Old December 20th, 2006, 19:38   #16
joevat
joevat's Avatar
TDI(s): TDI PD
post video again.
joevat is offline   Reply With Quote
Old December 21st, 2006, 02:44   #17
pegbox 7
Fuel Economy: 48.6
If I can find it from the net I will have to send it to one of you guys as i did last time..failing that i will look for my original posting...
pegbox 7 is offline   Reply With Quote
Old December 21st, 2006, 05:14   #18
VortexNL
VortexNL's Avatar
Fuel Economy: 9.3L every 100 km
Default I got the aquamist water/meth system on my 1.9TDI.
Its great and it works super.... lots more power... and torque... on my xtreemly tuned TDI it adds 45nm of torque and around 22HP... to 28HP.
And the EGTs are lowered...
Mark
Golf IV TDI ???hp with ???NM of Torque @ 5500Rpm's... also see my sounddomain page at www.sounddomain.com then search 4 me.
VortexNL is offline   Reply With Quote
Old December 21st, 2006, 08:53   #19
pegbox 7
Fuel Economy: 48.6
Sounds great - do you have any picks of the install ?
Old December 21st, 2006, 09:21   #20
Morse
Pegbox, if I'm wrong I apologize. I was thinking that car was running nitrous along with a propane system for added fuel. Nitrous alone on a stock car would do very little if anything because the lack of fuel on a stock car.
Sold.. Beetle - Kerma VNT20 kit, Kerma Race injectors, ARP headstuds, DG racepipe, EGR delete, Spec stage 3 with SMF, Autometer gauges, boost valve, walker muffler, cat delete, 3 bar map, metalnerd 2'' lift, 205/60/16 Michelin S8 tires
2000 Beetle auto. Hmm..
Kodiak 4500- Suncoast trans, efi live, semi wheels, custom paint, Deaver springs, etc.
69 Camaro/duramax diesel.. Motor by Fleece Performance, outlaw 10.5 chrome-moly chassis by Biven Race Cars, etc, etc..
Morse is offline   Reply With Quote
Old December 21st, 2006, 11:22   #21
DieselTweak
TDI(s): 02 Golf TDi
Wow, 22-28 hp is a really good power increase VortexNL. Do you run the water meth all the time or just when you want the extra umph?
DieselTweak is offline   Reply With Quote
Old December 21st, 2006, 11:33   #22
pegbox 7
Fuel Economy: 48.6
Yes it used Propane as well with the NOS, it was a bit of " everything chucked at it " kind of machine but it worked very well.
Some detailed picks of a water/meth install would be excellent..
Old December 21st, 2006, 11:38   #23
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
I've heard of water and methanol being sprayed on the intercooler to make it colder. Are you sure the system you're thinking of injects it directly into the intake? I would think that to be very dangerous in a diesel.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old December 21st, 2006, 11:43   #24
DieselTweak
TDI(s): 02 Golf TDi
yeah, you just drill and tap the intake and there is a nozzles that goes right there. They use water meth injection on all the diesel trucks for drag races and sled pulls. And is supposedly very safe. it cools things way down and adds power.
Old December 21st, 2006, 11:56   #25
Morse
Some guys run certain brands of windshield washer fluid as well.. The guys at snow performance can fill you in.. The kit I have is boost activated. You can preset it to spray at a given boost level.
Old December 21st, 2006, 11:58   #26
DieselTweak
TDI(s): 02 Golf TDi
so do you run the system all the time then, or usually? Or do you just use it when you want more power?
Old December 21st, 2006, 12:22   #27
scott_the_sock
Fuel Economy: High 30's City - 53 HWY & now going up
Originally Posted by joevat
post video again.
Looks like this is it:
http://media.putfile.com/5th-Gears-N...Wizards-of-NOS
2002 Silver Golf GLS TDI 5 Speed
scott_the_sock is offline   Reply With Quote
Old December 21st, 2006, 13:01   #28
Stevestyle67
Fuel Economy: 45-46 mpg lifetime
Turbo gassers use water injection as an anti-detonation device so that they can run up their boost to really high pressures. Sounds like most use a 50/50 mix of water and windshield washer fluid (Windshield washer fluid is a water, alcohol, and detergent mix), and the water injection pump is usually wired into the ignition to engage at about 4000 rpm or whatever rpm they choose. No need for water injection at lower rpm because the turbo is not producing enough boost to necessitate using it.
Thats the what i know about turbo gas engines, but i dont see why this wouldnt work/be beneficial do someone who wants to really turn up the boost on their turbo-diesel. Like a gas engine i would suspect the water injection would serve as an anti-detonation device so that boost pressure could be pushed to the limit. Sounds like some others here know of real world examples.
Ever notice your engine running really smooth on a misty or foggy day when the air is saturated with water?
SOLD 2003 Jetta GL TDI. 5-Speed
1972 Malibu Convertible. Carolina Blue.
Stevestyle67 is offline   Reply With Quote
Old December 21st, 2006, 13:21   #29
TheoSweden
TheoSweden's Avatar
TDI(s): A3Q,A4Q
A kit that is boost activated would be very nice to have! Any ideas how I can make my own?
Theo
TDI Project: VW Golf 1 - 83
Track/Ice racer: Audi A3 TDI Q - 02 ~280hp
Daily driver: Audi A4 TDI Q - 08 ~300hp
http://65.110.12.166/showthread.php?t=378371
TheoSweden is offline   Reply With Quote
Old December 21st, 2006, 14:29   #30
DieselTweak
TDI(s): 02 Golf TDi
Parleys Diesel is where I've been looking at possibly getting a water meth kit http://www.parleysdieselperformance....duct/SNO-47000 , it looks like a reservoir, pump, solenoid, a bunch of hoses and a couple of wires and crimp connectors. I don't know how hard it would be to get some of those part, but some aren't hard to find.
Page generated in 0.11384 seconds with 9 queries
[Output: 121.18 Kb. compressed to 100.48 Kb. by saving 20.70 Kb. (17.08%)]
