Old May 26th, 2011, 12:32   #31
16vjohn
Seems like a lot more work than just rebuilding the old pump... it's really not that hard to do.
16' Fusion Energi // 12' Honda Odyssey
Retired: 15' Jetta TDI 45k // 13' Passat 22k, Buyback // 01' Jetta TDI 177k // 98' Jetta TDI 291k // 00' Jetta TDI 240k // 91' 300D 2.5T // 90' Jetta TD
16vjohn is offline   Reply With Quote
Old January 17th, 2012, 06:08   #32
JFettig
JFettig's Avatar
Originally Posted by G60ING View Post
If I had an 11mm pump on a 1z/AHU I would drop down to 50k belt changes or switch to the wider belt setup.
I just want to note that the AHH belt is not wider, it has a different part number, same goes for the tensioner, but I cannot physically see a difference between the two.
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old January 22nd, 2012, 12:52   #33
98tdi
Fuel Economy: 41~42.5
Doing this swap very soon to bring my 97 passat back from the dead!
98tdi is offline   Reply With Quote
Old March 5th, 2012, 10:00   #34
burpod
teh stallionz!!1
burpod's Avatar
back from the dead... again i'm planning an 11mm pump on an ahu build. related question, can an 11mm alh pump head be installed on an ahu pump? or is there more to it than that? i could get a 11mm pump head for a good price, and have a good ahu ip core....
82 rabbit AHU 17/22 26psi ported head, 11mm pump, pp764s, franko6 cam, custom ce2 wired, vwmikel tuned
1998 jetta AHU 17/22 26psi pp764s etc
vwmikel tuned
88 scirocco
AHU 2056vl build... delayed...05 jetta tdi & 06 golf tdi
burpod is offline   Reply With Quote
Old July 21st, 2012, 14:16   #35
drejck
Fuel Economy: 5,2l/100km
""Fortunatly we have an AHH Passat in the USA with an enthusiast for an owner:
JFettig's Passat & pictures:""
IS THIS 11MM PUMP TOO??
drejck is offline   Reply With Quote
Old July 21st, 2012, 19:18   #36
JFettig
JFettig's Avatar
yup
Old August 29th, 2012, 11:19   #37
smokey_bearme
TDI(s): 2002 jettas
I have a really weird question I have a 1998 jetta ahu and rebuild the injection pump and the bottom of the quantity adj the part that slides into the sleve has like a ball end on it, has broke clean off I have a pump from a 2001 jetta ahl and I was wondering if i could just switch the quantity adjuster or be cheaper to machine the ahl pump to work
smokey_bearme is offline   Reply With Quote
Old August 29th, 2012, 14:07   #38
honda_vtec2
honda_vtec2's Avatar
Fuel Economy: 5L-5.2L/100km 70%city/25%hwy/5%driveway
Just like to add: Since i've done this mod. I've put about 80k or so on a used ALH pump without issue.
[2000 Golf ALH TDI 5spd] [SG2 with boost guage] [.205 Smog injectors]
honda_vtec2 is offline   Reply With Quote
Old August 29th, 2012, 16:07   #39
G60ING
G60ING's Avatar
How many miles on the ahu belt?
G60ING is online now   Reply With Quote
Old September 18th, 2012, 22:08   #40
libbybapa
Holy smoke, all you guys shimming the pump over are doing it the hard way. You just have to adjust the belt tracking by rotating the pump bracket. Sprocket down, lines up makes the belt track closer to the block.
libbybapa is offline   Reply With Quote
Old September 19th, 2012, 05:05   #41
JFettig
JFettig's Avatar
Here are some upgrade parts for those doing this swap
AHH timing belt tensioner
028109243K
028109243H - cross references with INA part number to be the same, but cheaper
INA 531 0524 30
CONTITECH V55736
Both VW part numbers are available at worldimpex
AHH timing belt
028109119AA
CONTITECH CT945
DAYCO 94941
GATES 5622XS
I have not found a US distributor for these, RyanP can source them.
Old September 26th, 2013, 22:13   #42
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Andrew Libby is right....no shim BS needed...My ALH Pump swap is washer/shim free...
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
GTiTDi is offline   Reply With Quote
Old September 27th, 2013, 04:11   #43
burpod
teh stallionz!!1
burpod's Avatar
no shims for me either. went in with no issue at all. love it
vwmikel tuned
88 scirocco
Old September 27th, 2013, 11:52   #44
Abacus
That helpful B4 guy
Abacus's Avatar
Seen any difference over the ribbed AHU pump?
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old July 12th, 2016, 18:17   #45
Stevesdirtybunny
Why not just use the alh pump and bracket instead of going threw the trouble of machining the old ahu bracket not sure if there the same or not but if someone knows it be great because I can get a 11mm alh pump off an automatic and the bracket if it bolts right up that would be great
Stevesdirtybunny is offline   Reply With Quote
Page generated in 0.17493 seconds with 9 queries
[Output: 125.91 Kb. compressed to 104.59 Kb. by saving 21.32 Kb. (16.93%)]
