Old December 27th, 2006, 10:25   #1
6speed
Default AHU block, ALH cylinder head?
Just wanted to know if an AHU block will mate to a ALH cylinder head? It's a long shot, but I don't have both next to me to compare.
I'd like to build a hybrid engine with the later internals in an earlier block to install into a vanagon.
6speed is offline   Reply With Quote
Old December 27th, 2006, 12:33   #2
vwmikel
vwmikel's Avatar
The ALH head isn't going to fit right up to the early block.
vwmikel is offline   Reply With Quote
Old December 27th, 2006, 12:48   #3
BleachedBora
BleachedBora's Avatar
I have a new complete cylinder head for an AHU--not the cheap Spanish kind either $895 shipped.
Cheers,
-BB
BleachedBora is offline   Reply With Quote
Old December 27th, 2006, 13:44   #4
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
No 6speed but if you remove the crank end pully from a mk4 bottom end and refit it to the pd 130hp bottom end it will fit your new head.
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old January 20th, 2018, 20:42   #5
Lenard
Fuel Economy: Managing 44mpg with .220 nozzles, on stock turbo and tuned for .208s lol
Whoa explain more? What's this Frankensteining I like the sound of
1998 Jetta AHU 5 speed SOLD @240Kish
2005 Jetta BEW auto. SOLD @208495K exactly.
1983 Jetta Diesel Coupe 4 speed. SOLD at ? Miles
1997 B4 Passat 1Z 5 speed. Mileage? Current diesel toy
Lenard is offline   Reply With Quote
Old January 25th, 2018, 23:11   #6
Mongler98
Maybe things changed since 2006! i never heard of any though, heads are block specific but now we have CNC machines and better welders and some people making custom heads so i guess anything is possible after 12 years
Old January 26th, 2018, 03:42   #7
senso
I got the idea that you could grab a PD150 shortblock and slap a VP head with some mish mash of pulley matching and using the accessory bracket from the VP into the PD.
That or grab the pistons and rods, sputerred bearings, bore your VP block to accepth the PD pistons and gain a bit more CC and then use the rods and bearings and you have an engine with internals a lot better than the stock ALH.
senso is offline   Reply With Quote
Old January 26th, 2018, 04:35   #8
Yucca
If you use PD bottom end you have to change trigger wheel.
Yucca is offline   Reply With Quote
Old January 26th, 2018, 22:20   #9
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
I think jimbote put an ALH head on a BHW if you wanna look him up.
2003 Jetta TDI - 11mm IP, R520s and FMIC from the Red Death, HE221W (shooting for 26PSI), 1.8T pancake, DIY 3" OMI, still working on the DIY tune... its a learning process.
1996 Passat TDI - "Red Death" RETIRED. Had: Malone stg 1, 11mm IP, R520s, GT15/17 hybrid, FMIC, ETC
1997 Passat TDI wagon - Running donor or beater for sale, rough body
ketchupshirt88 is offline   Reply With Quote
Old January 27th, 2018, 14:43   #10
[486]
TDI(s): 02 golf ALH
ahu block and alh head, the issue is the oil drains
you can weld them up to the right size for the AHU head gasket
thinking on it further, if the only difference is the big rectangular oil drain, you could get a tube turned to press fit in the head up where the drain is round, JB weld it in there and have it slip fit and extend down into the block. Make sure to run a really unrestrictive CCV system and it might work. Oh right, vanagon, they run the motor just about on its side... Never mind.
ETA: or maybe run an o-ring groove at the bottom of the tube to seal it in the block
I've got an AHU bare head kicking around, but shipping'd be a tremendous pain. I think I got it thinking I'd convert a 1.6D to a DI motor for whatever dumb reason.
[486] is offline   Reply With Quote
Old January 28th, 2018, 23:06   #11
turbovan+tdi
turbovan+tdi's Avatar
I've done an ALH head on a BEW short block, its not that much extra work.
Old January 31st, 2018, 07:46   #12
Franko6
Why would you want to do that? AHU-ALH? Just because you can doesn't mean you should.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old February 7th, 2018, 17:28   #13
turbovan+tdi
Why not? We do lots of things we shouldn't do and they work either well, so so or goes bad quickly,
Old February 7th, 2018, 18:18   #14
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Theoretically you would have two vacuum pumps as well.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old February 7th, 2018, 23:55   #15
[486]
TDI(s): 02 golf ALH
Slap a distributor in there and run spark plug wires to the glow plugs
just to confuse people
not like you really need the GPs on a direct injected motor above 0F anyways
Page generated in 0.16195 seconds with 9 queries
[Output: 125.29 Kb. compressed to 104.05 Kb. by saving 21.24 Kb. (16.95%)]
