Old September 18th, 2006, 20:26   #1
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
Fuel Economy: 57/43/32
Default HOW TO tamper with the fuel temp sensor like KERMA
For more info on what this mod does see the thread Kerma started about it here.
Since we got our first snow of the season I figured it was time to fake out the ECU to think my fuel is extra cool.
I bought a pack of 2200 ohm resistors from Radio shack, they were $.99,
I started by cutting the tape back on the wiring harness where it attaches to the injection pump,
Here is the wire I used, yellow with blue stripe, #7, it is quite thin like much of the wiring under the hood,
Oh yea, it's a lot easier to do this if you remove the vaccum resevoir, two 6 mm allen bolts.
First I cut it and tried to just push the thin wire of the resistor into the wiring insulation, but that was not going to happen, maybe if it was 90* + out, but it wasn't. So I soldered it in, I'm not sure hot hot resistors can get so I did the soldering as fast as I could,
I then coverd it all up with liquid electrical tape,
Here is the first coat, I'll put on a second coat tommorow,
before resistor fuel temp reported in VAG-COM was 16.2* C after the resistor it is 2.7* C
BEST FUEL COOLER EVER
You can see on the right side of the screen the coolant is 16.2* C the car hasn't run since yesterday,
Hp vs. TQ
jackbombay is offline   Reply With Quote
Old September 18th, 2006, 20:42   #2
Slave2school
Slave2school's Avatar
I had to go out and compare! I get 7.2*C for the fuel temp and 22.6*C for the coolant temp (car has not run today either). Your how-to is great Jack. My IAT was reading 5.9*C That is a cheap intercooler too
Jon
http://www.pyramining.com/referral/nhmb3x4a2
Civility, something that seperates us from the apes....sometimes.
Slave2school is offline   Reply With Quote
Old September 18th, 2006, 22:20   #3
TDIpurdue
Fuel Economy: 38city / 46hwy
what is the advantage of the computer thinking the fuel is cooler? wouldnt it inject less as cooler fuel is thicker?
Boiler Up! Go Purdue!
- Evry: 680ohm, Wett chip, Tokico Illumina Shocks/Struts/Springs
TDIpurdue is offline   Reply With Quote
Old September 18th, 2006, 22:47   #4
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
When fuel gets hot injection timing is retarded which raises EGT and lowers efficiency and power.
Hp vs. TQ
Old September 19th, 2006, 00:19   #5
gottdi
gottdi's Avatar
Fuel Economy: 45mpg
Nice mod. You really want that much difference? Seems a bit much. I'd think a little less would be better but then again I am only learning.
Hey! where are you located? Is that Colorado? Snow! Nice!
Just because you can does not mean you should. But then again...........
If you don't get it, be patient, you will
gottdi is offline   Reply With Quote
Old September 19th, 2006, 00:21   #6
skid9uk
skid9uk's Avatar
TDI(s): 1998 110
Fuel Economy: average 49mpg
would this be ok on my car? i can get what ever resistiors i need from work today do you notice a power increase?
Cheers
1998 Passat 110. upsolute stage 1 chip to 143bhp, modifyed airbox, sports panel filter, front mount intercooler, Dawes device, boost gauge ,Pagid fast road pads, Allard EGR delete plus PD150 race pipe, PD150 inlet manifold,18" RS4 Alloys, Audi S4 front strut brace, Home made intercooler water sprayer, custom ccv.
Coming very soon sachs organic clutch, vnt17,PP764's,aligator tune.
WANT A NEW MOBILE PHONE? TRY MY SITE @
www.allmobilez.2u.co.uk
skid9uk is offline   Reply With Quote
Old September 19th, 2006, 06:55   #7
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
I'm in south east Idaho, to quote an old farmer here "we've missed a few summers but we've never missed a winter."
I've only ben on a sort drive so far,the car didn't even fully warm up, after a longer drive where the fuel really warms up I think this mod should keep you from losing power due to retarded injection timing, I'm thinking it'll help MPG more than power.
Hp vs. TQ
Old September 19th, 2006, 07:14   #8
bam_bam_dip
bam_bam_dip's Avatar
Fuel Economy: 51.3, 700 Club
Now it just needs a catchy name........!!!!! You know, ventectomy, evry, etc.....
Come up with a few and run a poll.
Want a good read? Me & my Red Rider Against the Squirrels!!
My Father's house is a big, big house.
bam_bam_dip is offline   Reply With Quote
Old September 19th, 2006, 07:25   #9
Slave2school
KFC Mod
Kerma Fuel Cooler Mod
Jon
Old September 19th, 2006, 07:37   #10
bam_bam_dip
Oooooooh, that's good. The first one out of the bag might just be the winner.
Old September 19th, 2006, 08:37   #11
fishmando
fishmando's Avatar
Hmmm.... this sounds pretty nice! So do chips not do this on there own?
fishmando is offline   Reply With Quote
Old September 19th, 2006, 08:52   #12
baun
TDI(s): 2000 golf
Originally Posted by Slave2school
KFC Mod
haha yes
unitronic stage 1+ chip, kerma 3in dp , 3in straight pipe, intake, FMIC, vf engine mounts, egr delete, 42 draft design catch can and vacuum manifold, boost controller.
HStunung.com KermaTDI.com
baun is offline   Reply With Quote
Old September 19th, 2006, 09:33   #13
clove911
Fuel Economy: 52 mpg/42 mpg
that was my first thought. y couldn't a tuner reprogram the characteristics of the ecu to do the same thing?
Crisis is opportunity!
No longer own a TDI, but new car will blow you away!
clove911 is offline   Reply With Quote
Old September 19th, 2006, 10:18   #14
gottdi
gottdi's Avatar
Fuel Economy: 45mpg
KFC Mod
That's got my vote!
Even if a chip can be made to duplicate the same results this mod would be great for those without a mod or with a tuning box. Since neither have the ability to tune it out. Excellent Mod.
Old September 19th, 2006, 10:29   #15
bam_bam_dip
Hey Jack, did you do the Intake Air temp sensor as well?? If so, add those pics to your OP.
KFC Mod = Finger lickin' good!
Page generated in 0.16788 seconds with 9 queries
[Output: 130.92 Kb. compressed to 109.06 Kb. by saving 21.85 Kb. (16.69%)]
