Old January 4th, 2007, 14:23   #1
MalcolmBurke
TDI(s):
Question Reset transmission ECU adaptation A5 DSG ???
I know on the A4 it is possible to reset the ecu adaptation to ones driving by holding the pedal and turning the key on and off. Does this work as well on the A5 DSG? I would like to reset the trans ecu info to stock. thanks
MalcolmBurke is offline   Reply With Quote
Old January 4th, 2007, 14:40   #2
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
#1 Trip to the Dealer, they can possibly do a reset
#2 Requires a VAG-COM, http://forums.vwvortex.com/zerothread?id=2996538
#3 Remove - Terminal of Battery for 10 minutes or more, remove + Terminal...., you are on your own on this one.
05.5 MKV TDI,Euro Tails, Rear Fog, Aspherical Mirrors-04.5 PASSAT TDI, Aspherical Mirrors
Tim Birney is offline   Reply With Quote
Old January 4th, 2007, 17:29   #3
MalcolmBurke
TDI(s):
Tim, Vortex says removing the battery term doesn't work. So VAG-COM is the only choice besides the stealer?
Page generated in 0.10276 seconds with 9 queries
[Output: 53.95 Kb. compressed to 48.68 Kb. by saving 5.27 Kb. (9.77%)]
