TDIFest 2013 Registration is now open!
Old December 20th, 2006, 07:45   #1
sleze
Fuel Economy: 30 MPG
Default trying to adjust my idle speed
I am trying to increase my idle speed from 860ish to 900 in order to get rid of an annoying rattle. I tried following the instructions from Ross Tech's website:
Idle Speed Adaptation (see your Repair Manual):
With engine warmed up, at idle:
[Select]
[01 engine]
[Adaptation - 10]
Enter channel 01
Enter an adaptation value between 124 and 132
[Save]
When I tried it, I got a security access required in the fields(no rpm, etc.). I started fiddling around (I used the login code that Jeff gave me when I got RC2 but that didn't work in the security button)and turn the car off and turned the ignition so the engine wasn't on but the computer was. I went back in and saw the rpm(0) as well as a couple other fields including the value of the adaptation, 0. I then turned the car on and the RPM went to 861 and the adaptation number stayed at 0. I put in 124 and it accepted it but nothing changed. I closed out and went back in and alluva sudden the value was 134. I changed it to 132 and it accepted but nothing changed.
I closed out of adaptation, turned the car off/on and went back in. Once again I got the security error. I then decided to run an autoscan and it threw the following code:
Address 01: Engine
Part No SW: 038 906 016 R HW: 028 101 198 2
Component: R4 2,0L EDC G000AG 6416
Coding: 0150034
Shop #: WSC 05314
1 Fault Found:
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 000 - -
Freeze Frame:
RPM: 2205 /min
Torque: 256.0 Nm
Speed: 59.0 km/h
Load: 52.9 %
Voltage: 14.21 V
Bin. Bits: 00101000
Absolute Pres.: 2468.4 mbar
Absolute Pres.: 1968.6 mbar
Readiness: 0 0 0 0 0
Question 1 - How do I set my idle speed without that security code?
Question 2 - Does the code thrown(I don't have a CEL) have something to do with my idle rattle?
2005 Shadow Blue Passat TDI Wagon GLS
RC2, Mufflerectomy, Ventectomy
-DECEASED-
www.thereheis.com
sleze is offline   Reply With Quote
Old December 20th, 2006, 15:04   #2
Uwe
Uwe's Avatar
Try this:
Select -> 01-Engine -> Security Access-16 -> 12233 -> Do It!.
If it's accepted, proceed with your adaptation.
If it's not, then your 2.0L EDC-16 isn't like the 1.9's we've seen.
-Uwe-
__________________________________________________ ___
VCDS®:
Satisfaction guaranteed or double your fault codes back!
Uwe is offline   Reply With Quote
Old December 21st, 2006, 17:54   #3
sleze
The security code worked - YAY!
The idle adaptation did nothing - BOO!
I am gonna take this discussion to the B5 forum now. Thanks for your help.
-DECEASED-
www.thereheis.com
Old December 25th, 2006, 09:25   #4
GetMore
Fuel Economy: 56.1/42.7/38.1
You may have to restart the program. I forget exactly how the whole thing goes, but if I try making changes but used the wrong code the program had problems. Just trying to reconnect didn't work. I may even have had to restart the computer. I forget exactly.
It just goes to show that if you don't know what you are doing you make more work for yourself. Unfortunately I don't remember exactly how it goes, so I never learn.
1997 Passat TDI, B.203s, Ventectomy, EGR mod, front and rear fogs, Dawes Device, Old Navy CCV filter, Neuspeed rear swaybar and front strut bar.
2010 Jetta Sportwagen, DSG, Nav, Pano, 9W7
GetMore is offline   Reply With Quote
Old December 28th, 2006, 20:46   #5
SilverGhost
SilverGhost's Avatar
Fuel Economy: 26 - 53 mpg
Originally Posted by Uwe
Try this:
-Uwe-
Hi Uwe,
I'll admit up front I'm too chicken to play with the other code and nuke my edc or engine.
I have played around a bit and there are other security codes for the PD's ecms. EDC16 will accept the 12233 code, but nothing seems to "unlock" and make changes. The other codes will let you change other settings but since I don't know what it means I left it alone. I found the codes in a german site that had a lot of the control modules and their functions broken down. MVB for darn near everything and the like.
I'll post an address if I stumble across the site again.
SilverGhost is offline   Reply With Quote
Old December 28th, 2006, 21:48   #6
Dodoma
Default Incrasing idle speed
I wonder if the idle speed will increase if you just moved the pump sproklett clock or anti-clock wise. This is how it was done on 1.6 rabbits in additon to increasing the screw length on the pump where the throttle end rested.
Dodoma is offline   Reply With Quote
Old December 29th, 2006, 04:10   #7
sleze
As I found out in the B5 forum. This, and may other features, doesn't work on our Passats. I guess I am gonna have to pony up and pay Jeff to do it.
-DECEASED-
www.thereheis.com
Old December 29th, 2006, 04:55   #8
SilverGhost
He has a Passat with the PD engine. There is no pump sprocket to move. The computer activates a solinoid on each injector for control.
Old February 1st, 2010, 15:08   #9
spooner miller
Fuel Economy: don't know yet
I am having the same problem, my car makes this horrible rattling noise almost like the flywheel is scraping the bell housing or something, but if i just very slightly push on the throttle is does away or if the condenser kicks on.. I want to sell the car but that noise is going to scare away any potential buyer. Anyone have any ideas what the noise is or how to fix it??
spooner miller is offline   Reply With Quote
Old February 1st, 2010, 16:53   #10
SilverGhost
It's been a while since I've read this thread and I have learned some since then.
That sounds like the chain for your oil pump and balance shafts is worn out.
Jason
Old February 1st, 2010, 20:59   #11
jetta ,97
jetta ,97's Avatar
Fuel Economy: 39 MPG 20%hwy,80% citi;48 MPG hwy
That is like $3k fix.
http://forums.tdiclub.com/showthread.php?t=233651
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK IV 1999.5 With Immo3 FIS Cluster
jetta ,97 is offline   Reply With Quote
Page generated in 0.16017 seconds with 9 queries
[Output: 100.80 Kb. compressed to 84.84 Kb. by saving 15.95 Kb. (15.83%)]
