Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Vendor & GroupBuy items for sale VW TDI/Diesel related items for sale by vendors and Groupbuys. The only commercial posts to these forums are that of Vendors with TDI related equipment. To start a post, you must be a Registered Vendor. You may periodically post a note about products you may have for sale/services so long you indicate clearly you are from the company selling these products/services. The right to discontinue this practice & remove excessive posts remains with the operators of TDIClub. Please not there is also a webpage of TDI Vendors" Group-buys are permited if sponsored by a registered vendor.
Old September 28th, 2006, 17:04   #1
LanduytG
I can sell you the Espar Hydronic D5 S for $1050 and the install is not bad at all. We installed a couple on TDI's. One was in Toronto I beleive and I forget where the other was. Anyway that includes 7 day timer and if you don't want that we will take $110 off the price. They fit in the drives side fend well. Just remove the fender liner and their you go. I could have it installed in about 4-5 hours or so, may be a bit more since its been a couple of years since I've done one. At 17K btu it will flat run you out of the car and heat everything very fast. You don't have to worry about finding 110V and then hoping the breaker does not trip. Also since this is only a 6 quart system it will heat the water to 165* then cut back to low until it gets to 175*. Then it will shut the burner off but still continue to circulate the water. When the temp gets down a bit it will fire back up. If you want something that will keep you warm when parked this is it.
Greg
TDI CLUB Supporting Vendor
Check out our
Online Store
Order Cat Filter Here
Order Fumoto Valve Here
1-888-306-4255
LanduytG is online now   Reply With Quote
Old October 7th, 2006, 21:47   #2
sledhead1
does it include any install kit, the tank pick-up and fuel hoses
sledhead1 is offline   Reply With Quote
Old October 8th, 2006, 04:37   #3
PDwagon
Greg
Peterborough actually Greg, not Toronto, but close enough I guess.
PDwagon is offline   Reply With Quote
Old October 8th, 2006, 11:42   #4
LanduytG
Yes it comes with everything you need. Installs under the front left fender liner.
Greg
Check out our
Online Store
1-888-306-4255
Old October 8th, 2006, 11:43   #5
LanduytG
Hows it working?
Greg
Check out our
Online Store
1-888-306-4255
Old October 13th, 2006, 09:17   #6
Jetta4Jeff
Jetta4Jeff's Avatar
Fuel Economy: 48-58 imperial mpg.
Question About your installed Espar unit...
Could you post some pix of the unit?
Jeff Melnyk
-Silver '04 J TDI wESP/CWP, M5, Black Leather, Onstar, TDIClub plate frames, ScanGauge II.
-Mods: TDIheater, PV200 ccv, CAT ff, ARCTIC FOX fuel htr., CCFL in trunk, E-codes, 5 BL's...
-Pending: 'Loki' GP controller with 11v GP's. A fix for VW's botched BEW GP recall.
-Deleted: Muffler and Cat., 'OEM thermo. tee', fuel tank vent.
Jetta4Jeff is offline   Reply With Quote
Old October 15th, 2006, 13:45   #7
LanduytG
I don't have any that are installed in the VW. If you just want to look at the unit just go here. www.finetuningperformance.com
Greg
Check out our
Online Store
1-888-306-4255
Old October 15th, 2006, 15:11   #8
Slave2school
Slave2school's Avatar
Not a bad price, I got quoted $1400+tax up here (but "it includes the 7 day timer", said the sales man...lolololol)
Jon
http://belleville.kijiji.ca/c-ViewAd...AdId=203158470
Civility, something that seperates us from the apes....sometimes.
Slave2school is offline   Reply With Quote
Old October 15th, 2006, 18:26   #9
michigandon
michigandon's Avatar
TDI(s): 1998 A3
Fuel Economy: 44 best, 38 worst
Can you install in a Sprinter?
Also, do you have (or can you get) the D2 or D4 hot air units? Been contemplating the installation of one of those in the motorhome.
Thanks,
Don
1998 A3 Black
2005 Sprinter 118, white cargo, wife's ride.
1973 Travco 270 motorhome repowered with Cummins 6BT and 518 automatic OD tranny from wrecked 1993 Dodge D250.
michigandon is offline   Reply With Quote
Old October 17th, 2006, 11:51   #10
GCMarx
GCMarx's Avatar
I haven't been able to get an answer out of Espar -- can you run this on B20, and can you use the remote if you don't have the timer?
Thanks,
Gordon
GCMarx is offline   Reply With Quote
Old October 17th, 2006, 12:53   #11
LanduytG
All kits Hydronic kits I sell includes 7 day timer. Yes they can be installed in the Sprinter and we can get all Espar heaters. We sell many of the D2/D4 Airtronics. B15 is OK but any more and you my have trouble. I have many that that use B10 in California in both air and water heaters.
Greg
Check out our
Online Store
1-888-306-4255
Old October 17th, 2006, 16:48   #12
GCMarx
GCMarx's Avatar
I'm cheap. And if I can use the remote and not the timer, I will be a happy, cheap, and warm man.
Old October 17th, 2006, 17:53   #13
LanduytG
Yes you can use a remote. I have a truck with a remote, since it does not use the trunk button I use it to start the Espar. Plus its 2 way so I know if it started or not.
Greg
Check out our
Online Store
1-888-306-4255
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.11825 seconds with 9 queries
[Output: 107.97 Kb. compressed to 89.16 Kb. by saving 18.80 Kb. (17.42%)]
