Old October 11th, 2006, 14:21   #1
PseudoFinn
PseudoFinn's Avatar
Fuel Economy: Hell of a lot more than the EPA sticker said I would. ;-)
Default Pistons won't wind back on rear calipers...
So I loaned my TDI to someone... someone who will never be loaned a vehicle again- and they royally screwed my rear brakes up. It took quite a while to remove the calipers, as they were locked up, to replace the rotors. While attempting to wind back the caliper piston... I realized I was not getting anywhere. They would wind, but the booting never compressed, and the piston never went back in, even after maybe 20-30 revolutions, they never seemed to move. Is it possible that the piston was so far extended that they simply will not go back in now? I'm having this problem on both sides. Am I now out 200 dollars for new calipers, or can they be repaired. Am I correct in assuming that when I start turning the piston, it should go right back in without many revolutions?
Please help! My car is now sitting in a parking lot, 30 miles from home!
PseudoFinn is offline   Reply With Quote
Old October 11th, 2006, 14:26   #2
ScorpionBoy
how did they trash your rear brakes so fast?
2003 Jetta TDI, Auto
Coolant Migration Mod
Provent CCV Filter
Panzer Plate
Vented
ScorpionBoy is offline   Reply With Quote
Old October 11th, 2006, 14:36   #3
MOGolf
MOGolf's Avatar
What tool are you using for the windback? Does it also put pressure on the piston at the same time?
If it does get pushed out to the extreme limit (e.g. you have no pad material left) it does take an extreme amount of pressure to get it started back in.
There are several people in MI that can help. Can you supply a more specific location for the car?
MOGolf is offline   Reply With Quote
Old October 11th, 2006, 14:36   #4
PseudoFinn
PseudoFinn's Avatar
It was a fairly extended loaner... didn't expect it to be.... but it was.
Not something I will do again. Family or not.
Old October 11th, 2006, 14:39   #5
ScorpionBoy
ah. bummer. i haven't had to do rear brakes yet, so i am useless. i do know there are some special tools which are necessary. maybe you need one of those? just wild assed guess, fwiw
Provent CCV Filter
Panzer Plate
Vented
Old October 11th, 2006, 14:40   #6
4Gman
4Gman's Avatar
TDI(s): 2000 Jetta
Do you have the brake fluid reservoir open?
IF its full, The fluid needs somewhere to go when you push back the piston.
RC3 - PP520 - Vnt17 - 2.5 SSDP - etc
4Gman is offline   Reply With Quote
Old October 11th, 2006, 14:42   #7
PseudoFinn
PseudoFinn's Avatar
4Gman.... I cracked the fluid reservoir. No luck.
MOGolf... The vehicle is currently located in Linden, MI. I didn't realize I would need to apply much pressure at all. This is encouraging. Any idea what kinda tool I would need to get my hands on to get the job done?
Thanks for the SUPER speedy replies, everyone!!
Old October 11th, 2006, 14:51   #8
ScorpionBoy
i think you need this thing
http://www.tdiparts.com/catalog/prod...roducts_id=402
Provent CCV Filter
Panzer Plate
Vented
Old October 11th, 2006, 14:51   #9
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
You might need to apply pressure with a large c-clamp while turning the piston. I bought the Lisle universal tool from Sears for $12
How far is the car from these guys?
http://www.steveseuropeanauto.com/ab...e/SEA_shop.htm
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old October 11th, 2006, 14:58   #10
wjdell
Fuel Economy: avg. 41.93 high 46.32 low 34.6
If the piston locked up - you would be wise to replace or rebuild which ever you inclined to do. Kits are cheap but you must prepare cylinder and the piston. If they can be, when you disassemble you know what is required.
Bleed the sys well, if you do not have a work shop manual you should get or borrow.
Post your UOA data in the TDI UOA Database thread
http://forums.tdiclub.com/showthread.php?t=205814
~ USED OIL ANALYSIS ~ http://forums.tdiclub.com/showthread.php?t=190958
1.9 PD Jetta V ~ pkg 1 ~
DSG ~ 17" VV ~ 36/34 psi ~
ULSD ~ DG-BP90 - speed 39.2
hwy/city 83% / 17% ~
elev 58 ft / temp 72 F / humidity 76% ~ MPG 48.3 / 42.8 / 35.6
wjdell is offline   Reply With Quote
Old October 11th, 2006, 15:05   #11
MOGolf
MOGolf's Avatar
If you can carefully drive it to near Fowlerville, JETaah might be able to help. http://www.martinbergelllc.com/
Old October 11th, 2006, 16:34   #12
Drivbiwire
Zehntes Jahr der Veteran
LOL, you have to have the right tool for the right job...Shortcuts just make the journey longer.
www.metalnerd.com
DB
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old October 11th, 2006, 20:03   #13
jokila
jokila's Avatar
Fuel Economy: 52/45/40
If there is an Autozone in the area they will charge you $0 to loan you the tool. You do have to pay $35 upfront but you get it back when you return the tool.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is online now   Reply With Quote
Old October 11th, 2006, 20:44   #14
GoFaster
Moderator at Large
I've done it with the standard cube-shaped tool on a ratchet with a big adjustable woodworker's clamp around the whole deal. Turn a little, squash a little, turn a little, squash a little, etc. It's a whole lot easier with the tool designed for this purpose.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old October 11th, 2006, 21:39   #15
ScorpionBoy
rear brakes don't do all that much if you aren't hauling ass. if they aren't totally locked up, drive it home and turn up the stereo so you don't have to listen to the griiiiinding.
Provent CCV Filter
Panzer Plate
Vented
Page generated in 0.16934 seconds with 9 queries
[Output: 121.01 Kb. compressed to 100.04 Kb. by saving 20.96 Kb. (17.32%)]
