Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Old January 15th, 2007, 15:20   #1
dukelukas
Default Ultra Low Sulfer Fuel makes injector pumps fail?
My 2000 Jetta won't start. It caughs and sounds like it has startes for a fraction of a second, then it just spins... Took it to the mechanic and they can't figure it out yet. It seems like it might be the injector pump. Do they really fail in less than 100k mi? I read a little about the Ultra low sulfer fuel that has been in pumps since September and people say it has less lubricative properties. Could this make a pump prematurely fail? Should we be using an additive to avoid future problems from the ULS diesel?
dukelukas is offline   Reply With Quote
Old January 15th, 2007, 15:42   #2
n1das
n1das's Avatar
Fuel Economy: 51/47/42
Question
From your "newbie" status I have to first say Welcome to TDIclub!! There are plenty of people here that can help.
1. Did you check the anti-shudder valve to make sure it's not sticking shut in the closed position? If it's stuck in the closed position, no air will get into the engine, resulting in a no-start condition.
2. Could also be fuel-starved due a leak somewhere and the pump lost its priming. Did you check the clear fuel line between the fuel filter and the injector pump? The fuel line should be full of fuel and not air. It's OK to see a 1/2" to 1" bubble in the line when the engine is stoppped.
The injector pump can last the entire life of the engine provided only uncontaminated and clean DIESEL fuel has been used that meets the ASTM specs for diesel fuel. OTOH, the pump can be ruined in a very short time if severe water contamination occurs (water in fuel) or somebody fueled the car with gasoline or something else by mistake. In the worst case scenario, a pump can be ruined in a matter of minutes. This is why TDIclubbers recommend fueling up only at high-volume truck stops and busy gas stations along major routes...because they do lots of diesel business and the fuel will be the freshest in the region because it's constantly being replaced often.
I don't think your injector pump is bad though. I also think you need to find a mechanic that knows something about TDIs. Don't blame the injector pump until the other obvious stuff has been checked first. The best thing to do is find a TDIclub guru in your area that can help.
I don't think ULSD has anything to do with your no-start/hard-start problem. I've been using ULSD for several months without problems. My 2002 Golf "only" has 237k miles on it and it's still on its original injector pump. And YES, you should be using an additive to help increase lubricity, get rid of any water, and prevent the possibility of future problems, at least until more is known about the long-term effects of ULSD.
Good luck.
David Sterrett, N1DAS
2002 GOLF, 361k | RC4b & other mods = stomp 'n go fun!
2005 ATD PD100 JWagen, 102k
2010 JSW TDI, 2k
n1das is offline   Reply With Quote
Old January 15th, 2007, 15:47   #3
blurfocus
TDI(s): 2001 Jetta
You can mix biodiesel with ultra low sulphur diesel to improve its lubricity. Reportedly, as little as 2% biodiesel mixed into ULSD can restore the lubricity to that of high-sulphur diesel.
These links have some useful information. I don't know the answer to your injector pump question. Most of what I've read only talked about problems with non-synthetic hoses and seals (both from ULSD and biodiesel). Your VW shouldn't have any non-synthetic hoses or seals (according to what I've read anyway).
http://en.wikipedia.org/wiki/Ultra-low_sulfur_diesel
http://www.biofuelsforum.com/using_b...arranties.html
blurfocus is offline   Reply With Quote
Old January 15th, 2007, 17:45   #4
dukelukas
Thanks for the help. So I need an addative... Which one should I use? As for a mechanic, how do I find a Guru in my area? I have the car at a pretty good place; they specialize in VW's, though they admit themselves that they don't have extensive experience with the TDI's.
I do know that the glow plugs were soaked with fuel. So it seems unlikely that the pump is unprimed from a leak. But an air starved engine (from a stuck shudder valve) would have a lot of fuel in the cylinders, right?
Thanks so much for the help and I'm excited about this forum because I have always had cars (gasoline) that I could fix myself and perhaps with the help of you all I can learn to master the turbo-diesel too...
Old January 15th, 2007, 17:59   #5
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
While there has been some information to suggest that there may be an issue, it is far from proof and frankly I don't believe it myself.
I expect many people are going to blame ULSD for all kinds of problems and may well miss many real problems. Don't fall into that trap and don't assume that there is no chance of the problem either. Just do the usual testing and repair. If you then think it was fuel have an independent lab test the old parts.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old January 15th, 2007, 18:00   #6
volks_r_us
volks_r_us's Avatar
I use and sale ELF TOTAL
http://www.lubadmin.com/upload/produ...ang_1/4011.pdf
volks_r_us is offline   Reply With Quote
Old January 15th, 2007, 18:07   #7
40X40
Experienced
Fuel Economy: 42,with a best of 47
If the shop doesn't have vag-com get it to someone who does. It is
not a ulsd problem, but could be a fuel problem.
Change the fuel filter and check the anti-shudder valve. Vag-com will
tell you if the glow plugs are working.
At the TOP of this page there is a Vag-com list. PM some of the people
there for help.
HTH
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// You still cannot magnetize silver.// If you admire K. Marx, do not include ME in your WE// If you were the only entry, there wasn't a race.// Grammar and spelling really are important.// Typical drivers can't.//Sigs with ads are tacky.
40X40 is offline   Reply With Quote
Old January 15th, 2007, 18:12   #8
catmandoo
are the glow plugs working,been pretty cold out there lately.
catmandoo is offline   Reply With Quote
Old January 15th, 2007, 18:42   #9
gt
Wink Fuel Additives
Bosch recomends Stanadyne, the dealers also sell it, I know you did not want to hear that! I do believe you should run it all the time. I have had to replace pumps as early as 53,000 miles. You should not run diesel & switch to Bio often or you will be replacing seals. I would agree with anti-shudder valve being stuck may be the problem. gt
gt is offline   Reply With Quote
Old January 15th, 2007, 18:46   #10
cage
What about ashless 2 cycle oil?
I'm still running old diesel since my station doesn't have ULSD yet but I put lawnboy ashless in every once in a while. It comes in little green cans. I put the whole can in and fillup.
I do it a few times a year but once the ULSD comes out I will do it more often.
cage is offline   Reply With Quote
Old January 15th, 2007, 19:03   #11
n1das
n1das's Avatar
Exclamation
It sounds like a stuck anti-shudder valve or dead glowplugs. But I see you're in southern CA (Los Angeles) and the weather should be warm enough for the ECU to not need to use the glowplugs before a cold start.
Have you checked the anti-shudder valve to make sure it's not stuck in the closed position and moves freely?
And as others have pointed out, ULSD has nothing to do with your problem.
Good luck.
2010 JSW TDI, 2k
Old January 15th, 2007, 19:08   #12
n1das
n1das's Avatar
Cool
Start here by looking in the "Trusted TDI mechanics by state" thread:
http://forums.tdiclub.com/showthread.php?t=130044
2010 JSW TDI, 2k
Old January 15th, 2007, 19:08   #13
Canadian_Grizzly
Canadian_Grizzly's Avatar
TDI(s): 02 Jetta TDI
Snakeoil dealers are going to do well in the near future. ULSD has been used for years in other parts of the world. All these additive junkies will flog their snakeoil when this better quality fuel is absolutely fine. Should every post now begin with ULSD killed my pump, Maf, intake, turbo, glowplugs, cam followers etc... I'm just not buyting it!
My 2 cents...
Byron
Driver Found!
"There is lots of work to be done, if we are to achieve the kind of society people have the right to expect." Tommy Douglas
Having trouble with limp mode... Troubleshooting Low Power
Having trouble searching? Read this thread on advance search in forum http://forums.tdiclub.com/showthread.php?t=133579
Canadian_Grizzly is offline   Reply With Quote
Old January 15th, 2007, 19:18   #14
n1das
n1das's Avatar
Cool
Have a look at this thread to check the anti-shudder valve:
http://forums.tdiclub.com/showthread.php?p=1214327
Good luck.
2010 JSW TDI, 2k
Old January 15th, 2007, 20:43   #15
dukelukas
Thanks for all the help. Since there is unanimous opinion that it's not the ULSD, I will stop blaming myself for not using an additive. But I will start using one now, and I promise I will never start another thread blaming the ULSD (though at least it seemed to elicit many responses).
I do not think that it's the glow plugs because it is starting, for about 1 second, before it dies and just cranks over. So it is firing. Then I wait about 15 seconds, try again, and it does the same thing. Starts very briefly, then dies and just cranks (though at what seems like a faster rate, like it has no compression). This strange symptom has been quite repeatable for me and the mechanic.
I do not know if the mechanic where I have it has checked the anti-shudder valve, but I will see to it that he does. I do know that he has the electronic equiptment and has been scanning it for codes, and coming up empty handed.
If it does turn out to be the injector pump, do I really have to pay 900 bucks for a rebuilt one from the dealer? That's what they quoted me....
I drove by the place in my area suggested in the "Trusted TDI mechanic" thread and it didn't look like a place I'd take this car... What do you guys think about dealers??
Thanks again for everybody's helpful comments.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.12439 seconds with 9 queries
[Output: 124.39 Kb. compressed to 103.30 Kb. by saving 21.09 Kb. (16.96%)]
