| TDI Conversions Discussions on converting non TDIs into TDIS. More general items can be answered better in other sections. This is ideal for issues that don't have an overlap and are very special to swaping engines. |
October 18th, 2006, 08:26
#1
Diesel Buggy???????
Over in another thread I saw a link posted by toofer to someone putting a 1.6TD in a porshe. Over the last few weeks, I have been tempted to build a manx clone. How cool would it be to have a diesel buggy?
My Experience and skills in chronological order:
Small engine mechanic and builder since age 11
1981 rabbit diesel (caddie) general maintenance
1969 type I total restoration including all engine work
Mechanical Engineering degree
Two new TDI's
Resources I will have on hand before I start this project:
3 car garage with one empty bay
MIG welder
Access to a simple machine shop with minimal cost
Berrien Buggy Tube chassis and Nostalgia body
A simple 1.6 TD and a Kennedy Engineering adapter for the VW type one transaxle
Now for the real questions.
Besides the obvious radiator, transaxle and associated stuff, what else do I need?
Is there anybody in the foothills of NC that has more 1.6TD experience that would like to help? I have the general fab skill and the type I skills, just no specific 1.6 skills.
I know what a buggy looks like with a boxer hanging out the back, what's it gonna look like with 1.6TD hangin out back there?
As a last ditch effort for this project, I have everything to build a boxer shortblock on hand if the 1.6 doesn't work out.
Is it ever gonna happen?
Who wants to help?
Start throwing ideas out. I still have a kitchen remodel standing between me and this project, so start throwing suggestions my way so I can put together a rough budget.
2006 Jetta TDI, PKG 1, DSG Campanella White with beige
2005 Passat TDI Silverstone, grey leather, phatnoise, chainectomy
Ask me about my aircooleds
October 19th, 2006, 17:40
#2
Fuel Economy: 97 passat, best 51.3 Jetta, best 49.9 (ugh, almost there) Dodge, best 24.1 avg 19.6...ain't bad for 7000 pounds, 300 hp and 800 ft/lb
Nice....
A diesel buggy would be so cool...I thought of a diesel sand rail, after seeing a 2.0 supercharged in one a couple years ago. Good luck..I'm in CT otherwise I'd be down for a couple late nights to help make it happen!
Ray
97 Passat TDI (totalled) Bummin'
01 A4Q 1.8t 24mpg(that hurts)
October 19th, 2006, 20:01
#3
Fuel Economy: 44 best, 38 worst
After watching that trike build-off on the Discovery Channel the other night, I go to thinkin' that a TDI-powered trike would be pretty sweet!
1998 A3 Black
2005 Sprinter 118, white cargo, wife's ride.
1973 Travco 270 motorhome repowered with Cummins 6BT and 518 automatic OD tranny from wrecked 1993 Dodge D250<<SOLD
October 20th, 2006, 12:38
#4
Think there is one out there somewhere on the east coast. I know there are a couple Perkins diesel powered trikes out there. One is in Erie, Pa.
'02 Jetta TDI GLS. Bosio Sprint 520. Hella E-Codes. HiddenHitch and rear suspension air bags. Evolution Skid Plate.
October 20th, 2006, 19:01
#5
Know waht you mean
Engineer, I just bought a new 2006 TDi with just over a thousand miles on it and love it so far. But my day dreaming also has me thinking that it would be cool to set a TDI in a sandrail frame and get it all rolling. Out here theres a place called Dumont Dunes and people come up with all kinds of cool setups and some have thousands and thousands of dinero tied up in their projects. Sorry to say not me tho. Maybe when I retire and have more time. Let me know if you get it going and maybe send out some pics. Welderman
October 28th, 2006, 21:47
#6
Fuel Economy: 800km/1100km/tank
Engineer:
Why use the Kennedy/Type I box?? You can get a Type 2 box (T3) with the correct bellhousing for layed over 1.6, or better yet, an aftermarket bellhousing that puts a waterpumper upright (we will have one out of a WestySyncro that has a 1.8 in it when we go on to TDI swap - if you are interested).
A4=2003 TDI Variant, A3=Golf CL, A2=2x1.6 Jetta TDs, Golf Syncro Country, A1=Scirocco Mk1 & 16v, Audi 5000TD, Porsche 924/M471 and a bunch of diesel trucks.
October 29th, 2006, 15:38
#7
Pre-Forum Veteran Member
Fuel Economy: Which VW diesel? There have been Twelve of them!
What is the power to weight ratio for a hopped up air cooled 1.6 or 1.8 versus a chipped 1.9 TDI? Remember to add for the radiator and such for the TDI. Is this diesel weight penalty really what a lightweight, surface skimming vehicle needs hung on the back end?
Diesel for a Suzuki Samurai rock crawler, keep air cooled flat four (or Porsche 6) for a sand rail.
Svante Arrhenius 1896
October 29th, 2006, 15:41
#8
Originally Posted by Pat Dolan
Engineer:
Let me make sure I understand you correctly. I can get a Type II transmission and a 1.6 will bolt directly to it, or, a type II box with a new bellhousing that the 1.6 will bolt to upright?
What do I need to do to the type I chassis to make it accept a type II trans? I just picked up a 1968 swing axle beetle today as my chassis donor.
Sorry but I know nothing about vw buses. All my aircooled dealings have been with type I.
October 30th, 2006, 06:38
#9
engineerorange:
To begin with, you need to be IRS to use the TypeII box. From the beginning of IRS TypeIIs, they used a different gear case from all others (except some 181). All of these boxes use a separate bellhousing, so that VW could adapt whatever powerplant they wanted/needed. The 1.6NA diesel was in there (layed way over) and there are aftermarket bellhousings that stand one up straight. It will be a lot easier to just find/build a gearbox and buy an upright bellhousing than finding a complete diesel gearbox (with bellhousing), and then you would need the high-angle oil pan, pump, etc. There MAY be a swing-axle conversion for this box....but I would have to wonder why. The typeII box is often used in buggies, so there should be plenty of room, and mounts are easy (they do NOT mount on frame horns, they hang from on top plus rear engine hangars).
