Old August 12th, 2007, 09:30   #61
theFATman
theFATman's Avatar
Fuel Economy: 51/48/43
as far as the fuel in the oil goes.. is that just from blow-by or what do you think? Maybe i could lower my IQ a tiny bit as long as there was no shuddering and see what happens next time?
"Sir, are you classified as human?"
"Negative, i am a meat popsicle."
theFATman is offline   Reply With Quote
Old August 13th, 2007, 08:42   #62
SUNRG
SUNRG's Avatar
Fuel Economy: 28mpg@74mph: 1995 Volvo 850 Turbo Wagon
could be worn or dirty nozzles. you could try a couple doses of the Motul Diesel System Clean - LINK
and/or a LM Diesel Purge. i recommend doing this just after you pull your next oil sample (assuming your using an oil sampling pump) and just before your change the oil.
if that doesn't clear it up there are other potential causes - but IMHO that's the "low hanging fruit".
cheers!
ECO-DRIVING - advanced driving techniques contributing to sustainable mobility. Links 1 - 2 - 3 - 4 - 5
Bicycles, lots of them, mpg | 05 VW Passat Wagon GLS TDI ~36mpg
SUNRG is offline   Reply With Quote
Old August 20th, 2007, 09:04   #63
dhdenney
dhdenney's Avatar
Fuel Economy: 39
Here's my latest UOA for AFL. Fuel was 95% B20 use. I expected iron to be lower but maybe residual. Silicon was no surprise as I had the valve cover off. Probably got some dirt in there at that time.
*2012 Audi A3 TDI, Premium Plus, DSG, Ibis white
*1994 Pontiac Firebird Formula, Gt47-80 turbo, 580 rwhp/700 rwtq
*2004 Jeep Liberty Sport 4X4
dhdenney is offline   Reply With Quote
Old August 20th, 2007, 15:29   #64
SUNRG
SUNRG's Avatar
IMHO - you've been returning significantly higher than average Fe wear since you started UOA tracking at 14k. if it were my TDI - i'd drain and refill with a VW approved 50700 or 50501 oil, do one short cleansing OCI of 2-3k as a rinse (IMHO no UOA necessary), then on to 10k+ OCIs using UOAs to confirm oil performance and engine health. Cheers!
Old August 20th, 2007, 15:41   #65
Blue_Hen_TDI
Yeah, 82 iron over 10K would prompt me to go with an approved oil. I've always used 505.01 or better in my PD and have shown no higher than 41 ppm for Iron, 6 ppm Aluminum, and 4 ppm Copper over 10K OCI. You're roughly double on those.
'15 GSW TDI S, DSG - FrostHeater, Helix soundbox, OEM asphericals, OEM sunshades
'16 GTI S, 6M, Performance & Lighting pkgs - IE IC, AWE Touring TBE, VWR springs
Blue_Hen_TDI is online now   Reply With Quote
Old August 20th, 2007, 15:56   #66
dhdenney
dhdenney's Avatar
Fuel Economy: 39
I tend to agree. At my current rate of Fe, I would be at almost 89. At this point I feel like my Fe should be dropping significantly.
Old August 20th, 2007, 19:10   #67
dhdenney
dhdenney's Avatar
Fuel Economy: 39
BTW, should I use an engine flush such as Motul before switching oils? Or should I run the short 3K interval, then do a flush?
Old August 22nd, 2007, 00:38   #68
AndyH
There's no need to flush, as your engine is clean. If you plan to change oil brands, and the new oil company has a flush, and it would make you feel better, flush to 'neutralize' the last of the oil oil that will remain in the engine.
AndyH is offline   Reply With Quote
Old August 22nd, 2007, 00:42   #69
AndyH
A comment on comparing UOA reports...
UOA is a trending tool and is only valid for that specific engine. No two engines are identical, no two cars are identical, and no two drivers are identical.
UOA is a great diagnostic tool, but it is not a valid oil comparison tool. If it were, there'd be no need for ASTM tests or engine test stands.
Old August 22nd, 2007, 00:55   #70
Long_Range
Fuel Economy: 54/45/41
dhdenny;
Do you run this car a bit hard? Usually that's the case with high soot. I make 1% per 10K miles myself.
2004 Jetta GL, Amsoil bypass oil filter, FrostHeater.com, Cat fuel filter, Air Springs.
Long_Range is offline   Reply With Quote
Old August 22nd, 2007, 00:57   #71
AndyH
Originally Posted by TornadoRed
I have read somewhere that if oxidation plus sulfation equals 50 or greater, it's time for an oil change.
Okay, it was here: http://www.oaitesting.com/g2047.pdf
Given that you didn't get a TBN value, OXID + SULF may give you an approximate idea of the acidity of the oil. Yours is considered "excessive".
I think you mean that if either oxidation or nitration is over 50 it's time for a change?
Old August 22nd, 2007, 01:36   #72
TornadoRed
TornadoRed's Avatar
Fuel Economy: 52/41/36 (679k miles)
It does say that, doesn't it?
Oxidation, nitration, and sulfation are too often ignored. The lab results I get never include them.
'03 Golf with 679k miles: Bosio DLC 764, GT1749VB, Passenger Performance 2.5" DP, Malone tuning, VR6/G60 clutch/flywheel, Bilsteins, Recaros, Akebono pads/Zimmerman rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Nokian snows, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
Old August 22nd, 2007, 06:37   #73
Blue_Hen_TDI
Point taken. I still think 80+ppm Fe for recommended OCI is a tad high (certainly not terrible), regardless of conditions.
Old August 22nd, 2007, 08:27   #74
dhdenney
dhdenney's Avatar
Fuel Economy: 39
Right I am aware of variables between cars/engines and UOA in itself is not perfect. I just want to see if lower wear numbers are attainable for me.
Old August 22nd, 2007, 08:28   #75
dhdenney
dhdenney's Avatar
Fuel Economy: 39
Originally Posted by Long_Range
dhdenny;
IMHO, I don't run it hard. But that's a subjective term. Perhaps I do run it hard. So ideally soot should be down around .5 after 10K? Maybe it's in my oil instead of my EGR.
Page generated in 0.19778 seconds with 9 queries
[Output: 128.84 Kb. compressed to 107.17 Kb. by saving 21.67 Kb. (16.82%)]
