Old January 25th, 2007, 10:31   #1
straightliner
straightliner's Avatar
TDI(s): 09 TDI Jetta
Default odometer roll back?
A family member looked at a used 06 tdi jetta that i referred him to and during our discussion we noticed differences in the odometer from when i originally looked at the car.Is it possible to turn a digital odometer back?Or did i just make a error from the original inspection.
chris
straightliner is offline   Reply With Quote
Old January 25th, 2007, 10:34   #2
compu_85
Gadget Guy
compu_85's Avatar
I know it is VERY easy to do on the older cars with the right tools. Not sure about the new generation of clusters, though.
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
compu_85 is online now   Reply With Quote
Old January 25th, 2007, 10:55   #3
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
The controllers store the Miles/Kilometers to within 10miles/16 Kilometers.
Replacing the display, properly, the tech would invoke that memory and get the new OD close to original.
Replacing the display improperly (illegally) you could possibly get any numbers you wanted.
The original miles on the car should still be stored in one of the controllers.
05.5 MKV TDI,Euro Tails, Rear Fog, Aspherical Mirrors-04.5 PASSAT TDI, Aspherical Mirrors
Tim Birney is offline   Reply With Quote
Old January 25th, 2007, 12:20   #4
dschein
TDI(s): 06 Jetta
Vag-Com does have a option to display the miles logged - check under applications.
Original owner, former driver and still the mechanic of 2006 Jetta TDI
dschein is offline   Reply With Quote
Old January 25th, 2007, 12:29   #5
weedeater
Fuel Economy: 54/43/38
It's possible but only if you have the right electronic tools. I'd like to think that they are not that common.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old January 25th, 2007, 20:11   #6
GoFaster
Moderator at Large
Unfortunately, the tools to change odometer readings are all TOO common ...
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old January 25th, 2007, 20:13   #7
MOGolf
MOGolf's Avatar
Not applicable for an '06.
MOGolf is offline   Reply With Quote
Old January 26th, 2007, 09:45   #8
dschein
TDI(s): 06 Jetta
Works on my 06!
Old January 26th, 2007, 10:26   #9
Harvieux
Harvieux's Avatar
Yes, you can read the current mileage via Vag-com on the A5's and is in kilometers stored in the ECU. The cluster could be changed but, the ecu would give it's true mileage away. The ecu would have to be changed (new one) in order to pull this off and I need not tell you how cost prohibitive that would be, right? There was a Vag-Dash unit awhile back that was able to change the cluster mileage on the A4's and was forced from the market by the power's to be in Europe. Not sure if this unit would have worked on the A5's. Anyway you slice it, it's a felony, if caught. So rest assured, I doubt many would have the capability of performing such a task. Later!
Harvieux is offline   Reply With Quote
Old January 28th, 2007, 03:31   #10
2004STARWARSTDI
2004STARWARSTDI's Avatar
Post
According to VagCom web site the odometer can NOT be rolled back!
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old January 28th, 2007, 06:51   #11
Harvieux
Harvieux's Avatar
On the ALH's, the odometer can be rolled foward via Vag-com if the cluster has <100 miles. I don't know if you could go down from 100 to say, 25. Example being if you purchased a new or rebuilt cluster, you can set the mileage/kilometers forward to any number one time and one time only. I don't know if this is applicable with the PD's from 04 to present. The Vag-dash unit I am referring to above was a unit out of Germany and it was able to change cluster mileage, retrieve key codes, etc. The authorities put a stop to the mileage changing capabilities of the unit and they are no longer able to perform such a task.
BTW, May I respectfully ask how you achieved 54 mpg with an 04 tip auto? Later!
Old January 28th, 2007, 09:45   #12
GoFaster
Moderator at Large
... with VAG-COM.
That doesn't mean there aren't other ways to do it with some other software that isn't necessarily legal ...
Brian P.
Page generated in 0.13647 seconds with 9 queries
[Output: 107.37 Kb. compressed to 89.76 Kb. by saving 17.61 Kb. (16.40%)]
