Mardak
Hi guys,
I'm installing a 1Z TDI (mechanical) into an 82 Rabbit Pickup and have a question regarding exhaust manifolds. I will be running a VNT-20 turbo and would like to know what available manifolds will fit back there. I'd like to run a gasser A1 intake manifold. Am I wrong to assume any 8v turbo manifold will work (ATP, etc., which iirc mount the turbo plumb on the back of the manifold), or will it require one that points down slightly?
Will the turbo be oriented correctly, or will it need to be "clocked"?
Will the stock 3 hole TDI manifold work if I make an adapter plate? (again - fitting specifically into an A1 chassis)
Also, what style flange does the VNT-20 use (exhaust) - a T3 style?
I don't have the turbo in front of me yet, so I can't figure this out for myself at the moment, but I'd like to source all the parts I need so the swap will go quickly.
Thanks!
Mark.
75 Scirocco
82 Scirocco
82 Caddy - mTDI swap in progress
Thanks!
Mark.
75 Scirocco
82 Scirocco
