Old November 23rd, 2006, 08:09   #1
LF06VWJTDI
LF06VWJTDI's Avatar
Default Replacing side mirror turn signal bulbs?
Has anyone done this? What light bulb does it take? Or is it led?
Do I need to take the whole mirror apart (as if I were swapping the blinkers?)
'06 Jetta TDI Sport Edition Pkg2/DSG.
Sold
'06 Jetta 2.0T Pkg2/DSG.
73,200 mi.
LF06VWJTDI is offline   Reply With Quote
Old November 23rd, 2006, 08:31   #2
SVTWEB
LED.. Should never need to be replaced....
2010 Jetta TDI 6-Speed
2001 BMW R1200C Phoenix; 2012 BMW K1600GTL
2014 Ford F150 Raptor; 2017 Ford Escape
SVTWEB is offline   Reply With Quote
Old November 23rd, 2006, 08:44   #3
LF06VWJTDI
LF06VWJTDI's Avatar
uhm...so what happened...I blew a fuse?
Sold
73,200 mi.
Old November 23rd, 2006, 09:19   #4
compu_85
Gadget Guy
compu_85's Avatar
Or there's a wireing problem. I wonder if it tripped a fault code?
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old November 23rd, 2006, 09:21   #5
SVTWEB
Do you have VAG-COM? It is possible to accidently turn them off in VAG-COM. Just an FYI, if you do blow a bulb, a light on your instrument cluster will illuminate to let you know you have a light out.
I would do a scan before anything.
Old November 23rd, 2006, 12:35   #6
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
I wasn't going to touch this post, then I thought why not?
Start your car, turn on the turnsignal. Do the front and rear turn signals function properly? Normal rate of interruptions?
Yet the Mirror turn signal remains dark?
Yes you may have a blown fuse.
05.5 MKV TDI,Euro Tails, Rear Fog, Aspherical Mirrors-04.5 PASSAT TDI, Aspherical Mirrors
Tim Birney is offline   Reply With Quote
Old November 23rd, 2006, 14:31   #7
LF06VWJTDI
LF06VWJTDI's Avatar
Well, I took the mirror apart (I practiced for when I will put smoked blinkers).
I can confirm that those lights are indeed led lights. Wiring seems fine. Front and rear turn signal work ok.
Manual says turn signals fuses are F25 and F26 on fuse box in engine compartment. I checked those and they are fine.
Last think I need to check is if I didn't accidentally turn them off with VAG-COM, although I wouldn't have any idea on how to check that. Controller 9? Controller 46? Which bit should I look for?
I doubt it is a VAG-COM issue, if I did turn them off by mistake why would the right one work and not the left one? Unless they can be turned off separately through adaptation? But at this point that would have been too complicated an operation to have been done by mistake.
Looks like I gotta take a trip to the dealership. Man, I hate that...
Sold
73,200 mi.
Old November 23rd, 2006, 16:00   #8
SVTWEB
IT would be in controller 9, but you could also do it if you went into the door electronics for for the side that doesn;t work. they are controlled via CAN-BUS throught their respective door computer.
Old November 23rd, 2006, 17:24   #9
jayb79
It is possible the led is bad. They dont' wear out, but it is not unheard of for one to just quit.
01Golf(385k), 2013 Mustang V6 28-30 summer mpg, 2016 F150 RCSB 2WD 2.7L ecoboost.
jayb79 is offline   Reply With Quote
Old November 23rd, 2006, 17:51   #10
compu_85
Gadget Guy
compu_85's Avatar
In our Passat the mirror has 3 LEDs in it for the turn signal.
-Jason
Present:
Past:
Old November 24th, 2006, 00:37   #11
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
Did you try a voltmeter or testlamp check at the connections in the mirror? You'll soon confirm whether the problem is in the LED array that way...
DPM is online now   Reply With Quote
Old November 24th, 2006, 04:57   #12
LF06VWJTDI
LF06VWJTDI's Avatar
Unbelievable folks. After I went through the trouble of taking the mirror apart, checking all kinds of fuses and wires, in the end it turned out to be a VAG-COM issue just like SVTWEB suggested.
Controller 42 - Door Electronics, Driver: I added the value "4 - Side mirror turn signal installed" to the coding, so that now it's 000511 - and voila Houston we got blinkers!
It remains to be seen how that value was taken out of the coding since I haven't touched VAG-COM in a while, but I don't really care. It all works fine now.
Thank you all for your help and thanks to SVTWEB for pointing out the VAG-COM issue. I would have never thought of it.
Sold
73,200 mi.
Old November 24th, 2006, 07:27   #13
SVTWEB
Thank you.. Thank you... Thank you... I appreciate the applause from all of you... Please... Just throw money..... Thank you......
Page generated in 0.15250 seconds with 9 queries
[Output: 114.11 Kb. compressed to 94.94 Kb. by saving 19.16 Kb. (16.79%)]
