Old December 21st, 2006, 14:40   #31
Stevestyle67
Fuel Economy: 45-46 mpg lifetime
http://www.coolingmist.com/pagedispl...ure_key=diesel
there are sites all over
SOLD 2003 Jetta GL TDI. 5-Speed
1972 Malibu Convertible. Carolina Blue.
Stevestyle67 is offline   Reply With Quote
Old December 21st, 2006, 15:02   #32
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
This mod is ok for the big boys Cummings etc but to impractical for our tdi's.
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old December 21st, 2006, 15:59   #33
fishmando
fishmando's Avatar
perhaps... but VortexNL is using it and throwing down somthing like 500 lb/ft too
fishmando is offline   Reply With Quote
Old December 21st, 2006, 16:43   #34
pegbox 7
Fuel Economy: 48.6
The car in the video uses it only for cooling purposes as the massive increased power from the NOS/Propane mix causes a huge rise in temperature.
You have to be very careful with any form of water injection that it atomises correctly. Hardly any spare room in there for water droplets...
Be careful, choose a really good quality spray jet - and the results can be excellent
pegbox 7 is offline   Reply With Quote
Old December 21st, 2006, 17:15   #35
spoilsport
Fuel Economy: 53/46/40
Isn't the VW Rally TDI using water injection?
2000 Golf 5M -RC2/3 Sprint 520 Kerma 1" LIFT!!
spoilsport is offline   Reply With Quote
Old December 21st, 2006, 22:01   #36
weasel
Deactivated Member Account
TDI(s): None.
Making your own kit isn't hard to do at all. I made my own system before on my old TD and it worked rather well. I used a nozzle from an oil furnace ( Make sure its a stainless steel, solid cone pattern and the lowest flow they have ) the pressure switch I got from Napa ( adjustable ) and the pump is an agricultural chemical sprayer pump. The tank can be just about anything you want. After that its a matter of adjusting the switch to come on when you want. ~ 10psi is usually good. Tons of info on the net about various DIY kits. I ran 50/50 water meth in the winter and plain distilled water in the summer. Btw, if you use w/w fluid, use it straight up. Its already about 50/50 mix.
weasel is offline   Reply With Quote
Old December 22nd, 2006, 01:55   #37
VortexNL
VortexNL's Avatar
Fuel Economy: 9.3L every 100 km
Default Here are some pics of my install....
Golf IV TDI ???hp with ???NM of Torque @ 5500Rpm's... also see my sounddomain page at www.sounddomain.com then search 4 me.
VortexNL is offline   Reply With Quote
Old December 22nd, 2006, 02:13   #38
pegbox 7
Fuel Economy: 48.6
Hi Vortex, car looks awesome, very neat under bonnet install !!
Where abouts do you actually have the water/meth injection jet located on your car as i cant see it from the photos..
Old December 22nd, 2006, 03:28   #39
VortexNL
VortexNL's Avatar
Right after the intercooler... you won't see it from the pics because its on the back side. I do need to realocated my temp and pressure sensor to get more power out of the system.
Old September 8th, 2007, 10:46   #40
orion2.0
orion2.0's Avatar
Fuel Economy: 50mpg
Default water/methanol injection question
Ok well i have the opportunity to jump in on a group buy of water/methanol injection kits from snow performance. I am seriously considering getting one.
I am wondering if anyone on here has used water/meth injection with their TDI (or know someone who has)... I am curious to hear what kind of gains people have seen, or related problems/issues...or any advice at all regarding this. thanks.
orion2.0 is offline   Reply With Quote
Old September 8th, 2007, 12:01   #41
orion2.0
orion2.0's Avatar
Fuel Economy: 50mpg
no thoughts eh? Well I guess I'll just have to get one anyway...then I can let you all know if the results are worth while.
Old September 8th, 2007, 12:44   #42
drkblujetta
drkblujetta's Avatar
Knew a local guy with meth injection on his TDI.
He ran the same times racing in cold weather (no meth) as he did in hot weather(w/meth).
But he sold his kit, it was really useless with his stock turbo & fueling.
Really its meant to cool things down, some notice an increase in HP (only the bigger turbo and fueled TDI's around)
http://forums.tdiclub.com/showthread...meth+injection
I would invest in other upgrades before that set-up........(nozzles,turbo,chip/tuning box etc......)
Another Drkblujetta (ALH) ..
drkblujetta is offline   Reply With Quote
Old September 8th, 2007, 13:23   #43
devonutopia
devonutopia's Avatar
Mine seems cool enough with FMIC cooled intake temps. It never gets that hot anyway.
Jason - Skoda Fabia TDI project
http://www.youtube.com/watch?v=TOE4nbT5NGY 315bhp dyno run video of my car.
http://www.youtube.com/watch?v=8R5c496IG1Q Skoda Fabia GTB2260vk in-car acceleration video!
http://www.devoncardetailing.gb.net/
devonutopia is offline   Reply With Quote
Old September 8th, 2007, 14:03   #44
johnnloki
johnnloki's Avatar
TDI(s): 04 Golf TDI
Fuel Economy: 1100 km tanks, generally
The Rally Car has it, one or two of the Brits have it, Kerma seems to think they're a good idea. Everyone who doesn't have water/methanol seems to think it's a waste of time. They're designed with Turbo Diesels in mind- I'm really superised that they're not more popular/used.
johnnloki is offline   Reply With Quote
Old September 8th, 2007, 15:07   #45
shortysclimbin
shortysclimbin's Avatar
I would agree not the most useful for completely stock, but what are you running besides it? that should be a first question. then do I need the meth/h20 ink?
BTW- where is the group buy and what kit is it for? I may want one...
shortysclimbin is offline   Reply With Quote
Page generated in 0.17261 seconds with 9 queries
[Output: 123.78 Kb. compressed to 102.67 Kb. by saving 21.10 Kb. (17.05%)]
