Old October 11th, 2006, 08:07   #1
veget8
Fuel Economy: 74.3/36.5/31
Default Clogged Catalytic Converter?
I am experiencing problems with top end power output. According to a VAG-COM, my (brand new) MAF says that my actual flow is 450-550 (request is 800+) at 3000 rpm. I have pretty much eliminated the possibility of a problem with anything in the intake path.
My question is, has anyone ever experienced a clogged catalytic converter or other exhaust component? What was that like?
Another question- I shudder to think how much VW probably charges for the cat on these cars. Are there any lower cost options? Would any cat work ok, such as one made for a gasser?
2002 Golf TDI - 200,000 miles
RC2, 11mm pump, sprint .205 injectors, DG racepipe, mufflerectomy, high flow cat, Greasecar, SBC Stage 3 Clutch w/ Valeo G60 Flywheel, H&R OE Sport Springs, Bilstein HD Struts, cross-drilled rotors, .658 5th gear swap, DQY (Beetle) transmission
veget8 is offline   Reply With Quote
Old October 11th, 2006, 08:38   #2
Herm TDI
Herm TDI's Avatar
Symptoms of a clogged CAT:
1. Lack of or poor top end performance. Nopted by a limit of top speed. This is affected by the amount or degree of clogging. I've seen a TDI CAT clogged so badly that the top speed was 55/60 MPH.
2. Another symptom is excessive low /poor MPG on a 5 Sp I've seen MPG drop from 50 to a low of 38 MPG.
3. Excessive black smoke under attempted heavy acceleration
I also noticed that acceleration in 1st, 2nd & 3Rd gear was close to normal excepth when WOT in 3rd gear.
WOT in 3Rd resulted is a noteable sluggish feel. The car would accelerate but rather slowly.
About replacing your CAT...The CAT on a diesel is not the same as a "gasser" CAT. You'll need a diesel CAT.
Herm TDI is offline   Reply With Quote
Old October 11th, 2006, 11:29   #3
veget8
Thanks herm- that definitely describes what I'm seeing. I will look into a replacement diesel cat. I'm not particularly attached to having a cat, but it seems like I ought to have one in order to be legal. I see there is magnaflow cat. converter available for this car:
http://www.as-sl.com/car-sound/ficha...&ma=33&md=2229
Looks expensive and "oem like". Anyone bought/used it?
Old October 11th, 2006, 15:24   #4
pghPAtdi
pghPAtdi's Avatar
Fuel Economy: 57/40/34
How does this place compare in price to what you have seen?
http://www.import-catalytic-converte...rter-warehouse
219.00 bucks seems pretty reasonable. Or you could stick a paint mixer spade in there on a drill andbeat the he11 out of the inside.
Dave
15' Audi Q5 Tdi
pghPAtdi is offline   Reply With Quote
Old October 12th, 2006, 07:44   #5
chromeBuddha
chromeBuddha's Avatar
Fuel Economy: 47 mpg @ 75 mph
I think you would be better off trying to find a salvage car, there are a couple being parted out in the For Sale section, and get the exhaust from that.
I don't know how feasible this is, but disconnect the exhaust, stuff some heat shielding around the turbo outlet and see if the actual and requested come more into line.
2002 Golf TDI, 5-speed, 2-door
White w/ Tan interior (get the Scotchguard!!!)
47 mpg @ 75 mph
"El Bonbon" - The Marshmallow
chromeBuddha is offline   Reply With Quote
Old October 13th, 2006, 05:02   #6
Mikey2
The CAT on a diesel car is not something you truly need and it will not affect measured exhaust values.
Remove the CAT and using a length of steel bar remove the fillings inside the CAT and reinstall it. That is a standard procedure by VW dealership in Finland !
Mikey2 is offline   Reply With Quote
Old October 13th, 2006, 05:19   #7
Doug Huffman
Location: Washington Island, on the other side of Death's Door, Wisconsin
Fuel Economy: 50+(Jetta)
I wonder how 'stealership's no-service department' is said in Finnish?
Jetta Wagon TDI 2K3 Silver has gone to a new home, replaced by Behemoth 2012 BMW X5 35diesel. Jason T. Daniels Is my 55 mpg guru.
Doug Huffman is offline   Reply With Quote
Old October 13th, 2006, 09:58   #8
Herm TDI
Herm TDI's Avatar
This rare (and oft difficault to locate) "tool" is refered to as a "Devil's tooth pic". I have one such tool. I've used it a few times....works well.
Old October 13th, 2006, 11:55   #9
veget8
Well, I just got the car back from the muffler shop. Incidentally, they said they were required by law to replace a catalyst on a vehicle that has one from the factory. Had them replace the cat and do a mufflerectomy (I don't want any variables left). They used a high flow cat designed for a diesel, not sure what brand.
Took the car for a test drive and the only thing different is that it's louder. Top speed is still around 75-85 depending on whether I am going up or down hill. Power is fairly good until about 2800 rpm, and then it drops off pretty quick. The car won't go past much past 3200rpm in any gear, if it does, it creeps by it. If I jump hard on the pedal in first there is a quick puff of black smoke around 2000 rpm.
Thanks for everyone's suggestions anyway. I was pretty sure this was going to be it.
Old October 13th, 2006, 20:42   #10
chromeBuddha
So are we looking for a boost leak or a really stuck VNT at this point?
47 mpg @ 75 mph
Old October 15th, 2006, 19:04   #11
veget8
FYI, This thread has been taken over by http://forums.tdiclub.com/showthread.php?t=155184
Old October 15th, 2006, 19:24   #12
whitedog
Just not a Cat diesel.
Can fold paper in half eight times.
Old October 18th, 2006, 08:51   #13
cattlerepairman
cattlerepairman's Avatar
Fuel Economy: 8.4 l/100 km at 60/40 hwy/city
Default Are You Sure...
..that the "new" MAF was not DOA?
I would, at this point, replace it with a known good one (from a TDI that runs like the bat from hell, compared to yours) and see if that makes a difference. The values you posted and the drop-off at 2800 rpm sound too close to a bad MAF for comfort.
A good MAF meets the 800 - plus requested value without problems and can measure a flow of over 1000.
2012 Touareg TDI Lux, Campanella white
1974 AM General M35A2C w/w (for the 6x6 moments in life)
1999 New Beetle TDI, 1999, dark blue ("Batik Blue"), 5spd (SOLD)
cattlerepairman is offline   Reply With Quote
Old October 20th, 2006, 17:54   #14
veget8
Cattle-
Thanks for the suggestion. I have tried several MAFs that I had on hand, but I haven't really had one that I knew was right out of a working car. I will keep an eye out for someone who would be willing to let me try theirs. Thanks
-Scott
Old October 30th, 2006, 16:08   #15
sodapop6620
sodapop6620's Avatar
TDI(s): Jetta 2000
Fuel Economy: about 57 avg. lately
Your turbo maybe going south. Have you checked or replaced the fuel filter?
2000 Jetta 5sp 360,000 plus Nov 08
2/05 Mileage contest winner 59.942 MPG @ 55MPH indicated
4/05 Mileage 3rd place 59.76 MPG @ 60MPH indicated
sodapop6620 is offline   Reply With Quote
Page generated in 0.13650 seconds with 9 queries
[Output: 127.01 Kb. compressed to 105.56 Kb. by saving 21.45 Kb. (16.89%)]
