Old February 5th, 2007, 20:41   #1
meatwagon
Default Where to buy diesel anti gel or Diesel 911 in vancouver, canada?
OK my car died on me today it wasnt the fuel that was empty because when i turned it over again, the gauge moved. So im thinking its gelled in the tank, and because i got it going again, it ran fine but when i stopped the car again it was struggling while iddling, so i just left it at my house. I went to lordco. they were all out canadian tire had nothing or knowledge of anything. Any pointers? thanks jamie
2001 Jetta TDI
225,000 KMS
meatwagon is offline   Reply With Quote
Old February 6th, 2007, 16:02   #2
McBrew
McBrew's Avatar
Fuel Economy: 54/50/44 (usually running B100)
Any truck stops around? What about tractor supply stores?
Personally, I would want to know more about what is going on. It could be a clogged fuel filter, gelled fuel, ice, or any number of other things.
-McBrew
2011 Subaru Outback 2.5i Premium. Lineartronic CVT trans.
Still have 3 TDIs in the family fleet.
McBrew is offline   Reply With Quote
Old February 6th, 2007, 16:08   #3
DubbedDiesel
You may need a new battery man. All us guys in the A3/B4 section have flooded the forum with recommendations for a new battery. Take a look for yourself.
If you don't think the battery is doing this, how new are your fuel injectors? Is your car smoking while trying to start or did it smoke like crazy that one time it did start??
I hope you're running the correct synthetic oil. If you aren't that could be your problem too....
DubbedDiesel is offline   Reply With Quote
Old February 20th, 2007, 18:08   #4
meatwagon
i dont recall any smoke, I added some anti-gell and got 610 km on that tank, (seems whenever i fill up its always around 50L) wich is way better than the 550km i was gettin from the last 3 tanks. As for the battery, never really though about that! As for the fuel injectors, i have no idea. How do i check them? I think it may also be a clogged intake? I have to save up my $$ 1st to get it checked out. Thanks for the input,
2001 Jetta TDI
225,000 KMS
Old February 20th, 2007, 18:22   #5
doc_m
doc_m's Avatar
TDI(s): None
should not be gelled as it is 5 C out right now, probably bad fuel.
Do work on cars like intake cleanings, nozzle swaps, brakes etc.... Hex usb + can now
2009 Jetta TDI Comfortline with ESP and beige leather interior. Evolution Imports Osiris Skidplate.
So far just over 10,200 kms on it
doc_m is offline   Reply With Quote
Old February 21st, 2007, 22:25   #6
meatwagon
how can teh battery cause pour fuel efficientcy?
2001 Jetta TDI
225,000 KMS
Old February 21st, 2007, 23:13   #7
doc_m
doc_m's Avatar
TDI(s): None
you busy on march 3rd? I am having a gtg we can look at it closer then if you have not figured i out by then.
Old February 24th, 2007, 19:00   #8
DubbedDiesel
Any luck on this? Just curious as to whether this worked out or not. Did you get a hold of a tech with VAG and run the codes?
For the fuel injectors, pull them out and do a visual. Easiest way. If they're caked with carbon, you need new ones. Inspect all fuel lines between injectors and running off the fuel filter for leaks or damage. 610 kms a tank is low....a clogged intake can cause it as well a cracked downpipe.
Bad fuel was also a good suggestion...did you drain and fill?? How'd the battery test score?
Old February 26th, 2007, 01:02   #9
meatwagon
welli did add antigels, and i got 610 kms, on that tank, im going to a meet next sat so hopefully someone will be able to help me out and test things... ill keep you posted, thanks for the interest!
2001 Jetta TDI
225,000 KMS
Old April 27th, 2007, 18:35   #10
meatwagon
hey there after 2 tanks full of b40 bio diesel, i got 665 on my last tank, thats was with around 52L, i still want to get a new air filter and fuel filter as well. ill keep yous posted on my progress, thanks again, Jamie
2001 Jetta TDI
225,000 KMS
Old April 28th, 2007, 19:42   #11
VW Petrolero
How is your Intake Manifold ?.I think it needs to be cleaned.
Later
Tony
Andes Auto is back in Richmond B.C.
(604) 401-2130
TDI Friendly Repairs.TBs & Vag-Com .
VW Petrolero is offline   Reply With Quote
Old May 13th, 2007, 11:18   #12
meatwagon
Yeah, i have no idea if its clogged, Never really attemped to check, last time i was at your shop you said 700km is avg for those cars.. Can you give me an estimate on how much it would cost to clean it out? Thans tony..
Jamie
PS, last tank got 695lm/ 52L
2001 Jetta TDI
225,000 KMS
Old June 5th, 2007, 00:02   #13
meatwagon
just an update, still running the b40 bio, this tank drove to whistler and back, then langley and back, rest was city, i hit 755kms and filled up 52L, things are looking better, changed the fuel filter too, slowly but surely things are looking good!
2001 Jetta TDI
225,000 KMS
Page generated in 0.13058 seconds with 9 queries
[Output: 106.62 Kb. compressed to 88.17 Kb. by saving 18.45 Kb. (17.30%)]
