Old July 12th, 2016, 19:06   #46
G3TDI
Originally Posted by Stevesdirtybunny View Post
Why not just use the alh pump and bracket instead of going threw the trouble of machining the old ahu bracket not sure if there the same or not but if someone knows it be great because I can get a 11mm alh pump off an automatic and the bracket if it bolts right up that would be great
It's not possible to use the ALH one it's completely different!
If you need an AHU bracket professionally machined PM me and I can have it arranged for you!
G3TDI is offline   Reply With Quote
Old November 23rd, 2016, 19:59   #47
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
Swapped an ALH 11mm onto the red death today. Figuring out how to de-pin/re-pin the harnesses was basically the hardest part of the swap. everything else just falls into place if you have the bracket machined properly.
i made a terminal tool from a harbor fright tweezer set but i only needed the smallest one of the set. i just looked at this guys video ( https://www.youtube.com/watch?v=bbW9Yc36RPE ) and figured i could find something that would work at harbor freight or walmart. notice the tips of the tweezers bent inward (1st pic) which press the tabs inward (3rd pic). Pin swap list also shown in 1st pic, stolen from PAGE 1 of this sticky.
2003 Jetta TDI - 11mm IP, R520s and FMIC from the Red Death, HE221W (shooting for 26PSI), 1.8T pancake, DIY 3" OMI, still working on the DIY tune... its a learning process.
1996 Passat TDI - "Red Death" RETIRED. Had: Malone stg 1, 11mm IP, R520s, GT15/17 hybrid, FMIC, ETC
1997 Passat TDI wagon - Running donor or beater for sale, rough body
ketchupshirt88 is offline   Reply With Quote
Old July 31st, 2017, 14:31   #48
jimbote
jimbote's Avatar
Just used this thread to repin an injection pump connector but i'm putting an entire ALH into a B4V so i repinned the B4V wires into an MKIV headlight connector (same as mk4 harness side pump connector) ... great guide! thank you
Page generated in 0.13589 seconds with 9 queries
[Output: 57.75 Kb. compressed to 52.40 Kb. by saving 5.34 Kb. (9.26%)]
