Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old September 25th, 2006, 12:48   #1
brianstrange
Default First fill up
Well, I just got 360 miles out of the first 9.97 Gallons (topped). Im not sure if they filled it to the top at delivery, so I'm assuming 36 MPG. I drive both suburban and highway at about 50% each. I drive around 70-75 mph on the highway. Should I expect this to go up as it breaks in?
06.5 DSG TDI PKG 1
08 Ford Explorer, 06.5 Jetta TDI DSG PKG1, 94 Mustang GT Convert, 92 Jeep Wrangler, 67 Mustang Convertible 66 Bronco U140 68 Bronco U150 13 Audi A6 3.0T
brianstrange is offline   Reply With Quote
Old September 25th, 2006, 13:00   #2
Mike_M
Mike_M's Avatar
Fuel Economy: 56/47/41
06.5 DSG TDI PKG 1
1) One tank (much less 2/3 of a tank) isn't really a fair test. Fuel foaming, small variations in pumps, the uncertainty about whether it was topped or not at the dealer...all these constitute errors that can make a big difference in calculations.
2) This HAS been asked before about 500 times. Check the existing threads here for answers.
3) It's brand-new...give it 10,000 miles before you start really payin attention to the fuel economy. It'll take that long to start to break in and give you something resembling representative fuel economy. So, in a sense, the answer to your question is "yes".
4) Break it in properly. Use DrivBiWire's break-in procedure, at least for the first 10-30K miles, then gradually switch over to gdr703's modified break-in/driving for MPG. Do a search, and they should pop up.
Welcome aboard!
Mike
2002 Jetta GLS & 2003 Golf GL, for sale soon!
2010 Golf, white 2-door, 6-speed stick, 8k miles, avg 42MPG, SHINY!
Mike_M is offline   Reply With Quote
Old September 25th, 2006, 15:07   #3
MrErlo
MrErlo's Avatar
Fuel Economy: lifetime 45.52, best 61.18
Smile try some BioD in there
brianstrange,
have you considered BioDiesel? you should be aware that any blend higher than B5 (5% bio and 95% petro) will void your VW warranty. however, people report higher MPG when using a BioD blend due to increased lubricity and cetane. some people with new TDIs even use B100 which is awesome. if you're not comfortable risking your warranty, that's perfectly acceptable. at least learn about BioD, and try a B5 blend. i always like to suggest to new TDI drivers to try BioD. if it's not for you, no problem. welcome to the club.
MrErlo is offline   Reply With Quote
Page generated in 0.13457 seconds with 9 queries
[Output: 56.17 Kb. compressed to 50.71 Kb. by saving 5.46 Kb. (9.72%)]
