| OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs |
February 9th, 2007, 09:16
#1
DTC Library
Volkswagen Engine and Transmission Codes Published July 19, 2006
"A" Camshaft Position Actuator Circuit / Open, Bank 1
"A" Camshaft Position - Timing Over-Advanced or System Performance, Bank 1
"A" Camshaft Position - Timing Over-Retarded, Bank 1
"B" Camshaft Position - Actuator Circuit / Open, Bank 1
"B" Camshaft Position - Timing Over-Advanced or System Performance, Bank 1
"B" Camshaft Position - Timing Over-Retarded, Bank 1
Crankshaft Position - Camshaft Position Correlation, Bank 1 Sensor A
Crankshaft Position - Camshaft Position Correlation, Bank 1 Sensor B
Crankshaft Position - Camshaft Position Correlation, Bank 2 Sensor A
Crankshaft Position - Camshaft Position Correlation, Bank 2 Sensor B
"A" Camshaft Position Actuator Circuit / Open, Bank 2
"A" Camshaft Position - Timing Over-Advanced or System Performance, Bank 2
"A" Camshaft Position - Timing Over-Retarded, Bank 2
"B" Camshaft Position - Actuator Circuit / Open, Bank 2
"B" Camshaft Position - Timing Over-Advanced or System Performance, Bank 2
B Camshaft Position - Timing Over-Retarded, Bank 2
HO2S Heater Control Circuit, Bank 1 Sensor 1
HO2S Heater Control Circuit Low, Bank 1 Sensor 1
HO2S Heater Control Circuit High, Bank 1 Sensor 1
HO2S Heater Control Circuit, Bank 1 Sensor 2
HO2S Heater Control Circuit Low, Bank 1 Sensor 2
HO2S Heater Control Circuit High, Bank 1 Sensor 2
O2 Sensor Signals Swapped, Bank 1 Sensor 1/Bank 2 Sensor 1
O2 Sensor Signals Swapped, Bank 1 Sensor 2/ Bank 2 Sensor 2
HO2S Heater Control Circuit, Bank 1 Sensor 3
HO2S Heater Control Circuit Low, Bank 1 Sensor 3
HO2S Heater Control Circuit High, Bank 1 Sensor 3
HO2S Heater Control Circuit, Bank 2 Sensor 1
HO2S Heater Control Circuit Low, Bank 2 Sensor 1
HO2S Heater Control Circuit High, Bank 2 Sensor 1
HO2S Heater Control Circuit, Bank 2 Sensor 2
HO2S Heater Control Circuit Low, Bank 2 Sensor 2
HO2S Heater Control Circuit High, Bank 2 Sensor 2
MAP/MAF - Throttle Position Correlation
Fuel Rail/System Pressure - Too Low
Fuel Rail/System Pressure - Too High
Fuel Pressure Regulator 1 Performance
Intake Air Temperature Sensor 2 Circuit Low
Intake Air Temperature Sensor 2 Circuit High
Mass or Volume Air Flow "A" Circuit
Mass or Volume Air Flow "A" Circuit Range/Performance
Mass or Volume Air Flow "A" Circuit Low
Mass or Volume Air Flow "A" Circuit High
Manifold Absolute Pressure/Barometric Pressure Circuit
Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
Manifold Absolute Pressure/Barometric Pressure Circuit Low
Manifold Absolute Pressure/Barometric Pressure Circuit High
Intake Air Temperature Sensor 1 Circuit Low
Intake Air Temperature Sensor 1 Circuit High
Engine Coolant Temperature Sensor 1 Circuit Range/Performance
Engine Coolant Temperature Sensor 1 Circuit Low
Engine Coolant Temperature Sensor 1 Circuit High
Throttle/Pedal Position Sensor/Switch "A" Circuit
Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
Throttle/Pedal Position Sensor/Switch "A" Circuit Low
Throttle/Pedal Position Sensor/Switch "A" Circuit High
Insufficient Coolant Temperature for Closed Loop Fuel Control
Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
O2 Sensor Circuit, Bank 1 Sensor 1
O2 Sensor Circuit Low Voltage, Bank 1 Sensor 1
O2 Sensor Circuit High Voltage, Bank 1 Sensor 1
O2 Sensor Circuit Slow Response, Bank 1 Sensor 1
O2 Sensor Circuit No Activity Detected, Bank 1 Sensor 1
O2 Sensor Heater Circuit, Bank 1 Sensor 1
O2 Sensor Circuit, Bank 1 Sensor 2
O2 Sensor Circuit Low Voltage, Bank 1 Sensor 2
O2 Sensor Circuit High Voltage, Bank 1 Sensor 2
O2 Sensor Circuit Slow Response, Bank 1 Sensor 2
O2 Sensor Circuit No Activity Detected, Bank 1 Sensor 2
O2 Sensor Heater Circuit, Bank 1 Sensor 2
O2 Sensor Circuit, Bank 1 Sensor 3
O2 Sensor Circuit Low Voltage, Bank 1 Sensor 3
O2 Sensor Circuit High Voltage, Bank 1 Sensor 3
O2 Sensor Circuit Slow Response, Bank 1 Sensor 3
O2 Sensor Circuit No Activity Detected, Bank 1 Sensor 3
O2 Sensor Heater Circuit, Bank 1 Sensor 3
O2 Sensor Circuit, Bank 2 Sensor 1
O2 Sensor Circuit Low Voltage, Bank 2 Sensor 1
O2 Sensor Circuit High Voltage, Bank 2 Sensor 1
O2 Sensor Circuit Slow Response, Bank 2 Sensor 1
O2 Sensor Circuit No Activity Detected, Bank 2 Sensor 1
O2 Sensor Heater Circuit, Bank 2 Sensor 1
O2 Sensor Circuit, Bank 2 Sensor 2
O2 Sensor Circuit Low Voltage, Bank 2 Sensor 2
O2 Sensor Circuit High Voltage, Bank 2 Sensor 2
O2 Sensor Circuit Slow Response, Bank 2 Sensor 2
O2 Sensor Circuit No Activity Detected, Bank 2 Sensor 2
O2 Sensor Heater Circuit, Bank 2 Sensor 2
Incorrect Fuel Composition
System Too Lean, Bank 1
System Too Rich, Bank 1
System Too Lean, Bank 2
System Too Rich, Bank 2
Fuel Temperature Sensor "A" Circuit Range/Performance
Fuel Temperature Sensor "A" Circuit Low
Fuel Temperature Sensor "A" Circuit High
Fuel Temperature Sensor "B" Circuit High
Fuel Rail Pressure Sensor "A" Circuit
Fuel Rail Pressure Sensor "A" Circuit Low
Injector Circuit/Open
Injector Circuit/Open - Cylinder 1
Injector Circuit/Open - Cylinder 2
Injector Circuit/Open - Cylinder 3
Injector Circuit/Open - Cylinder 4
Injector Circuit/Open - Cylinder 5
Injector Circuit/Open - Cylinder 6
Injector Circuit/Open - Cylinder 7
Injector Circuit/Open - Cylinder 8
Injector Circuit/Open - Cylinder 9
Injector Circuit/Open - Cylinder 10
Injector Circuit/Open - Cylinder 11
Injector Circuit/Open - Cylinder 12
Injector/Injection Timing Control Circuit
Engine Overspeed Condition
Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance
Throttle/Pedal Position Sensor/Switch "B" Circuit Low
Throttle/Pedal Position Sensor/Switch "B" Circuit High
Throttle/Pedal Position Sensor/Switch "C" Circuit
Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance
Throttle/Pedal Position Sensor/Switch "C" Circuit Low
Throttle/Pedal Position Sensor/Switch "C" Circuit High
System Too Rich at Idle
Turbocharger/Supercharger Overboost Condition
Turbocharger/Supercharger Boost Sensor "A" Circuit Range/Performance
Turbocharger/Supercharger Boost Sensor "A" Circuit Low
Turbocharger/Supercharger Boost Sensor "A" Circuit High
Turbocharger/Supercharger Boost Sensor "B" Circuit Range/Performance
Turbocharger/Supercharger Boost Sensor "B" Circuit Low
Turbocharger/Supercharger Boost Sensor "B" Circuit High
Turbocharger/Supercharger Wastegate Solenoid "A"
Turbocharger/Supercharger Wastegate Solenoid "A" Low
Turbocharger/Supercharger Wastegate Solenoid "A" High
Turbocharger/Supercharger Wastegate Solenoid "B"
Turbocharger/Supercharger Wastegate Solenoid "B" Low
Turbocharger/Supercharger Wastegate Solenoid "B" High
Injection Pump Fuel Metering Control "A" (Cam/Rotor/Injector)
Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
Cylinder 1 Injector Circuit Low
Cylinder 1 Injector Circuit High
Cylinder 1 Contribution/Balance
Cylinder 2 Injector Circuit Low
Cylinder 2 Injector Circuit High
Cylinder 2 Contribution/Balance
Cylinder 3 Injector Circuit Low
Cylinder 3 Injector Circuit High
Cylinder 3 Contribution/Balance
Cylinder 4 Injector Circuit Low
Cylinder 4 Injector Circuit High
Cylinder 4 Contribution/Balance
Cylinder 5 Injector Circuit Low
Cylinder 5 Injector Circuit High
Cylinder 5 Contribution/Balance
Cylinder 6 Injector Circuit Low
Cylinder 6 Injector Circuit High
Cylinder 6 Contribution/Balance
Cylinder 7 Injector Circuit Low
Cylinder 7 Injector Circuit High
Cylinder 7 Contribution/Balance
Cylinder 8 Injector Circuit Low
Cylinder 8 Injector Circuit High
Cylinder 8 Contribution/Balance
Cylinder 9 Injector Circuit Low
Cylinder 9 Injector Circuit High
Cylinder 9 Contribution/Balance
Cylinder 10 Injector Circuit Low
Cylinder 10 Injector Circuit High
Cylinder 10 Contribution/Balance
Cylinder 11 Injector Circuit Low
Cylinder 11 Injector Circuit High
Cylinder 12 Injector Circuit Low
Cylinder 12 Injector Circuit High
Turbocharger/Supercharger Underboost Condition
Random/Multiple Cylinder Misfire Detected
Cylinder 1 Misfire Detected
Cylinder 2 Misfire Detected
Cylinder 3 Misfire Detected
Cylinder 4 Misfire Detected
Cylinder 5 Misfire Detected
Cylinder 6 Misfire Detected
Cylinder 7 Misfire Detected
Cylinder 8 Misfire Detected
Cylinder 9 Misfire Detected
Cylinder 10 Misfire Detected
Cylinder 11 Misfire Detected
Cylinder 12 Misfire Detected
Rough Road Sensor "A" Signal Circuit
Ignition/Distributor Engine Speed Input Circuit Range/Performance
Ignition/Distributor Engine Speed Input Circuit No Signal
Knock Control System Error
Knock Sensor 1 Circuit Low Bank 1 or Single Sensor
Knock Sensor 1 Circuit High Bank 1 or Single Sensor
Knock Sensor 2 Circuit Low Bank 2
Knock Sensor 2 Circuit High Bank 2
Camshaft Position Sensor "A" Circuit, Bank 1 or Single Sensor
Camshaft Position Sensor "A" Circuit Range/Performance, Bank 1 or Single Sensor
Camshaft Position Sensor "A" Circuit Low, Bank 1 or Single Sensor
Camshaft Position Sensor "A" Circuit High, Bank 1 or Single Sensor
Camshaft Position Sensor "A" Circuit, Bank 2
Camshaft Position Sensor "A" Circuit Range/Performance, Bank 2
Camshaft Position Sensor "A" Circuit Low, Bank 2
Camshaft Position Sensor "A" Circuit High, Bank 2
Ignition Coil "A" Primary/Secondary Circuit
Ignition Coil "B" Primary/Secondary Circuit
Ignition Coil "C" Primary/Secondary Circuit
Ignition Coil "D" Primary/Secondary Circuit
Ignition Coil "E" Primary/Secondary Circuit
Ignition Coil "F" Primary/Secondary Circuit
Ignition Coil "G" Primary/Secondary Circuit
Ignition Coil "H" Primary/Secondary Circuit
Ignition Coil "I" Primary/Secondary Circuit
Ignition Coil "J" Primary/Secondary Circuit
Ignition Coil "K" Primary/Secondary Circuit
Ignition Coil "L" Primary/Secondary Circuit
Camshaft Position Sensor "B" Circuit, Bank 1
Camshaft Position Sensor "B" Circuit, Bank 1 Range/Performance
Camshaft Position Sensor "B" Circuit Low, Bank 1
Camshaft Position Sensor "B" Circuit High, Bank 1
Glow Plug/Heater Circuit "A"
Glow Plug/Heater Indicator Circuit
Camshaft Position Sensor "B" Circuit Range/Performance, Bank 2
Camshaft Position Sensor "B" Circuit Low, Bank 2
Camshaft Position Sensor "B" Circuit High, Bank 2
Exhaust Gas Recirculation Flow
Exhaust Gas Recirculation Flow Insufficient Detected
Exhaust Gas Recirculation Flow Excessive Detected
Exhaust Gas Recirculation Control Circuit
Exhaust Gas Recirculation Control Circuit Range/Performance
Secondary Air Injection System Incorrect Flow Detected
Secondary Air Injection System Switching Valve "A" Circuit Open
Secondary Air Injection System Switching Valve "A" Circuit Shorted
Secondary Air Injection System Switching Valve "B" Circuit Open
Secondary Air Injection System Switching Valve "B" Circuit Shorted
Secondary Air Injection System Control "A" Circuit
Catalyst System Efficiency Below Threshold, Bank 1
Warm Up Catalyst Efficiency Below Threshold, Bank 1
Main Catalyst Efficiency Below Threshold, Bank 1
Heated Catalyst Efficiency Below Threshold, Bank 1
Heated Catalyst Temperature Below Threshold, Bank 1
Catalyst Temperature Sensor Circuit, Bank 1 Sensor 1
Catalyst Temperature Sensor Circuit Range/Performance, Bank 1 Sensor 1
Catalyst Temperature Sensor Circuit Low, Bank 1 Sensor 1
Catalyst Temperature Sensor Circuit High, Bank 1 Sensor 1
Catalyst Heater Control Circuit, Bank 1
Catalyst System Efficiency Below Threshold, Bank 2
Warm Up Catalyst Efficiency Below Threshold, Bank 2
Main Catalyst Efficiency Below Threshold, Bank 2
Evaporative Emission System Incorrect Purge Flow
Evaporative Emission System Leak Detected (small leak)
Evaporative Emission System Purge Control Valve Circuit Open
Evaporative Emission System Leak Detected (large leak)
Evaporative Emission System Vent Valve/Solenoid Circuit
Evaporative Emission System Leak Detected (very small leak)
Evaporative Emission System Purge Control Valve Circuit Low
Evaporative Emission System Purge Control Valve Circuit High
Fan 1 Control Circuit
Fan 2 Control Circuit
Exhaust Gas Recirculation Control Circuit Low
Exhaust Gas Recirculation Control Circuit High
Secondary Air Injection System Insufficient Flow, Bank 1
Secondary Air Injection System Insufficient Flow, Bank 2
Evaporative Emission System Vent Valve Control Circuit Low
Evaporative Emission System Vent Valve Control Circuit High
Vehicle Speed Sensor "A" Range/Performance
Idle Air Control System
Idle Air Control System RPM Lower Than Expected
Idle Air Control System RPM Higher Than Expected
Closed Throttle Position Switch
Exhaust Gas Temperature Sensor Circuit, Bank 1 Sensor 1
Exhaust Gas Temperature Sensor Circuit Low, Bank 1 Sensor 1
Exhaust Gas Temperature Sensor Circuit High, Bank 1 Sensor 1
System Voltage Low
System Voltage High
Cruise Control Multi-Function Input "A" Circuit
Thermostat Heater Control Circuit/Open
Thermostat Heater Control Circuit Low
Thermostat Heater Control Circuit High
Serial Communication Link
Internal Control Module Memory Check Sum Error
Control Module Programming Error
Internal Control Module Keep Alive Memory (KAM) Error
Internal Control Module Random Access Memory (RAM) Error
Internal Control Module Read Only Memory (ROM) Error
Control Module Processor
Control Module Performance
Control Module VSS Output "A"
Control Module VSS Output "B"
TCM Processor
ECM / TCM Incompatible
Fuel Pump "A" Control Circuit/Open
Fuel Pump "A" Control Circuit High
Throttle Actuator Control Range/Performance, Bank 1
Throttle Actuator Control Range/Performance, Bank 2
Sensor Reference Voltage "A" Circuit/Open
Sensor Reference Voltage "A" Circuit Low
Sensor Reference Voltage "A" Circuit High
Sensor Reference Voltage "B" Circuit/Open
Sensor Reference Voltage "B" Circuit Low
Sensor Reference Voltage "B" Circuit High
Actuator Supply Voltage "A" Circuit/Open
Actuator Supply Voltage "A" Circuit Low
Actuator Supply Voltage "A" Circuit High
Glow Plug Control Module Control Circuit/Open
Cylinder 1 Glow Plug Circuit/Open
Cylinder 2 Glow Plug Circuit/Open
Cylinder 3 Glow Plug Circuit/Open
Cylinder 4 Glow Plug Circuit/Open
Cylinder 5 Glow Plug Circuit/Open
Cylinder 6 Glow Plug Circuit/Open
Cylinder 7 Glow Plug Circuit/Open
Cylinder 8 Glow Plug Circuit/Open
Cylinder 9 Glow Plug Circuit/Open
Cylinder 10 Glow Plug Circuit/Open
Glow Plug Control Module to PCM Communication Circuit Range/Performance
ECM/PCM Power Relay Control Circuit/Open
ECM/PCM Power Relay Control Circuit Low
ECM/PCM Power Relay Control Circuit High
ECM/PCM Power Relay Sense Circuit/Open
Fan 1 Control Circuit Low
Fan 1 Control Circuit High
Fan 2 Control Circuit Low
Fan 2 Control Circuit High
Sensor Reference Voltage "C" Circuit/Open
Sensor Reference Voltage "C" Circuit Low
Sensor Reference Voltage "C" Circuit High
Transmission Control System (MIL Request)
Transmission Control System Range/Performance
Transmission Control System Electrical
Clutch Switch Input Circuit
Transmission Range Sensor "A" Circuit (PRNDL Input)
Transmission Range Sensor "A" Circuit Range/Performance
Transmission Fluid Temperature Sensor "A" Circuit
Transmission Fluid Temperature Sensor "A" Circuit Range/Performance
Transmission Fluid Temperature Sensor "A" Circuit Low
Transmission Fluid Temperature Sensor "A" Circuit High
Transmission Fluid Temperature Sensor "A" Circuit Intermittent
Input/Turbine Speed Sensor "A" Circuit
Input/Turbine Speed Sensor "A" Circuit Range/Performance
Input/Turbine Speed Sensor "A" Circuit No Signal
Generator Control Circuit
Output Speed Sensor Circuit Range/Performance
Output Speed Sensor Circuit No Signal
Gear 6 Incorrect Ratio
Incorrect Gear Ratio
Gear 1 Incorrect Ratio
Gear 2 Incorrect Ratio
Gear 3 Incorrect Ratio
Gear 4 Incorrect Ratio
Gear 5 Incorrect Ratio
Reverse Incorrect Ratio
Torque Converter Clutch Circuit/Open
Torque Converter Clutch Circuit Performance/Stuck Off
Torque Converter Clutch Circuit Electrical
Pressure Control Solenoid "A" Performance/Stuck Off
Pressure Control Solenoid "A" Stuck On
Pressure Control Solenoid "A" Electrical
Pressure Control Solenoid "A" Intermittent
Shift Solenoid "A" Performance/Stuck Off
Shift Solenoid "A" Stuck On
Shift Solenoid "A" Electrical
Shift Solenoid "B" Performance/Stuck Off
Shift Solenoid "B" Stuck On
Shift Solenoid "B" Electrical
Shift Solenoid "C" Performance/Stuck Off
Shift Solenoid "C" Stuck On
Shift Solenoid "C" Electrical
Shift Solenoid "D" Performance/Stuck Off
Shift Solenoid "D" Electrical
Shift Solenoid "E" Performance/Stuck Off
Shift Solenoid "E" Electrical
Pressure Control Solenoid "B" Performance/Stuck Off
Pressure Control Solenoid "B" Stuck On
Pressure Control Solenoid "B" Electrical
Pressure Control Solenoid "B" Intermittent
Shift Error
1-2 Shift
2-3 Shift
3-4 Shift
4-5 Shift
Shift Timing Solenoid "A"
Intermediate Shaft Speed Sensor "A" Circuit
Pressure Control Solenoid "C" Performance/Stuck Off
Pressure Control Solenoid "C" Stuck On
Pressure Control Solenoid "C" Electrical
Pressure Control Solenoid "C" Intermittent
Excessive Clutch "A" Slippage
Gear Lever X-Y Position Sensor Circuit
Gear Lever X Position Circuit
Gear Lever Y Position Circuit
5-6 Shift
Four Wheel Drive (4WD) Switch Circuit Low
Transmission Fluid Pressure Sensor/Switch "A" Circuit
Transmission Fluid Pressure Sensor/Switch "A" Circuit Range/Performance
Transmission Fluid Pressure Sensor/Switch "A" Circuit Low
Transmission Fluid Pressure Sensor/Switch "B" Circuit
Transmission Fluid Pressure Sensor/Switch "B" Circuit Range/Performance
TCM Communication Circuit
TCM Communication Circuit Range/Performance
TCM Communication Circuit Low
TCM Power Input Signal Intermittent
TCM Power Relay Control Circuit Low
TCM Power Relay Control Circuit High
TCM Power Relay Sense Circuit Range/Performance
TCM Power Relay Sense Circuit Low
TCM Power Relay Sense Circuit High
TCM Power Relay Sense Circuit Intermittent
Gear Shift Position Circuit
Gear Shift Position Circuit Range/Performance
Gear Shift Position Circuit Intermittent
Gear Shift Position Control Error
Gear Shift Lock Solenoid Control Circuit Range/Performance
Air Mass Meter 1/2 Implausible Signal from Load Detection
Activation Intake Manifold Flap for Air Stream Regulation Short Circuit to B+
Activation Intake Manifold Flap for Air Stream Regulation Short Circuit to Ground (GND)
Activation Intake Manifold Flap for Air Stream Regulation Open Circuit
Mass Air Flow (MAF) Sensor 2 -G246- Signal Too Small
Mass Air Flow (MAF) Sensor 2 -G246- Signal Too Large
Exhaust-Bank3, Mixture Adaptation Range 1 Lower Lean Limit Not Reached
Exhaust-Bank3, Mixture Adaptation Range 2 Lower Lean Limit Not Reached
Exhaust-Bank3, Mixture Adaptation Range 1 Rich Limit Exceeded
Exhaust-Bank3, Mixture Adaptation Range 2 Rich Limit Exceeded
Exhaust-Bank4, Mixture Adaptation Range 1 Lower Lean Limit Not Reached
Exhaust-Bank4, Mixture Adaptation Range 2 Lower Lean Limit Not Reached
Exhaust-Bank4, Mixture Adaptation Range 1 Rich Limit Exceeded
Exhaust-Bank4, Mixture Adaptation Range 2 Rich Limit Exceeded
HO2S Heater Control Circuit (Bank 1 Sensor 1) High
Bank1-Probe1, Heating Circuit Output Too Low
HO2S Heater Control Circuit (Bank 1 Sensor 2) High
HO2S Heater Control Circuit (Bank 2 Sensor 1) High
HO2S Heater Control Circuit (Bank 2 Sensor 2) High
Bank1, Sensor 1 Internal Resistance Too Large
Bank 1, sensor 2 Internal resistance too large
HO2S Heater Control Circuit (Bank 1 Sensor 1) Low
HO2S Heater Control Circuit (Bank 1 Sensor 2) Low
Bank1, Mixture Adaption (mult.) System Too Rich
Bank1, Mixture Adaption (mult.) System Too Lean
Bank2, Mixture Adaption (mult.) System Too Rich
Bank2, Mixture Adaption (mult.) System Too Lean
Bank1, Mixture Adaption (add.) System Too Lean
Bank1, Mixture Adaption (add.) System Too Rich
Bank2, mixture adaption (add.) system too lean
Bank2, Mixture Adaption (add.) System Too Rich
Load Detection Implausible Value
Load Detection Value Below Lower Limit
Load Detection Value Above Upper Limit
Mass Air Flow (MAF) Sensor -G70- Open Circuit/Short Circuit to Ground (GND)
Mass Air Flow (MAF) Sensor -G70- Short Circuit to B+
Air Mass Meter -G70 Supply Voltage
Long Term Fuel Trim Additive Air., Area 1 System Too Lean
Long Term Fuel Trim Additive Air., Area 2 System Too Lean
Manifold Absolute Pressure (MAP) Sensor -G71- Short Circuit to B+
Manifold Absolute Pressure (MAP) Sensor -G71- Open Circuit/Short to Ground (GND)
Intake Air Temperature (IAT) Sensor -G72- Short Circuit to Ground (GND)
Intake Air Temperature (IAT) Sensor -G72- Open Circuit/Short Circuit to B+
Fuel Temperature Sensor A Circuit Low
Fuel Temperature Sensor A Circuit High
Fuel Temperature Sensor -G81- Unplausible Signal
Long Term Fuel Trim Additive Air., Area 1 System Too Rich
Long Term Fuel Trim Additive Air., Area 2 System Too Rich
Mass Air Flow (MAF) Sensor 2 -G246- Unplausible Signal
Angle Sender 2 for Throttle Valve Drive -G188 Implausible Signal
Angle Sender 2 for Throttle Valve Drive -G188 Signal Too Low
Angle sender 2 for throttle valve drive -G188 Signal Too High
Fuel Trim, Bank 1 Injection Timing Deviation
Pre-Injection Switched Off
Bank1, Lambda Correction Downstream of Catalyst Control Limit Reached
Bank2, Lambda Correction Downstream of Catalyst Control Limit Reached
O2 Sensor Heater Circuit, Bank1 Sensor1 Electrical Fault
O2 Sensor Heater Circuit, Bank2 Sensor1 Electrical Fault
O2 Sensor Heater Circuit, Bank1 Sensor2 Eletrical Fault
HO2S Heater Control Circuit, Bank2 Sensor2
Cylinder 5 Fuel Injector -N83- Short circuit to B+
Cylinder 6 Fuel Injector -N84- Short circuit to B+
Cylinder 5 Fuel Injector -N83- Short Circuit to Ground (GND)
Cylinder 6 Fuel Injector -N84- Short Circuit to Ground (GND)
Cylinder 1 Injector -N30 Open Circuit
Cylinder 2 Injector -N31 Open Circuit
Cylinder 3 Injector -N32 Open Circuit
Cylinder 4 Injector -N33 Open Circuit
Cylinder 5 Injector -N83 Open Circuit
Cylinder 6 Injector -N84 Open Circuit
Needle Lift Sensor -G80- Short Circuit to Ground (GND)
Needle Lift Sender -G80 Implausible Signal
Needle Lift Sensor -G80- Open Circuit/Short Circuit to B+
Injection Pump Fuel Metering Control (A) Range/Performance
Fuel Level Too Low
Cold Start Injector -N108- Short Circuit to B+
Cold Start Injector -N108- Open Circuit/Short Circuit to Ground GND)
Engine Coolant Temperature (ECT) Sensor -G62- Short Circuit to Ground
Engine Coolant Temperature (ECT) Sensor -G62- Open Circuit/Short Circuit to B+
Air Control Valve for Injectors -N212 Air Flow Too Low
Malfunction in Cooling System
Misfire Detected Low Fuel
Knock Sensor 3-G198 Signal Too Low
Knock Sensor 3-G198 Signal Too High
Knock Sensor 4-G199 Signal Too Low
Knock Sensor 4-G199 Signal Too High
Engine Torque Monitoring 2 Value Above Upper Control Limit
EngineTorque Monitoring Value Above Upper Control Limit
Bank1, Camshaft Position (CMP) =>Sensor -G40- Short Circuit to Ground (GND)
Bank 1, Camshaft Position (CMP) Sensor -G40- = > Open Circuit/Short Circuit to Ground (GND)
Camshaft Position Sensor-G40, Engine Speed Sensor-G28 Incorrect Allocation
Ignition Coil Power Output Stage 1 Short Circuit to Ground (GND)
Ignition Coil Power Output Stage 2 Short circuit to Ground (GND)
Ignition Coil Power Output Stage 3 Short Circuit to Ground (GND)
Modulating Piston Movement Sender -G149 Electrical Fault in Circuit
Ignition Activation Cylinder 1 Open Circuit
Ignition Activation Cylinder 1 Short Circuit to B+
Ignition Activation Cylinder 1 Short Circuit to Ground (GND)
Ignition Activation Cylinder 2 Open Circuit
Ignition Activation Cylinder 2 Short Circuit to B+
Ignition Activation Cylinder 2 Short Circuit to Ground (GND)
Ignition Activation Cylinder 3 Open Circuit
Ignition Activation Cylinder 3 Short Circuit to B+
Ignition Activation Cylinder 3 Short Circuit to Ground (GND)
Ignition Activation Cylinder 4 Open Circuit
Ignition Activation Cylinder 4 Short Circuit to B+
Ignition Activation Cylinder 4 Short Circuit to Ground (GND)
Bank2, Camshaft Position (CMP) =>Sensor 2 -G163- Short Circuit to Ground (GND)
Bank2, Camshaft Position (CMP) = >Sensor 2 -G163- Open Circuit/Short Circuit to B+
Ignition Output 1 Electrical Fault in Circuit
Ignition Output 2 Electrical Fault in Circuit
Ignition Output 3 Electrical Fault in Circuit
EGR Vacuum Regulator Solenoid Valve -N18- Short Circuit to Ground (GND)
EGR Vacuum Regulator Solenoid Valve -N18- Short Circuit to B+
Exhaust Gas Recirculatio Sensor (A) Circuit Low
Exhaust Gas Recirculatio Sensor (A) Circuit High
Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80- Short Circuit to B+
Bank2, Secondary Air System Air Flow Too Low
Pressure Sensor for Exhaust Gas Recirculation Signal Too High
Bank2, Secondary Air System Leak Detected
Fuel Level Sensor (A) Circuit High
Secondary Air Injection System Switching Valve (A) Circuit Malfunction
Secondary Air Injection (AIR) Solenoid Valve -N112- Short Circuit to Ground (GND)
Secondary Air Injection (AIR) Solenoid Valve -N112- Short Circuit to B+
Bank1, Secondary Air System Leak Detected
Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80- Short Circuit to Ground (GND)
Evaporative Emission System Pure Control Valve Circuit Open
Secondary Air Injection System Switching Valve (A) Circuit Open
Secondary Air Pump Relay-J299 Open Circuit
Secondary Air Injection (AIR) Pump Relay -J299- Short Circuit to B+
Secondary Air Injection (AIR) Pump Relay -J299- Short Circuit to Ground (GND)
Valve -2- for EGR -N213- Short Circuit to B+
Valve -2- for EGR -N213- Open Circuit/Short Circuit to Ground (GND)
Exhaust Gas Recirculation Valve -N18 Open Circuit
Exhaust Gas Recirculation Valve -N18- Open Circuit/Short Circuit to Ground (GND)
Temperature Sensor 1 for Catalyst -G20- Short Circuit to Ground (GND)
Secondary Air Injection System Short Circuit to B+
Secondary Air Injection System Short Circuit to Ground (GND)
Secondary Air System Open Circuit
Evaporative Emission (EVAP) Canister Purge Solenoid Valve -N115- Short to B+
Evaporative Emission (EVAP) Canister Purge Solenoid Valve -N115- Short to Ground
Evaporative Emission (EVAP) Canister Purge Solenoid Valve -N115- Open
EVAP Emission Control LPD Circuit Short Circuit to B+
EVAP Emission Control LPD Circuit Short Circuit to Ground (GND)
Leak Diagnosis Pump - Tank Breather System Open Circuit
Leak Diagnosis Pump - Tank Breather System Malfunction/No Signal
Leak Diagnosis Pump - Tank Breather System Malfunction/Vacuum Too Low
Secondary Air Injection (AIR) Pump Relay 2 -J545- Short Circuit to B+
Secondary Air Injection (AIR) Pump Relay 2 -J545- Short Circuit to Ground (GND)
Secondary Air Injection (AIR) Pump Relay 2 -J545- Electrical Malfunction in Circuit
Evaporative Emission (EVAP) Canister Purge Regulator Valve 2 -N333- Short Circuit to B+
Evaporative Emission (EVAP) Canister Purge Regulator Valve 2 -N333- Short Circuit to Ground (GND)
Evaporative Emission (EVAP) Canister Purge Regulator Valve 2 -N333- Open Circuit
Secondary Air System, Bank 3 Flow Faulty
Secondary Air System, Bank 4 Flow Faulty
Fuel Pump Primary Circuit Fault in Electrical Circuit
Fuel Pump (FP) Relay -J17- Short Circuit to Ground (GND)
Fuel Pump (FP) Relay -J17- Short circuit to B+
Idling Switch -F60 Does Not Close/Open Circuit
Closed Thottle Position (CTP) Switch -F60- Does Not Open/Short Circuit to Ground (GND)
Main Relay =>-J271 Electrical Fault in Circuit
A' Camshaft Position Actuator Circuit Bank 1 Malfunction
A' Camshaft Position Actuator Circuit Bank 2 Malfunction
Fuel Pump Relay -J17 Open Circuit
Angle Sender 1 for Throttle Valve Drive -G187 Implausible Signal
Angle Sender 1 for Throttle Valve Drive -G187 Signal Too Low
Angle Sender 1 for Throttle Valve Drive -G187 Signal Too High
Throttle Valve Control System Malfunction
Turbo/Super Charger Wastegate Solenoid (A) High Input/Short to B+
Turbo/Super Charger Wastegate Solenoid (A) Open/Short Circuit to Ground
Turbo/Super Charger Boost Sensor (A) Circuit Control Limit Not Reached
Turbo/Super Charger Overboost Condition Control Limit Exceeded
Throttle Valve Drive -G186 Electrical Fault in Circuit
Throttle Valve Control Part -J338- Fault in Basic Settings
Quantity Adjuster -N146 Upper Limit Stop Value
Quantity Adjuster -N146 Lower Limit Stop Value
Throttle Valve Control Part -J338- Lower Stop Not Reached
Throttle Valve Control Module -J338- Mechanical Malfunction
Throttle Valve Drive - Bank 1 Malfunction
Idling Speed Regulation Adaptation Limit Reached
Height Sensor/Charge Pressure Sensor Unplausible Ratio
Coolant Pump2 Control Circuit Open
Coolant Pump 2 Control Circuit Low
Coolant Pump 2 Control Circuit High
Request MIL on Short Circuit to Ground (GND)
Engine Control Unit Incorrect Coding
Request MIL on Open Circuit/Short Circuit to B+
Glow Plug Relay -J52- Short Circuit to B+
Glow Plug Relay -J52- Open Circuit/Short Circuit to Ground (GND)
Data-Bus-Drivetrain Implausible Message From Transmission Control Module
Data-Bus-Drivetrain Missing Message From Transmission Control Module
Data-Bus-Drivetrain Missing Message From ADC Control Module
Throttle/Pedal Position Sensor/Switch -C- Circuit Low
Throttle/Pedal Position Sensor/Switch -C- Circuit High
Throttle/Pedal Position Sensor/Switch -C- Circuit Voltage Supply
Accelerator Pedal Position Sender 2 -G185 Signal Too Low
Accelerator Pedal Position Sender 2 -G185 Signal Too High
Checking Coding/Versions of Control Modules in CAN-Bus
Data-Bus-Driving Gear Faulty
Data-Bus-Drivetrain Missing Message From ABS Control Module
Data-Bus-Drivetrain Missing Message From Instrument Cluster
Speed Signal Malfunction Message Fom ABS Control Module
Control Unit Programming Programming Not Finished
Malfunction Cannot Activate Envisioned Replacement Function, Since Another Malfunction With Equal Pritority is Present
Voltage Supply for Solenoid Valves Short Circuit to B+
Supply Voltage for Solenoid Valves
Voltage supply for solenoid valves Open circuit/short circuit to Ground (GND)
System Voltage Low Voltage
System Voltage High Voltage
Valve 7 Electrical Fault in Circuit
Torque Withdrawal Faulty
Pressure Control Valve 1 -N215 Electrical Fault in Circuit
Pressure Control Valve -1- for Auto. Transmission -N215- Open Circuit/Short Circuit to Ground (GND)
Pressure Control Valve -1- for Auto. Transmission -N215- Short Circuit to B+
Pressure Control Valve 2 -N216 Electrical Fault in Circuit
Pressure Control Valve -2- for Auto. Transmission -N216- Open Circuit/Short Circuit to Ground (GND)
Pressure Control Valve -2- for Auto. Transmission -N216- Short Circuit to B+
Pressure Control Valve 3 -N217 Electrical Fault in Circuit
Pressure Control Valve -3- for Auto. Transmission -N217- Open Circuit/Short Circuit to Ground (GND)
Pressure Control Valve -3- for Auto. Transmission -N217- Short Circuit to B+
Pressure Control Valve 4 -N218 Electrical Fault in Circuit
Pressure Control Valve -4- for Auto. Transmission -N218- Open Circuit/Short Circuit to Ground (GND)
Pressure Control Valve -4- for Auto. Transmission -N218- Short Circuit to B+
Engine control module/Transmission Control Module (TCM)
Versions not compatible
Data-Bus-Drivetrain Missing Message From Engine Control Module
Data-Bus-Driving Fear Hardware Faulty
Data-Bus-Driving Gear Software Version Monitoring
Load Signal Fault Signal From Engine Control Unit
Throttle Position (TP) Sensor -G79-
Malfunction Indication From Engine Control Module (ECM)
Data-Bus-Driving Fear Missing Messages
Control Module Pin Coding Unplausible Signal
Turbocharger (TC) Control Module 2 Faulty
Automatic Glow Time Control Module 2, Electrical Circuit Electrical Malfunction Electrical Circuit
Glow Plug Control Module 2 to PCM Comm. Circuit Range/Performance
Intake Manifold Runner Control Stuck Open
Intake Manifold Runner Control Circuit/Open, Bank 1
Intake Manifold Runner Position Sensor/Switch Circuit, Bank 1
Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance, Bank 1
Intake Manifold Runner Position Sensor/Switch Circuit Low, Bank 1
A Camshaft Position Actuator Control Circuit Low, Bank 1
A Camshaft Position Actuator Control Circuit High, Bank 1
B Camshaft Position Actuator Control Circuit Low, Bank 1
B Camshaft Position Actuator Control Circuit High, Bank 1
A Camshaft Position Actuator Control Circuit Low, Bank 2
A Camshaft Position Actuator Control Circuit High, Bank 2
B Camshaft Position Actuator Control Circuit Low, Bank 2
B Camshaft Position Actuator Control Circuit High, Bank 2
Post Catalyst Fuel Trim System Too Lean Bank 1
Post Catalyst Fuel Trim System Too Rich Bank 1
Post Catalyst Fuel Trim System Too Lean Bank 2
Post Catalyst Fuel Trim System Too Rich Bank 2
Throttle Actuator Control Motor Circuit/Open
Throttle Actuator Control Motor Circuit Range/Performance
Throttle Actuator Control Motor Circuit Low
Throttle Actuator Control Motor Circuit High
Throttle Actuator Control System - Forced Limited Power
Throttle Actuator Control Module Performance
Throttle Actuator Control System - Forced Limited RPM
Throttle/Pedal Position Sensor/Switch "D" Circuit Low
Throttle/Pedal Position Sensor/Switch "D" Circuit High
Throttle/Pedal Position Sensor/Switch "E" Circuit Low
Throttle/Pedal Position Sensor/Switch "E" Circuit High
Throttle/Pedal Position Sensor/Switch "F" Circuit High
Throttle/Pedal Position Sensor/Switch "D"/"E" Voltage Correlation
Fuel Injector Group "A" Supply Voltage Circuit/Open
Fuel Injector Group "B" Supply Voltage Circuit/Open
Fuel Injector Group "C" Supply Voltage Circuit/Open
System Too Lean Off Idle, Bank 1
System Too Rich Off Idle, Bank 1
System Too Lean Off Idle, Bank 2
System Too Rich Off Idle, Bank 2
Cooling System Performance
Engine Coolant Temperature Sensor 2 Circuit Low
Engine Coolant Temperature Sensor 2 Circuit High
System Too Lean at Idle, Bank 1
System Too Rich at Idle, Bank 1
System Too Lean at Higher Load, Bank 1
System Too Rich at Higher Load, Bank 1
System Too Lean at Higher Load, Bank 2
System Too Rich at Higher Load, Bank 2
O2 Sensor Signal Biased/Stuck Lean, Bank 1 Sensor 1
O2 Sensor Signal Biased/Stuck Rich, Bank 1 Sensor 1
O2 Sensor Signal Biased/Stuck Rich, Bank 2 Sensor 1
Intake Air Temperature Sensor 1/ 2 Correlation
O2 Sensor Signal Circuit Shorted to Heater Circuit, Bank 1 Sensor 1
O2 Sensor Signal Circuit Shorted to Heater Circuit, Bank 2 Sensor 1
O2 Sensor Positive Current Control Circuit/Open, Bank 1 Sensor 1
O2 Sensor Positive Current Control Circuit Low
O2 Sensor Positive Current Control Circuit High
O2 Sensor Positive Current Control Circuit/Open, Bank 2 Sensor 1
O2 Sensor Reference Voltage Circuit/Open, Bank 1 Sensor 1
O2 Sensor Reference Voltage Circuit Low
O2 Sensor Reference Voltage Circuit High
O2 Sensor Reference Voltage Circuit/Open, Bank 2 Sensor 1
O2 Sensor Negative Current Control Circuit/Open, Bank 1 Sensor 1
O2 Sensor Negative Current Control Circuit Low
O2 Sensor Negative Current Control Circuit High
O2 Sensor Negative Current Control Circuit/Open, Bank 2 Sensor 1
Secondary Air Injection System Control "A" Circuit Low
Secondary Air Injection System Control "A" Circuit High
Turbocharger/Supercharger Boost System Performance
O2 Sensor Signal Stuck Lean, Bank 1 Sensor 2
O2 Sensor Signal Stuck Rich, Bank 1 Sensor 2
O2 Sensor Signal Stuck Lean, Bank 1 Sensor 3
O2 Sensor Signal Stuck Rich, Bank 1 Sensor 3
Intake Air System Leak
Fuel Pressure Regulator 2 Performance
Fuel Pressure Regulator 2 Control Circuit
Fuel Pressure Regulator 2 Control Circuit Low
Fuel Pressure Regulator 2 Control Circuit High
Ignition Coil "A" Primary Control Circuit Low
Ignition Coil "A" Primary Control Circuit High
Ignition Coil "B" Primary Control Circuit Low
Ignition Coil "B" Primary Control Circuit High
Ignition Coil "C" Primary Control Circuit Low
Ignition Coil "C" Primary Control Circuit High
Ignition Coil "D" Primary Control Circuit Low
Ignition Coil "D" Primary Control Circuit High
Ignition Coil "E" Primary Control Circuit Low
Ignition Coil "E" Primary Control Circuit High
Ignition Coil "F" Primary Control Circuit Low
Ignition Coil "F" Primary Control Circuit High
Evaporative Emission System Leak Detection Pump Control Circuit/Open
Evaporative Emission System Leak Detection Pump Control Circuit Low
Evaporative Emission System Leak Detection Pump Control Circuit High
Evaporative Emission System Leak Detection Pump Sense Circuit/Open
Evaporative Emission System Leak Detection Pump Sense Circuit Range/Performance
Exhaust Gas Recirculation System Performance
O2 Sensor Exhaust Sample Error, Bank 1 Sensor 1
O2 Sensor Exhaust Sample Error, Bank 2 Sensor 1
O2 Sensor Signals Swapped, Bank 1 Sensor 2/Bank 1 Sensor 3
Evaporative Emission System Vent Valve Stuck Closed
Exhaust Gas Recirculation Cooling Valve Control Circuit/Open
Exhaust Gas Recirculation Cooling Valve Control Circuit Low
Exhaust Gas Recirculation Cooling Valve Control Circuit High
Low Pressure Fuel System Sensor Circuit
Low Pressure Fuel System Sensor Circuit Range/Performance
Low Pressure Fuel System Sensor Circuit Low
Turbocharger Boost Control Position Sensor "A" Circuit Low
Turbocharger Boost Control Position Sensor "A" Circuit High
Coolant Pump Control Circuit/Open
Coolant Pump Control Circuit Low
Coolant Pump Control Circuit High
O2 Sensor Pumping Current Trim Circuit/Open, Bank 1 Sensor 1
Fuel Pump "B" Control Circuit /Open
Fuel Pump "B" Control Circuit High
Torque Management Feedback Signal "A"
Pressure Control Solenoid "D" Performance/Stuck Off
Pressure Control Solenoid "D" Stuck On
Pressure Control Solenoid "D" Electrical
Pressure Control Solenoid "D" Intermittent
Pressure Control Solenoid "E" Performance/Stuck Off
Pressure Control Solenoid "E" Stuck On
Pressure Control Solenoid "E" Electrical
Pressure Control Solenoid "E" Intermittent
Pressure Control Solenoid "F" Performance/Stuck Off
Pressure Control Solenoid "F" Stuck On
Pressure Control Solenoid "F" Electrical
Pressure Control Solenoid "F" Intermittent
Glow Plug Indictor Light -K29- Malfunction Message From Instrument Cluster
Fuel Pump (FP) 2 Relay -J49- Short Circuit to B+
Fuel Pump (FP) 2 Relay -J49- Open Circuit/Short Circuit to Ground (GND)
Angle Sensor 1 (on Throttle Drive 2 Power Accelerator Actuation) -G297- Unplausible Signal
Angle Sensor 1 (on Throttle Drive 2 Power Accelerator Actuation) -G297- Signal Too Small
Angle Sensor 1 (on Throttle Drive 2 Power Accelerator Actuation) -G297- Signal Too Large
Angle Sensor 2 (on Throttle Drive 2 Power Accelerator Actuation) -G298- Unplausible Signal
Angle Sensor 2 (on Throttle Drive 2 Power Accelerator Actuation) -G298- Signal Too Small
Angle Sensor 2 (on Throttle Drive 2 Power Accelerator Actuation) -G298- Signal Too Large
Throttle Drive 2 (Power Accelerator Actuation) -G296- Electrical Malfunction in Circuit
Throttle Valve Control Module 2 -J544-
Malfunction in Basic Setting
Intake Air Temperature (IAT) Sensor 2 -G299- Signal Too Small
Intake Air Temperature (IAT) Sensor 2 -G299- Signal Too Large
Throttle Valve Control Module 2 -J544- Mechanical Malfunction
Throttle Valve Control Module 2 -J544- Lower Impact Is Not Being Reached
Activation Starter Relay 2 Short Circuit to B+
Activation Starter Relay 2 Short Circuit to Ground (GND)
Activation Starter Relay 2 Open Circuit
Exhaust Pressure Sensor 2 High
Exhaust Gas Recirc.Flow 2 Insufficient Detected
Exhaust Gas Recirc.Flow Excessive Detected
Cooling Bypass Valve, Exhaust Gas Recirculation Flow
Electrical
Cooling Bypass Valve 2, Exhaust Gas Recirculation Flow
Electrical
Turbo/Super Charger Underboost
Engine Temperature Too Low
Exhaust Gas Recirculation (EGR) System Control Limit Exceeded
Exhaust Gas Recirculation (EGR) System Lowest Control Limit Exceeded
Exhaust-Bank 3, Sensor 1, Oxygen Sensor Signal Implausibly Lean
Exhaust-Bank 3, Sensor 1, Oxygen Sensor Signal Implausibly Rich
Exhaust-Bank 4, Sensor 1, Oxygen Sensor Signal Implausibly Lean
Exhaust-Bank 4, Sensor 1, Oxygen Sensor Signal Implausibly Rich
Exhaust-Bank 3, Oxygen Sensor Before Cat, Heater Circuit Regulation at Upper Impact
Exhaust-Bank 3, Oxygen Sensor Before Cat, Heater Circuit Regulation at Lower Impact
Exhaust-Bank 4, Oxygen Sensor Before Cat, Heater Circuit Regulation at Upper Impact
Exhaust-Bank 4, Oxygen Sensor Before Cat, Heater Circuit Regulation at Lower Impact
Exhaust-Bank 3, Sensor 1 Inner Resistance Implausible
Exhaust-Bank 4, Sensor 1 Inner Resistance Implausible
Exhaust-Bank 3, Mixture Adaptation Range 3
Exhaust-Bank 3, Mixture Adaptation Range 3 Rich Limit Exceeded
Exhaust-Bank 4, Mixture Adaptation Range 3 Lean Limit Not Reached
Exhaust-Bank 4, Mixture Adaptation Range 3 Rich Limit Exceeded
Emissions-Bank 3 Sensor1, Heater Circuit Short Circuit to Ground (GND)
Emissions-Bank 3 Sensor 1, Heater Circuit Short Circuit to B+
Emissions-Bank 3 Sensor 1, Heater Circuit Open Circuit
Emissions-Bank 3 Sensor 1, Electrical Malfunction in Circuit
Emissions-Bank 3 Sensor 1, No Activity
Emissions-Bank 3 Sensor 1, Signal Too Slow
Exhaust-Bank 1 Sensor 1, Heater Return Connection
Exhaust-Bank 2 Sensor 1, Heater Return Connection
Exhaust-Bank 3 Sensor 1, Heater Return Connection
Exhaust-Bank 4 Sensor 1, Heater Return Connection
Emissions-Bank 3 Sensor 2, Heater Circuit Short Circuit to Ground (GND)
Emissions-Bank 3 Sensor 2, Heater Circuit Short Circuit to B+
Emissions-Bank 3 Sensor 2, Heater Circuit Open Circuit
Emissions-Bank 3 Sensor 2, Heater Circuit Electrical Malfunction
Emissions-Bank 3 Sensor 2, Voltage Too Low
Emissions-Bank 3 Sensor 2, Voltage Too High
Emissions-Bank 3 Sensor 2, Electrical Malfunction in Circuit
Emissions-Bank 3 Sensor 2, No activity
Emissions-Bank 3 Sensor 2, Signal Too Slow
Exhaust-Bank 3, O2 Correction Behind Catalyst, B1 Limit Attained
Exhaust-Bank 4, O2 Correction Behind Catalyst, B1 Limit Attained
Emissions-Bank 4 Sensor 1, Heater Circuit Short Circuit to Ground (GND)
Emissions-Bank 4 Sensor 1, Heater Circuit Short Circuit to B+
Emissions-Bank 4 Sensor 1, Heater Circuit Open Circuit
Emissions-Bank 4 Sensor 1, Electrical Malfunction in Circuit
Emissions-Bank 4 Sensor 1, No Activity
Emissions-Bank 4 Sensor 1, Signal Too Slow
Emissions-Bank 4 Sensor 2, Heater Circuit Short Circuit to Ground (GND)
Emissions-Bank 4 Sensor 2, Heater Circuit Short Circuit to B+
Emissions-Bank 4 Sensor 2, Heater Circuit Open Circuit
Emissions-Bank 4 Sensor 2, Heater Circuit Electrical Malfunction
Emissions-Bank 4 Sensor 2, Voltage Too Low
Emissions-Bank 4 Sensor 2, Voltage Too High
Emissions-Bank 4 Sensor 2, Electrical Malfunction in Circuit
Emissions-Bank 4 Sensor 2, No Activity
Emissions-Bank 4 Sensor 2, Signal Too Slow
Exhaust Bank 3/4 Oxygen Sensors Before Catalytic Converter Swapped
Exhaust Bank 1/2 Oxygen Sensors Behind Catalytic Converter Swapped
Exhaust Bank 3/4 Oxygen Sensors Behind Catalytic Converter Swapped
Linear 02 Sensor, Exhaust-Bank 3/Pump Current Open Circuit
Linear 02 Sensor, Exhaust-Bank 3/Reference Voltage Open Circuit
Linear 02 Sensor, Exhaust-Bank3/Common Ground Wire Open Circuit
Linear 02 Sensor, Exhaust-Bank 4/Pump Current Open Circuit
Linear 02 Sensor, Exhaust-Bank 4/Reference Voltage Open Circuit
Linear 02 Sensor, Exhaust-Bank 4/Reference Voltage Short Circuit to Ground
Linear 02 Sensor, Exhaust-Bank 4/Common Ground Wire Open Circuit
Catalytic Converter System, Exhaust-Bank 3 Effectiveness Too Low
Catalytic Converter System, Exhaust-Bank 4 Effectiveness Too Low
Intake Flap Motor 2 Short to B+
Intake Flap Motor 2 Open/Short to Ground
Intake Flap Motor 2 No Signal
Intake Flap Motor 2 Faulty
Automatic Glow Time Control Relay 2 Electrical Malfunction in Circuit
Intake Air Temperature Sensor 3 Circuit-G520 Low
Intake Air Temperature Sensor 3 Circuit-G520 High
High Speed CAN Communication Bus
High Speed CAN Communication Bus Performance
Control Module Communication Bus Off
Lost Communication With ECM/PCM "A"
Lost Communication With TCM
Lost Communication With Gear Shift Module "A"
Lost Communication With ECM/PCM "B"
Lost Communication With Anti-Lock Brake System (ABS) Control Module
Lost Communication With Instrument Panel Cluster (IPC) Control Module
Software Incompatibility With Transmission Control Module
Software Incompatibility With Anti-Lock Brake System Control Module
Invalid Data Received From TCM
Invalid Data Received From Gear Shift Control Module "A"
Invalid Data Received From Anti-Lock Brake System (ABS) Control Module
"A" Camshaft Position Slow Response, Bank 1
"B" Camshaft Position Slow Response, Bank 1
"A" Camshaft Position Slow Response, Bank 2
"B" Camshaft Position Slow Response, Bank 2
Mass or Volume Air Flow "B" Circuit Range/Performance
Mass or Volume Air Flow "B" Circuit Low
Mass or Volume Air Flow "B" Circuit High
ISO/SAE reserved
Fuel Pump Module Control Circuit/Open
Fuel Pump Module Control Circuit Low
Fuel Pump Module Control Circuit High
Cold Start Idle Air Control System Performance
Internal Control Module Fuel Injector Control Performance
Bank1, Lambda Correction Catalyst Center Control Limit Reached
Bank3, Oxygen Sensor Correction Behind Cat Lean Control Limit Exceeded
Bank3, Oxygen Sensor Correction Behind Cat Rich Control Limit Exceeded
Bank4, Oxygen Sensor Correction Behind Cat Lean Control Limit Exceeded
Bank4, Oxygen Sensor Correction Behind Cat Rich Control Limit Exceeded
Bank3-Probe1, Voltage Too Low/Leakage Air
Bank4-Probe2, Voltage Too Low/Leakage Air
Fuel Rail Pressure Sensor Inappropriately Low
Fuel Rail Pressure Sensor Inappropriately High
Fuel Rail Pump Control Valve Stuck Closed
