Old September 23rd, 2006, 09:12   #1
vw4life
vw4life's Avatar
Fuel Economy: 7.4 L/100km 75% city (~32 MPG US)
Default Ventectomy gone awry?
Hmmm, yah. So I was pushing that little bugger everyone says is so stiff and it busts off and rattles down fuel filler neck into the tank. OK, it could be worse. I don't suppose it will cause any harm down there...
My bigger question is did I complete the venectomy? Is my tank vented now or not? The car is so new to me I don't have any idea how much fuel should be going in at any stage of the needle.
Funny thing is that my buddy showed me his vent mechanism that was removed and the part I saw swirl down into the tank looked to be only half of that- the lever part. Parhaps the flapper part is still in the vent assembly? I dunno.
I fished around with L-angle hex keys to see what I could feel in there. Nothing appeared to be spring loaded anymore...
At that point I had used 3/8 of a tank- I filled up to the brim with 31.7 L - thats 8.4 g for some of you. So, assuming a 2 gal vent capacity, I think that I filled the vent- unless the top of the tank IS much bigger than the bottom disregarding vent space. However, my passat fuel guage appears to be more steady than my Golf. So my feeling is that it is vented. But it sucks to be unsure.
Any words of wisdom for me?
A suggestion for all who might attempt this. Stuff a big rag down your filler neck before you start a ventectomy. That way you will be sure not to drop anything down there.
\\\ David /// 2005 B5.5V TDI Stonehenge Grey - Manual Headlamp Leveling - Aspherical Mirrors - Ventectomy trouble? - Fuel Economy - Euro trailer hitch: towing, install, safety chains, towing, wiring, euro bike rack! +Factory de-tooef's, Airlift
vw4life is offline   Reply With Quote
Old September 23rd, 2006, 17:23   #2
TDI_Jeffster
Fuel Economy: avg 38-40
I feel your pain. I did the same thing last year!! So far, no problems. And no, you didn't complete the ventectomy. What I didn't understand at the time is you're not supposed to push it down (towards the gas tank) but back (towards the rear of the vehicle.
And you are correct, the piece that broke off is just the lever piece. The rest of the device is still installed in place.
Jeff
2004 Passat TDI w/ RC stage 2 & boostvalve
TDI_Jeffster is offline   Reply With Quote
Old September 23rd, 2006, 17:47   #3
vw4life
vw4life's Avatar
Sooo... is it possible to complete the job?
Old September 23rd, 2006, 18:37   #4
bigEZ
did you check this out and follow it?
http://pics2.tdiclub.com/gwillie/VW/...tomy/index.htm
you remove the tab button, the black ring and the spring. the white part goes back (or stays in).
when i did mine, i could not get the vent out either, so i ended up just pulling the button out with pliers. luckily, i was able to keep the pieces out of the tank.
when you fill up now, the pump will still cut off before it is full, but the tank will automatically vent itself, as opposed to your having to push the vent button. you can fill the tank all the way up until you see the fuel (not foam) in the filler neck.
bigEZ is offline   Reply With Quote
Old September 23rd, 2006, 20:04   #5
vw4life
vw4life's Avatar
OK - I did it! When we first tried I had viewed the photos several times- but we went to do it we didn't have the reference and couldn't find the release tab.
As some others did, I put a large allan key in vice grips and while pressing the release it poped out.
I can see how it really can be a 1 minute job.
Ventectomy tips for total newbies:
1.) View photos thoroughly, don't operate from memory.
2.) ensure you can locate step #7 in the photos and do that. I just jammed a small flat head in there so I didn't have to hold it.
3.) stuff something down your filler neck to plug it just in case.
4.) spray in some WD40
5.) push
maybe when I have a low tank of fuel I will pop the top off the tank and try to find the bit that slide down.
Now, I can't wait to fill up again. Got to wait 1000 km.
Old September 24th, 2006, 18:02   #6
kahuna
Fuel Economy: Presently working on that.
Wink
Glad you finally were able to get the job done right.
Vancouver B.C.
2003 Golf GLS ALH: Ventectomy,
Early 60's mpg
kahuna is offline   Reply With Quote
Old August 15th, 2011, 18:26   #7
dbranson
Fuel Economy: (15/18 4x4) -> (44/57 Jetta)
Thanks for the excellent how-to with links to the pics! I did a ventectomy on my 2000 Jetta tonight, filled up, and got an extra 2 gallons in. So cool. I'm a software guy, and even for me it was easy. Normally, I would expect a mod like this to cause the left front tire to leak or something, but not this time.
Don Branson
http://coders-log.blogspot.com/
dbranson is offline   Reply With Quote
Old August 15th, 2011, 19:34   #8
Dean
Old thread is old, but you're supposed to pull the knob thingy towards you, not push it.
Dean is offline   Reply With Quote
Old August 16th, 2011, 13:31   #9
dbranson
It's true it's old, just happened to be the first one with pictures that I stumbled across when I searched for ventectomy. Once the white plunger is out of the car, it's easy from there, even if the push/pull guidance is awry.
Don Branson
Old August 16th, 2011, 14:31   #10
vw4life
vw4life's Avatar
glad my trial and error has helped other people.
Old August 16th, 2011, 17:35   #11
dbranson
Personally, I think that's why we have them, so that we can help the next person. So, thank you for making the time to pass along what you learned.
Don Branson
Page generated in 0.16079 seconds with 9 queries
[Output: 105.18 Kb. compressed to 89.15 Kb. by saving 16.04 Kb. (15.25%)]
