Old October 3rd, 2006, 13:29   #1
progolfer_20
progolfer_20's Avatar
Fuel Economy: 40-50
Default Fixing Headliner in a 96 Passat??
My headliner is drooping down pretty bad in my 96 Passat and I want to remove the cloth, remove the cardboard and scrape the old glue off of the cardboard then use some 3M Spray glue for upholstry and reattach the fabric to cardboard. I just cant figure out how to remove the cardboard headliner, how do you do it?
Travis
F-15E Strike Eagle
2010 Toyota FJ Cruiser
2012 Jetta TDI
progolfer_20 is offline   Reply With Quote
Old October 3rd, 2006, 22:10   #2
TDI Jim
Default Headliner repair
I am in the same boat on my '97 Passat TDI. I just bought headliner material at Jo-Ann's fabrics, but have been too busy replacing my turbo and oil and water pumps, etc. to get to it. My guess is the cardboard stays in place and you put the headliner in as is. It is too big I would guess to pull it out of the trunk. I will wish us both good luck!
TDI Jim is offline   Reply With Quote
Old October 5th, 2006, 05:20   #3
beetle1963
the headliner comes out the front pass. side of the car. all the trim has to come out first then the cardboard. local shop charges about $80to$120 to do the whole thing
1996 passat 190K
beetle1963 is offline   Reply With Quote
Old October 5th, 2006, 17:37   #4
ninedee_golf_tdi
Some jobs arent worth doing yourself. Find an upholstery shop and let them do it all. I had 2 headliners done 2 years ago, and both are coming unglued. Both are going back to the guy who did it and they are going to do it again for free.
ninedee_golf_tdi is offline   Reply With Quote
Old October 7th, 2006, 19:59   #5
steve_s
When beetle1963 says "all the trim has to come out first" he isn't kidding. been there done that. Once the trim around all 4 doors, the rear pillars, lights/switches/sunroof control are out, the headliner is a piece of cake.. Think about doing your rear struts while you're in this deep; much of the same rear trim has to come out for the struts!
steve_s is offline   Reply With Quote
Old October 8th, 2006, 17:06   #6
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Please post pictures of this "suicide" door conversion on your B4.
Svante Arrhenius 1896
Old October 10th, 2006, 09:54   #7
trhaverstock
Default Which fabric brand and color though???
I have the same problem on my 96 Passat and want to do this. I read up on some past threads and think I understand how to do it (it looks like a pain) but want to order a fabric color that most closely matches the stock so I don't have to redo the sunroof. Can anyone post where they got theirs and the color name if it was darn near an exact match? I have the beige interior. -T
trhaverstock is offline   Reply With Quote
Old October 11th, 2006, 05:12   #8
fastvicar
fastvicar's Avatar
Fuel Economy: 51/44/41
Having pulled my headliner out, removed the adhesive and re-attached using a good 3M adhesive (good = $17/can) only to have the bugger fall down within 3 weeks, I can tell you that I will have the local auto upholstery shop do it for me next month. If I can make an appointment in time.
It's pronounced "vicker"
fastvicar is offline   Reply With Quote
Old October 11th, 2006, 16:11   #9
progolfer_20
Fuel Economy: 40-50
I just called around town and found a place to recover it for $85. Some other places were charging around $150.
F-15E Strike Eagle
2012 Jetta TDI
Old October 12th, 2006, 06:46   #10
fastvicar
fastvicar's Avatar
Is that the price if you take it out or them?
Old October 12th, 2006, 19:03   #11
2TDIguy
2TDIguy's Avatar
Also, when you need a windshield is a good time to drop the headliner out. I have a friend that runs a body shop so he can cut the glass out and let me pull the headliner, then put the glass in.
2002 Jetta TDI, 2005 B5 TDI
2TDIguy is offline   Reply With Quote
Old October 13th, 2006, 13:10   #12
progolfer_20
Fuel Economy: 40-50
$85 is to pull the headliner cardboard out, clean it and then recover it.
F-15E Strike Eagle
2012 Jetta TDI
Old October 14th, 2006, 17:12   #13
redtdi966
I know it sounds hoky but, I got headliner spray glue and then bought 1-inch wide x 48 in aluminum "spars". I cut them to span the headliner in three - four places, painted them the same grey color as my headliner. SO far it has held up, that's all I want. If I could a shop to do entire job for 120 I'd jump on it!Q
bruce
2003 jetta wagon 4-cyl , 2012 jetta sedan auto gassers -- Done with diesels "cost of ownership"
redtdi966 is offline   Reply With Quote
Page generated in 0.14818 seconds with 9 queries
[Output: 106.39 Kb. compressed to 87.96 Kb. by saving 18.44 Kb. (17.33%)]
