Old February 28th, 2007, 10:47   #1
yuz1954
Default VAG COM driver for 409.1 USB
Just received a cable from e-bay but the CD-ROM with drivers was damaged in the post. Does anyone know where I can download the drivers for USB cable using 409.1? Cheers, Ian
yuz1954 is offline   Reply With Quote
Old February 28th, 2007, 11:35   #2
Sebastian
Contact the vendor/seller of your 3rd party hardware, there is no generic driver - each interface vendor uses mostly own stuff and the 3rd party hardware driver is not specific for VAG-COM, it's a COM<>USB driver.
Sebastian
Sebastian is offline   Reply With Quote
Old February 28th, 2007, 11:45   #3
yuz1954
Thanks Sebastian, I've asked for a replacement CD-ROM, but was impatient to have fun with the new toy...! Cheers, Ian
Old March 1st, 2007, 06:52   #4
Lee_Taylor
Lee_Taylor's Avatar
Default usb drivers
I bought a cheapo usb connector which uses the ftdi uart chip. They seem to be quite popular. Generic drivers available here...
http://www.ftdichip.com/FTDrivers.htm
To be sure however you need to open the connector and look for the square 64pin chip. You may need a manifying lens though to see what type it is!
Once you have verified the cable works you can purchase the license. At £50 it's a bargain given what a dealer would charge just to hook your car up.
Lee_Taylor is offline   Reply With Quote
Old March 1st, 2007, 14:52   #5
yuz1954
Default USB driver
Hi Lee, Thanks for your helpful comments. The vendor had e-mailed me directing me to the FTDI website to download the drivers - you were correct! I had opened the dongle and the chip is an FTDI 232BL. I run XP, so downloaded the driver 2.00.00 However, I still can't get it to run: Having plugged in the cable, On the VAG-COM options menu, selecting USB and "Test" returns
Port status: OK
Interface: Not Found!
If I unplug the cable from the USB port, then the report says "Ross-Tech Interface Not Found!" So, this seems to suggest something is working OK. Also, in the "Add or Remove Programs" facility, the "FTDI USB Serial Converter Drivers" is listed, so this looks encouraging....
I've discovered that if I select COM3 and then press Test, the window says:
Port Status: OK
Interface: Found!
Type: Serial Pass-Through
Opto/ISo: No
Ross-Design: No
However, the above happens even if the cable is unplugged...
With the dongle plugged in (the led lights up) and turning on the ignition to the first setting, clicking on the OBD-II returns "Interface Not Found!"
As I mentioned, the CD-ROM was cracked when delivered - although no sign of any damage to the Jiffybag or to the cable and dongle...
Would be very grateful for any suggestions.... Cheers, Ian
Old March 1st, 2007, 15:51   #6
quartersaw
Fuel Economy: Passat:44mpg Golf 52MPG
........Sorry to be the bearer of bad news,but those generic USB Com Port cables tend to be problematic.I bought one on E Bay,and I could not make it work and believe me, I tried everything.The seller would not refund my money until I filed a PayPal complaint.
I ended up buying a Ross Tech Vag-Com cable and it has paid for itself many times over....
quartersaw is offline   Reply With Quote
Old March 2nd, 2007, 08:45   #7
Lee_Taylor
Lee_Taylor's Avatar
Port status: OK
Port Status: OK
Interface: Found!
Opto/ISo: No
Ross-Design: No
Ian,
mine did exactly the same. What you need to do is plug in the cable to your laptop. Now go into control panel open up or navigate to system/hardware/device manager/ports.
It will probably say USB serial port (COM3 or somesuch) open up it by double clicking, go to the port settings tab and click on advanced. This will allow you to set the com port to Com1 The cable should now connect to the car.
If the cable is unplugged from the car and you try to find it with VAG-COM it "finds" it at COM3 but it wont work. Try the above then connect to the car and test it at COM1 and it should work. It's a lot of buggering about but it should go. Try to ensure you use the same usb socket each time.
Once you know it works it is time to buy the registered version, it's well worth the expense. I have to say their cable is a lot less aggro. I have been looking at the screenshots of the next version of VAG-COM which Uwe has posted. I may have to shell out for one because it looks really pukka. Though I may get it shipped to friends in the US as I resent paying that Scottish oaf at the treasury all my hard earned cash!
Let me know how you get on.
Old March 2nd, 2007, 09:04   #8
Uwe
Uwe's Avatar
Just to avoid any possible disappointment, I want you to be aware of the following item in the Release Notes on the Beta Page:
"Screen-shots presented on this page were taken on a PC running Windows Vista.
The exact appearance of the screens will vary based on the version of Windows being used
and the Theme selected in Windows."
-Uwe-
__________________________________________________ ___
VCDS®:
Satisfaction guaranteed or double your fault codes back!
Uwe is offline   Reply With Quote
Old March 2nd, 2007, 09:07   #9
wolfsburg_de
Ross-Tech AssociateVendor
Fuel Economy: 33.5 mpg, mostly city
In other words, depending on your specific PC, the appearance may be less pukka.
support@ross-tech.com
wolfsburg_de is offline   Reply With Quote
Old March 2nd, 2007, 12:30   #10
yuz1954
Default USB Drivers
Hi Lee,
Again, thank you for your kind help. I've now persuaded the beast to work and it was exactly as you said. I decided to call FTDI this afternoon and the guy there was massively helpful if walking me through the changes. He also advised another couple: In the "Advanced settings for [COM 1 (or other port that is selected)], under:
USB Transfer Sizes, change "Receive (Bytes)" to 64
BM Options, change "Latency Timer (msec)" to 3
As you say, I now need to register the software for $99 - I assume this will active more functions? Will this then operate as the KEY-USB product from Ross-Tech selling for $249, or does the KEY-USB from Ross-Tech perform other functions in addition?
Thanks again for your time and patience - this site is a great concept!
kind regards
Ian
VW Passat 2002 TDI 130 estate
Old March 2nd, 2007, 15:41   #11
Uwe
Uwe's Avatar
The KEY-USB performs other functions, -- because it works with the latest software:
http://www.ross-tech.com/vag-com/revisions.html
It's also faster to connect and more reliable at staying connected because it has some intelligence and can buffer some data.
-Uwe-
VCDS®:
Old March 4th, 2007, 04:33   #12
Lee_Taylor
Lee_Taylor's Avatar
-Uwe-
And will work with future releases!
Old July 17th, 2013, 00:45   #13
jimbo1981
jimbo1981's Avatar
Fuel Economy: 5.1 litres/100km
I found this quick guide online having fiddled for hours - it resolved my driver hassles right away! (my chip ID is FT232RL)
http://www.evbplus.com/TinyUSB_9s12/ft232rl.html
jimbo1981 is offline   Reply With Quote
Page generated in 0.16150 seconds with 9 queries
[Output: 111.20 Kb. compressed to 93.09 Kb. by saving 18.11 Kb. (16.28%)]
