SUNRG
- Joined
- Oct 19, 2003
- Location
- Roanoke, VA
- TDI
- None currently. Previously owned 04 Golf TDI & 05 Passat GLS Wagon TDI
Wear Rate Comparisons - all expressed in ppm / 1000 miles
G52 = OEM Factory Fill G52, MTL = Redline MTL
Fe: G52 - 3.41 | MTL - 5.83
Cu: G52 - 0.93 | MTL - 1.27
Al: G52 - 0.07 | MTL - 0.22
Pb: G52 - 0.02 | MTL - 0.16
The particle counts show that there was more stuff in the Factory Fill fluid after 43k than there was in the MTL after 18k, but in terms of "rates of wear metal production" G52 use in my engine correlated with significantly lower rates of wear than MTL. Cu: G52 - 0.93 | MTL - 1.27
