Old February 8th, 2007, 09:08   #1
tomo366
TDI Lifer
tomo366's Avatar
Default Windshield Washer........
06 Jetta Package2
Top Up windshield washer fluid light came on yesterday........
I filled it . This AM the warning light came on again......
I topped it when I got to work and ended up with a big puddle on the ground. I don't know if the tank split or a hose froze and broke.....
I was using -20 WW Fluid....
It has been in the teens here for several days
Looking at the Bentley the front Bumper cover has to come off to replace.
Car is under warranty although I hate having to take it in.......
Anyone else have this problem??
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old February 8th, 2007, 09:10   #2
SVTWEB
I have the same issue on my car....
2010 Jetta TDI 6-Speed
2001 BMW R1200C Phoenix; 2012 BMW K1600GTL
2014 Ford F150 Raptor; 2017 Ford Escape
SVTWEB is offline   Reply With Quote
Old February 8th, 2007, 09:33   #3
tomo366
TDI Lifer
tomo366's Avatar
Eric, I remember yours from when we installed your Skid Plate......Was that a bad Tank??
Old February 8th, 2007, 12:04   #4
sinneD
sinneD's Avatar
tomo- i have the same problem here today too.
Dennis
2006 Jetta TDi NAV, 5M ESP Reflex Silver PKG 2
Other steeds in the stable: Y2K F250 SC LB 4WD- 1985 Golf 1.6NA 1980 FJ40
Other vehicles we have loved: 1969 VW Bus, 1974 VW Bettle, 2004 VW Jetta TDi, 1992 Exploder, 1959 BMW R69US w/'53 Steib
sinneD is offline   Reply With Quote
Old February 8th, 2007, 12:38   #5
AlexR
Had the same problem on wife's Passat. it was a small plastic connector holding the tube to the tank. From what I recall it was a quick $15 dealer fix.
AlexR
2006 Jetta - Pkg 2, Black/Anthracite, 5spd
AlexR is offline   Reply With Quote
Old February 8th, 2007, 17:44   #6
GregoryB
GregoryB's Avatar
Fuel Economy: 42 +or- fun factor
My problem was the crap plastic hose where it bends near the passenger side front hood hinge. The hings had partially sheered the plastic tube and the wires going to the heaters on the Window Washer nozzles was severed. - Advise dealer to fix at next service. Replace plastic hose with rubber fuel filter line sold by the foot at the dealership. Also armour the piece near the hinge with split plastic conduit protector and zip tie together.
Friends may come and friends may go, but enemies accumulate.
2006 Jetta TDI, Platinum Grey, DSG, Pkg.2, Protection Package,
Aspherical Mirrors, Clear Marker Lenses, Euro Tails, Euro Switch,
Rear Fog, Volk-L Bluetooth, VAG-COM HEX-CAN USB, Charged Particle Beam Generator 12w.
GregoryB is offline   Reply With Quote
Old February 8th, 2007, 19:10   #7
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
I too had a problem with the hose breaking at the hood hinge...But
that is not your problem... Look for a rubber? plug in the resevoir
side that has come loose or broken. This might be where the headlight
washer outlet goes... or not. Sorry I don't have a better answer!!
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old February 9th, 2007, 07:17   #8
SVTWEB
Tomo, I'll be at Johns Tomorrow.. just an FYI
Old February 9th, 2007, 07:28   #9
tomo366
TDI Lifer
tomo366's Avatar
I hope I can come, need to get it on the lift......
Work though!! 77 Days until retirement!!
Old February 9th, 2007, 18:00   #10
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
As Greg pointed out to me, my assembly is cracked, and on its way to self destruction.
Hopefully I can make it to late April before I have to perform surgery on the beast.
Thanks Guido!
05.5 MKV TDI,Euro Tails, Rear Fog, Aspherical Mirrors-04.5 PASSAT TDI, Aspherical Mirrors
Tim Birney is offline   Reply With Quote
Old February 10th, 2007, 12:06   #11
jccgmn
I had a similar problem. Last weekend, on my way back from Hinkley I cleared my windows and the light came on. I got home and it took a gallon to fill. The light went out, but since than, I haven't had enough flow to clear the windshield.
My car is going back in next week for a new heater fan and gear shift knob. Maybe I will have them take a look at this also.
John, 2006 Wheat TDI, 5 Spd Manual
jccgmn is offline   Reply With Quote
Old February 13th, 2007, 09:23   #12
tomo366
TDI Lifer
tomo366's Avatar
anyone else??
Old February 13th, 2007, 09:27   #13
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
Oh yeah the '65 'cuda has the same problem. I sure hope the stealer will help me!
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old February 13th, 2007, 17:29   #14
WalletBoy
Angry
This happened to me today as well! We have been experiencing cold temps here in Michigan over the last few weeks. Today we were supposed to get hammered by a snowstorm so I picked up two bottles of blue. When I left work I topped off the tank and started on my way. I noticed that when I was using the washers there was only a low pressure stream coming out of the pissers. At first I thought the pump had lost it's prime so I just kept them on for a few bursts. Then the low fluid light pops on! I pulled over and popped the hood and sure enough the line had snapped at the passenger side hood hinge. Why did they made this piece out of hard plastic?! My guess is that the line has some play to allow the hood to open and close, as when I pulled on the broken line to get some slack it came out quite a bit. It appears that it was frozen somewhere on the hood side, and I opened my hood it snapped that piece right in half. Right now I made a quickie repair using a small piece of vacuum line and a couple of zip ties. That really gets my goat. Hopefully this gets remedied with an upgraded design. Any idea on how long it takes the dealer to replace this part?
WalletBoy is offline   Reply With Quote
Old February 13th, 2007, 18:27   #15
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
Thumbs up
You just made the only upgrade that part will ever see. When it gets warmer, go back under the hood and make it pretty.
Page generated in 0.16413 seconds with 9 queries
[Output: 124.97 Kb. compressed to 103.53 Kb. by saving 21.44 Kb. (17.15%)]
