Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Other TDI/Diesel Picture Gallery
Other TDI/Diesel Picture Gallery Do you have a TDI or Diesel not listed above? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old November 18th, 2006, 11:08   #1
03_01_TDI
Banned
TDI(s): Na
Default Best full size truck -for MPG
Whats the best full size diesel truck for general use. No towing and very little to no heavy hauling. Just a motorcycle or two in the bed.
Since towing is not needed I could use a very low gear and turn very little RPMs to increase MPG. 4x4 is prefred over 4x2. Don't want a huge long four door truck.
Would love to get a light duty 1/2 SWB 4x4 truck, but they don't make them.
Whats the best truck that can use a very low gear for best MPG?
Whats the highest MPG you've read about from a 3/4t Diesel truck?
03_01_TDI is offline   Reply With Quote
Old November 18th, 2006, 11:37   #2
DesertV10
DesertV10's Avatar
TDI(s): 2006 V10
Here's a little different idea- the Dodge Sprinter, really a Mercedes, with a 2.7L, 5 cyl., 154 hp diesel, get 24-28 mpg. It's a van, not a pickup, but comes in both passenger and cargo versions and various wheelbases. There is plenty of room for motorcycles, but not 4WD.
DesertV10 is offline   Reply With Quote
Old November 18th, 2006, 20:46   #3
KansasTDI
I had a friend in SE Colorado that owned a 96 Dodge 3/4 ton 4X4 auto diesel and he got between 25 mpg and 30 mpg on the highway but it had a high speed rear end in it. He was a diesel mechanic by trade and knew what he was looking for when he bought it.
Bryan
2003 Jetta TDI sedan, 5m, tinted windows, XM radio, purchased May of 2005, great car. SOLD with 406,000 miles
NEW 2003 VW Beetle TDI, 5m, purchased July 2016
KansasTDI is offline   Reply With Quote
Old November 18th, 2006, 21:20   #4
whitedog
You don't want low gears so the engine will turn slower, you want high gears.
Which means the numbers will be smaller.
IE 4.11s are lower than 3.89s.
Winters come, and winters go.,
Summers come, and summers go.
Old November 19th, 2006, 06:02   #5
RAMP
TDI(s): 2002 NB
Fuel Economy: 39 first tank
My Duramax with a 6.6L diesel gets 20 mpg uphill or downhill.
RAMP
2002 NB
RAMP is offline   Reply With Quote
Old November 20th, 2006, 03:08   #6
DieselPub
Fuel Economy: 40-45
I have a 2002 Chevy 2500HD 4x4 with the Duramax. When I am on the "Juice" get about 10mpg. Normal driving, uphill, downhill, or even loaded I am averaging 22mpg.
2012 Jetta TDi w/Navi & Premium, Black
Bought it 9-24-11
Thanks Tara!!
DieselPub is offline   Reply With Quote
Old November 28th, 2006, 10:53   #7
Wil Murphy
The Ford LCF (a cabover commercial vehicle) has a 200hp twin-turbo 4.5L V6 diesel which may end up in the F-150.
Wil Murphy is offline   Reply With Quote
Old November 28th, 2006, 13:38   #8
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Sure they do. You don't see them very often, but they make a 1/2 ton, reg cab, shortbed (6.5'), 4x4 truck. It'll be up to you to make it a diesel of course.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old April 4th, 2007, 01:40   #9
MR42HH
MR42HH's Avatar
TDI(s): BMW 530d
Sure there are sprinter pickups, crew cab or single cab, three wheelbases, a choice of five diesels and three gearboxes.
pickup:
There's more info on the microsite.
http://sprinter-microsite.syzygy.de/2/start/en-GB/
AWD is available as a retrofit from Iglhaut.
http://www.iglhaut-allrad.de/htm/e_home.html
review here:
http://www.iglhaut-allrad.de/htm/pdf/003.pdf
530d
MR42HH is offline   Reply With Quote
Old April 8th, 2007, 07:04   #10
RC
RC's Avatar
pickup:
Hey MR42HH, how can I kindly tell you to #^&* off?
You Euros alway have to rub it in our faces don't you.
What I wouldn't give for one of those dual cab pickups with an Iglhaut retrofit.
Two 96 TDI Passat Wagons, Bypass Filters, Chipped
87 MB 300TD, 97 Ram2500, Kubota Tractor
24 cylinders sipping the sweet sauce of the soy bean
RC is offline   Reply With Quote
Old April 8th, 2007, 13:46   #11
lawallac
lawallac's Avatar
Fuel Economy: 57 MPG
I did a little search on the 4.5L diesel and found this. Some interesting stuff here. http://findarticles.com/p/articles/m...66/ai_63256175
2002 JETTA 5SP -RC 4, PP520S, VNT 17/22, Mufflerectomy, 3 Bar MAP, SBC Stage 3 with 17# FW, Snow Screen Tossed, Bilstein HDS, H&R OE Sport's, Alientech Window Controller, Clear Side Markers, Phatbox, Memphis 12, Oldschool Fosgate 800 a 2, Panzer Plate, TDI Heater, Ariettas, DG Race Pipe, EGR Cooler Delete, , TDIParts OMI, Doniol OLED 30 PSI Boost/EGT w/MCA Probe
lawallac is offline   Reply With Quote
Old April 9th, 2007, 04:57   #12
dieselsRus
dieselsRus's Avatar
No worries guys, these sprinter trucks are sold for us as well. They even come with the luxuries: side airbag, xeonons, steering wheel controls, two available wheel bases, and a 11,000 LB GVW.
http://www.fl-sprinter.com/index.asp?n=5&p=0&s=5
also click on the gallery they show one with that exact bed in the photo above!
dieselsRus is offline   Reply With Quote
Old April 9th, 2007, 06:45   #13
MR42HH
MR42HH's Avatar
TDI(s): BMW 530d
Ah, great. The bed in an option for the chassis cab. Makes sense.
530d
Old April 10th, 2007, 01:25   #14
hemisareslow
i call bs on that one....22mpg??? up hill or down loaded or unloaded??? please...I have an 03 duramax with the lb7 motor...argueably the best duramax to have from a mpg standpoint....with my edge/attitude set on one driving like an old lady I might..and I stress might see 20mpg on a flat stretch of highway... towing 12k pounds I get around 12-14 mpg...and for general mix of highway and city driving I see around 15-16...lets not forget this is an 8000 pound truck...
hemisareslow is offline   Reply With Quote
Old April 10th, 2007, 01:28   #15
hemisareslow
question for the origonal poster....if you do not intend on towing...and the most you will haul is 2 bikes...why pay 8 thousand bucks more for a diesel?? granted you will get it back on the resale...but you will pay more for maintenance....100 dollar oil changes...35 bucks for a fuel filter you change every 5k...10 bucks for a tranny filter you change every 5k...it all adds up...I'd sitck with a 1/2 ton gasser with a 5.7 in it...just my 2 cents though
Page generated in 0.19433 seconds with 9 queries
[Output: 125.15 Kb. compressed to 103.66 Kb. by saving 21.49 Kb. (17.17%)]
