Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Central Canada
Central Canada Local discussions for those between the Rockies and the Great Lakes (Alberta to Manitoba).
Old October 7th, 2006, 10:38   #1
casta_baga
casta_baga's Avatar
Default how to install ZeroStart Engine Heater
after i figure the ZeroStart Tank/Circulation Engine Heater would be the best pick for my TDI Golf i have a question..
can anyone explain to me how the best way to install it or just redirect me to the proper thread?
best wishes and thanks
Edmonton
casta_baga is offline   Reply With Quote
Old October 9th, 2006, 17:37   #2
chris2
Default Zerostart install
I think this is what you need.
http://pics2.tdiclub.com/gwillie/zer...%20install.htm
Let me know how you make out as I am thinking of getting one of these units myself.
chris2 is offline   Reply With Quote
Old October 9th, 2006, 17:41   #3
burpod
teh stallionz!!1
burpod's Avatar
actually, i have the same question - i know how it installs with the manual tranny, easy, mount it to the battery holder (which i did on my 5spd jetta), but on the automatic (06 golf), the tranny is in the way. i thought i read on the automatic it mounts (with the tdiheater.com kit) behind the intercooler. is there any other place to put it? i haven't taken the wheel well out to see about a mounting space there... but it seems out of the way, but i can't figure out another space where it will sit low enough...
82 rabbit AHU 17/22 26psi ported head, 11mm pump, pp764s, franko6 cam, custom ce2 wired, vwmikel tuned
1998 jetta AHU 17/22 26psi pp764s etc
vwmikel tuned
88 scirocco
AHU 2056vl build... delayed...05 jetta tdi & 06 golf tdi
burpod is offline   Reply With Quote
Old October 10th, 2006, 10:57   #4
red golf tdi
Fuel Economy: 53/48/42
Our custom kit for the A4 tiptronics mounts under the oil cooler.
Terry
1999.5 Golf TDI 2 door 402K; Owner of FrostHeater-Custom Engine Heater Kits
29+ different heater kits available for Volkswagens. Got Heat? Be warm this winter! http://www.FrostHeater.com
red golf tdi is offline   Reply With Quote
Old October 10th, 2006, 11:06   #5
burpod
teh stallionz!!1
burpod's Avatar
ahhh, thanks. that makes more sense i didn't think i saw space there, but i'll take another look....
vwmikel tuned
88 scirocco
Old October 10th, 2006, 12:02   #6
red golf tdi
You should come down, and I'll put one in for you no charge labor. I need to test-fit our new stainless steel bracket for the tiptronics anyway.
Terry
Old October 10th, 2006, 12:31   #7
burpod
teh stallionz!!1
burpod's Avatar
terry - sent a pm. but i don't think it will work out as i'm installing a pd134 oil cooler and doing an oil change at the same time (while the coolant and oil are both drained), so it might be too much of a hassle and not the standard fit....thx tho
vwmikel tuned
88 scirocco
Old October 13th, 2006, 17:46   #8
casta_baga
casta_baga's Avatar
thanks ..
I just bought one today at canadian tire, very cheap in fact...
i looked thought the link u gave me..
looks easy...
i have to install it quick because the winter's coming
I'll post the results
Old October 16th, 2006, 06:54   #9
wolfsburg
TDI(s): 06 Golf
Originally Posted by casta_baga
thanks ..
looks easy...
You purchased one at Canadian tire...what is the part number???
2006 Golf TDI
2001 Jetta TDI
wolfsburg is offline   Reply With Quote
Old November 16th, 2006, 18:44   #10
casta_baga
casta_baga's Avatar
hello Wolfsburg...
I purchased in Edmonton a zerostart 1000watts with a model number 3305002A...
I haven't installed it yet unfortunately since I came to Edmonton I'm always busy, looks like but..
do you have anything to had on my reply?
thanks
Old November 18th, 2006, 15:41   #11
Vulcan
Vulcan's Avatar
Is there a mounting change on 2004 Jettas? I wias looking at the instructs proved here and I don't have that bolt on the corner of the battery tray on my car (that I can see/feel).
2004 VW Jetta TDI Sport
Vulcan is offline   Reply With Quote
Old November 19th, 2006, 10:33   #12
TDI_YWG
Fuel Economy: really, really.....great
You will have to drill a hole through the battery tray. Just make sure that you take in to account where the battery sits on the tray or you will go to put your battery back in, and d'oh!
Scott
2003 Golf GLS TDI
2001 T4 California Exclusive 2.5TDI
TDI_YWG is offline   Reply With Quote
Old November 23rd, 2006, 21:11   #13
red golf tdi
Yes, the mounting bolt was removed by Volkswagen mid-2001, and then for the PD engines in 2004 VW changed the layout under the hood which requires a specific kit for the PDs. We offer the specific kits for the 2004 to 2006...one for the manual, one for the automoatic.
Terry
Old November 25th, 2006, 15:11   #14
backhoeken
Do they have a pump or something in them to push the water to the engine
backhoeken is offline   Reply With Quote
Old November 25th, 2006, 15:20   #15
burpod
teh stallionz!!1
burpod's Avatar
it circulates simply by convection. this is why you want to mount it in a low spot in the coolant system, so the warm coolant rises up easier. if you buy the zerostart heater itself it's really easy to make/find a mounting bracket yourself...
vwmikel tuned
88 scirocco
Page generated in 0.15726 seconds with 9 queries
[Output: 123.43 Kb. compressed to 102.26 Kb. by saving 21.17 Kb. (17.15%)]
