Old April 2nd, 2007, 21:00   #31
thermographer
thermographer's Avatar
Fuel Economy: 51.7/46.06/39.66 800 mile club 3 times.
Oil sample pump question, not worth starting a new thread.
Where do you guys get the tubing that came with the sample pump (white poly or air line maybe?). The cat store near my house will only sell it in a huge roll. I would think it's important to use a new piece of tubing every time?
Waiting for results of OA 13,0004 miles on elf 507. Should be coming in the mail at any day.
2004 Jetta Sedan with Auto Trans @ 250K miles. It's not just wheat beige, it's pure gold.
thermographer is offline   Reply With Quote
Old April 3rd, 2007, 05:56   #32
dabear95
dabear95's Avatar
Fuel Economy: 45+ lifetime
I hope they are for Delvac! I meant, how many miles of use do they represent?
Jason
2002 Golf GLS ~127K+ miles. I have Vag-Com...
Modifications: RC3 ASV, PP520, G60/VR6 Clutch, Koni FSD's, VDO Boost/EGT gauges, Boostvalve, HiddenHitch
dabear95 is offline   Reply With Quote
Old April 3rd, 2007, 06:45   #33
dabear95
dabear95's Avatar
The lab indicates 8,266 miles and 266 samples for the universal averages.
Old April 3rd, 2007, 10:03   #34
Windjammer
TDI(s): MK4 & Mk5
Here is my 20K UOA. The iron seems high, but I'll defer to the experts.
http://pics.tdiclub.com/showphoto.ph...0&ppuser=45930
edit. Thanks Jason
00 Jetta TDI GLS Auto Black w/Beige leather, Phatbox
06 Jetta TDI Shadow Blue w/Beige Pkg 2 DSG W/NAV & Phatbox
06 Jetta TDI Blue Graphite w/Grey Pkg 2 DSG W/NAV & Ipod dock
06 Jetta TDI White w/Beige Pkg 2 DSG
06 Jetta TDI Black w/Beige Pkg 0 5MT
Windjammer is offline   Reply With Quote
Old April 3rd, 2007, 10:07   #35
Windjammer
TDI(s): MK4 & Mk5
Yes it's important to use a new piece of tubing. When I buy my sample kits from the Cat store it comes with a new piece of tubing. Pricing btw is 1 for $18 or a 10 pack for $90. Price includes postage & lab analysis.
Old April 3rd, 2007, 10:17   #36
dabear95
dabear95's Avatar
Scott,
If you want to remove your name/address from the file you posted you may want to take a screen print or make your annotations permanent. Just a heads up!
I noticed it just from scrolling. When you scroll fast those black blobs go away for a second.
Jason
Old April 3rd, 2007, 13:09   #37
SUNRG
SUNRG's Avatar
Fuel Economy: 28mpg@74mph: 1995 Volvo 850 Turbo Wagon
http://pics.tdiclub.com/data/500/20k.pdf
if that's 20k ODO and 10k on the oil, it's quite good. some of the levels are higher than we sometimes see - but if it were my TDI i wouldn't worry about them since it's such a young engine.
ECO-DRIVING - advanced driving techniques contributing to sustainable mobility. Links 1 - 2 - 3 - 4 - 5
Bicycles, lots of them, mpg | 05 VW Passat Wagon GLS TDI ~36mpg
SUNRG is offline   Reply With Quote
Old April 3rd, 2007, 13:37   #38
Windjammer
TDI(s): MK4 & Mk5
Thanks SUNRG. I should have clarified that. Yes, 20K odo & 10k on oil.
Old April 4th, 2007, 10:13   #39
SUNRG
SUNRG's Avatar
Some of the numbers we're seeing lately are from 5k oil changes, so they look low compared to yours but, your numbers may actually be better.
For example - wjdell posted some good numbers: Fe at 10k was 24 and then he changed again at 15k and Fe was again 24 - so for the 10,000 miles from 5k ODO to 15k ODO Fe was 48.
In your engine, for the 10,000 miles from 10k ODO to 20k ODO Fe was 46. So your Fe wear is very good / low for a young engine.
Cheers!
Old April 4th, 2007, 15:58   #40
JB05
Fuel Economy: 43/41/40
This was posted in another thread but with only one response:
2005 Golf, Amsoil AFL, 5200/7500/10000 miles on oil and 25K on vehicle.
Iron 37 66 99
Chromium 2 3 11
Lead 4 6 7
Copper 11 13 16
Tin 0 0 0
Aluminum 7 8 13
Nickel 0 0 0
Silver 0 0 0
Silicon 12 4 11
Boron 30 42 42
Sodium 2 5 0
Magnesium 15 13 18
Calcium 2063 1734 1944
Barium 0 0
Phosphorus 631 709 823
Zinc 985 832 962
Molybdenum 0 2 1
Titanium 0 0 0
Vanadium 0 0 0
Potasium 0 0 0
Fuel <1 <1 <1
Vis@ 100c 13.76 12.36 12.24
Water 0 0 0
Soot/solids 1.0 0.9 0.9
Coolant No No No
TBN 4.60 4.07 3.45
Oxid 2.0 8.0 10.0
Nitr 2.0 12.0 12.0
F-soot 1.08 0.91 0.96
Change No No No
Analyst JJL JJL JJL
Drop in viscosity most likely due to B11 usage for the last 2500, and possibly my high wear metal count. I do mostly urban driving so I will just go with straight D2 and maybe shorten my OCI's. This is where I get confused because DBW has said that shorter OCI's do more harm due to the longer time for additives to stabilize. I have switched from AFL to DEO which looks to be a more robust additive package and a slightly thicker viscosity. I will resample @ 5K or sooner. Comments and suggestions are more than welcome.
John
JB05 is online now   Reply With Quote
Old April 5th, 2007, 13:04   #41
SUNRG
SUNRG's Avatar
Wear is high, but IMHO neither the wear or viscosity have anything to do with B11 use. ASTM certified biodiesel use generally results in reduced wear due to its superior lubricity compared to D2. My PD has been fueled virtually exclusively by B30 to B100 biodiesel with very low UOA indicated wear and outstanding performance.
If it were my TDI - I would drain the DEO immediately. DEO is not supported by Amsoil for use in PD TDIs. It's not 50501 recommended or approved.
Will DEO work fine in a PD? Maybe. But again, if it were my TDI there's no way I'd risk it.
We've already seen one PD failure that correlated with using the old Amsoil AFL formulation exclusively. Amsoil representatives said the earlier version of AFL was not recommended for use in PDs and Amsoil did not cover the repairs. The current version of AFL is recommended for PDs, but DEO is not. This means you are voiding your VW warranty and Amsoil's warranty will not protect you either.
With high wear numbers I don't blame you for considering switching to another oil, but considering your soot is at ~1% - if it were my TDI - I would go with a 50501 or 50700 oil.
Old April 5th, 2007, 16:27   #42
wny_pat
Fuel Economy: 48 mpg
John
How many other oils have you ran in that vehicle and what were they?
'02 Jetta TDI GLS. Bosio Sprint 520. Hella E-Codes. HiddenHitch and rear suspension air bags. Evolution Skid Plate.
wny_pat is offline   Reply With Quote
Old April 5th, 2007, 21:40   #43
robco
robco's Avatar
Has anyone tested castrol syntec 5w40 american oil? Is it suitable for 10k?
It is the only thing I can find in this hick town. I'm new to the tdi and am finding it hard to go 10,000 miles without an oil change.
robco is offline   Reply With Quote
Old April 5th, 2007, 22:18   #44
wjdell
Fuel Economy: avg. 41.93 high 46.32 low 34.6
No its probably not a good choice if you need 505.01, order it on the net.
InterAuto Parts Lubro Moly
Impex, Motor spot, Motul & Elf do some searching.
Post your UOA data in the TDI UOA Database thread
http://forums.tdiclub.com/showthread.php?t=205814
~ USED OIL ANALYSIS ~ http://forums.tdiclub.com/showthread.php?t=190958
1.9 PD Jetta V ~ pkg 1 ~
DSG ~ 17" VV ~ 36/34 psi ~
ULSD ~ DG-BP90 - speed 39.2
hwy/city 83% / 17% ~
elev 58 ft / temp 72 F / humidity 76% ~ MPG 48.3 / 42.8 / 35.6
wjdell is offline   Reply With Quote
Old April 5th, 2007, 22:57   #45
wny_pat
What car do you want to put it in???
Page generated in 0.20052 seconds with 9 queries
[Output: 132.42 Kb. compressed to 110.59 Kb. by saving 21.83 Kb. (16.48%)]
