine but then lose the power as you drive.
So make sure to replace them at recommended intervals, 20k miles I believe.
TDI Fest 2007 Je me souviens.
00 NB running biodiesel, PP502 and 11mm pump
diy_fool is offline   Reply With Quote
Old March 6th, 2007, 07:14   #8
MIGHTYDAD
I use Rotella 5w-40 synthetic. I do my own oil changes. I always try to keep the oil level right in the middle of the suggested area. I am getting ready to start using the Rotella 5w-40 advanced soot control on my next oil change.
I thought about checking the fuel filter also, I didn't know if it could have water in it or if I maybe should just put in a new one just in case. We are just now getting out of a bad winter here.
She doesn't drive like a granny, she travels the hiways a lot for her job. Her average daily drive is about 60 to 70 miles round trip driving 70mph. She said this morning her speed dropped from 70 to 65 while going up a small hill, trust me they are all small in Kansas.
Check engine light does not come on nor the glow plug light. The glow plug light only comes on when she is starting it to signal when it is ready.
I drove it last night for about 50 miles and I drove it with it wound tight. I did notice when I went up a couple of small hills it would drop about 4 mph on the speed, but she says once in a while it bogs down so much that she has to take it off of cruise and floor it and it still takes forever to reaccelerate back to 70mph. Last time it happened she was on the interstate and a guy in a pick up was on her tail honking at her which she couldn't get over because the car flubbed out while she was passing a semi who was on her immediate right. Great position to be in.
Old March 6th, 2007, 11:29   #9
meganuke
TDIClub Contributor
meganuke's Avatar
Does the car smoke noticably under heavy throttle? If not, it's probably starving for fuel. Change the fuel filter, run a can of diesel purge through it, and check the intake for clogging again. All told, you should only be out about $30 and maybe 4 hours of your time.
meganuke is offline   Reply With Quote
Old March 6th, 2007, 14:03   #10
MIGHTYDAD
No I haven't noticed it smoking a lot. Should I purge it before I change the fuel filter or after?
Any good how to's on removing and cleaning my own intake. Last time it cost me $500 bucks, but I bet I could do it myself if I had a good how to to follow. Any suggestions?
2000 New Beetle TDI 1.9
Also how come when I look for a MAF on-line they are listed as Air Mass Meter? They look the same, are they?
Old March 6th, 2007, 18:47   #11
diy_fool
TDI(s): '00 NB
Default Change that filter
If you don't know the last time it was changed, change it now. Your symptoms are of a clogged filter, not clogged intake.
I should know, I have had both. The clogged intake is just slow all the time, there's little boost getting into the cylinders. Turbo whine is nearly gone, no air in, no exhaust out.
Filters on the other hand tend to work well when started. The goop must fall away from the pores when the engine is off, then slowly plug the few remaining holes as the engine runs. Eventually all the paths in the filter clog and the engine starves for fuel and can't produce crap hp. Petal to the metal and it won't accelerate. Sometimes no other symptoms like rough running or misfire since any fuel will fire. It's just a small fire with the little fuel.
A filter change will set you back $25 and fifteen minutes.
Old March 7th, 2007, 06:23   #12
MIGHTYDAD
Default What's the difference if any?
I unplugged the MAF and my wife said it drove much better. GREAT! But now I am confused as to which part I need. Is there a difference between an MAF and an Air Mass Meter? They look exactly the same, but are called different names on different on-line store sites. The tdi.com site says MAF and runs about $125 bucks and the Air Mass Meter on autoparts warehouse is $90 bucks. What's up? Any good suggested places to pick the right one up for the best price?
I am still going to change the fuel filter and purge it. Thanks for the info.
Old March 7th, 2007, 18:52   #13
diy_fool
TDI(s): '00 NB
I bought a maf at world impex they are listed at $85 and shipped quickly.
By the way, it turned out my maf wasn't bad- it was a fuel filter that clogged at 10k miles because of changing to biodiesel. It was expected but not diagnosed right.
Old March 10th, 2007, 19:08   #14
dieselTQrules
dieselTQrules's Avatar
TDI(s): '99 Beetle
Fuel Economy: 44
For those of you that have older tdi's check your flexible elboes and piping before the manifold. My elbow right before the intake is cracked and I am in the process of getting a new piece. My power surges horrible, it's loud on boost, gets horrible mileage and pretty much sucks.
'99 Beetle - Ventnectomy, Rotella T Synthetic, Hidden Hitch, VagCom, Intake/Intercooler submerged in ultrasonic tank.
Much more could be said about my items yet to be repaired - No A/C, No blower fan, intermittent boost, brake shudder, headlights... it goes on and on.
dieselTQrules is offline   Reply With Quote
Old March 17th, 2007, 12:05   #15
4JimmyVee
4JimmyVee's Avatar
Fuel Economy: 1700 ltr yr 45Mpg 5.3L/100k
There are several CCV mods available that bacisly filter the exhaust before to goes through the manifold. They way you just clean the extra filter every time you do an oil change. I have not done this but a few of my freinds have check dieseldrinks posts, as for fuel stick to premium diesel like sunoco gold.
4JimmyVee is offline   Reply With Quote
Page generated in 0.15584 seconds with 9 queries
[Output: 121.06 Kb. compressed to 100.38 Kb. by saving 20.68 Kb. (17.08%)]
