Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old September 11th, 2006, 11:35   #1
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Default What is Engine Lugging?
I've searched my reference material, but have found very little/no information about lugging.
Does anyone have a defined set of conditions where lugging occurs?
I assume it has something to do with the ratio of power stroke cylinder pressure to compression stroke cylinder pressure at any given point in the stroke, and as that ratio approaches 1:1 lugging occurs, the farther away from 1:1 it is, the smoother it will run.
This is just my guessing here - Does anyone know?
03 Jetta, Cat 2u Fuel Filter, DG Steel SP with MOGolf Mod, DG Ultra SS, 3" downpipe, 4" exhaust, CC Vent, 0.681 5th, Amsoil EaBP110 Bypass, Elf 506.01, Redline D4, Boost & EGT, Euroswitch, PD Lift Pump, EGR Delete, PP502 DBW'd, RC6, ScanGaugeII, BB Dual Diaphram Clutch, 3" Turbo Intake Tube, VNT 17/22, 3 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Access Mod, 11mm IP, Monster Mats, 205/70/15's (37.4/53.0/75) Monthly MPG Links
Fix_Until_Broke is offline   Reply With Quote
Old September 11th, 2006, 12:28   #2
MrErlo
MrErlo's Avatar
Fuel Economy: lifetime 45.52, best 61.18
i'm sure someone has a set of theoretical numbers for when lugging will occur, my advice is only from personal experience.
[quote=Fix_Until_Broke]MrErlo
So if I'm in 1st or 2nd idling along a flat road (in traffic for example), that's lugging?
I don't suspect that it is quite this clear cut.[/qutoe]
if the car is traveling slower than the engine, then you're lugging. if you're rolling to a stop sign in 2nd at 25 mph, you're clearly not lugging, but if you were trying to do that at 5mph, you'd be able to feel the engine trying to pull you forward and not being able to do so b/c it does not have enough fuel. like i said in all gears this happens for me as i drop below 1200RPM, slightly lower if i'm decelerating by using the breaks heavily.
2003 Golf 4dr, 109k
Omaha Biofuels Coop
VNT17, 11mm, G60/VR6, FM-100, side mount heater
MrErlo is offline   Reply With Quote
Old September 11th, 2006, 12:41   #3
wjdell
Fuel Economy: avg. 41.93 high 46.32 low 34.6
A good way to look at lugging is to remember riding your bike. When you first took off in a high gear. Going up hill and in high gear you feel the load on your legs. To running smoothly and not pedaling to fast but not working so hard that they ached.
Post your UOA data in the TDI UOA Database thread
http://forums.tdiclub.com/showthread.php?t=205814
~ USED OIL ANALYSIS ~ http://forums.tdiclub.com/showthread.php?t=190958
1.9 PD Jetta V ~ pkg 1 ~
DSG ~ 17" VV ~ 36/34 psi ~
ULSD ~ DG-BP90 - speed 39.2
hwy/city 83% / 17% ~
elev 58 ft / temp 72 F / humidity 76% ~ MPG 48.3 / 42.8 / 35.6
wjdell is offline   Reply With Quote
Old September 11th, 2006, 12:47   #4
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
From my experiences, lugging happens most (based on feel and engine sound) at less than 1500 RPM in 4th or 5th and trying to accelerate. 1st through 3rd don't exhibit the same feel/sound.
Trying to accelerate at less than 1500 RPM in 4th or 5th I might out well use my feet to try and help it along.
2003 Jetta TDI, healthily modified with 17/22. Mobil 1 0w40
Photos | Mods | CJ-4 Oils | Oil Analysis | AFE CAI | AFE CAI Video
Bob_Fout is offline   Reply With Quote
Old September 11th, 2006, 14:28   #5
MrErlo
MrErlo's Avatar
WJ and Bob are right. i guess i might have been describing a different engine condition, perhaps it's just a different type of lugging. when i roll down a hill in 5th then try to accelerate up the next hill at 35mph in 5th i have the same problem they're describing. gotta down shift, and heck... it's more fun that way.
2003 Golf 4dr, 109k
Omaha Biofuels Coop
Old September 11th, 2006, 15:07   #6
Brock_from_WI
Brock_from_WI's Avatar
TDI(s): 2003 wagon
Fuel Economy: 62/54/45
I know it's got to be the torque, but in all the gassers I used to drive I lugged them a lot, or at least I knew when I was doing it. Take our nice 1988 Mazda 323 hatchback. If I was in 5th and going up a 3% or better grade at 35mpg my speed would drop off and the car would slow and the engine would "chug". That is what I have always considered lugging.
The thing is I can do the same thing with the TDI and it doesn't seem to bog down and can even increase speed if I want to on that same hill in 5th.
My only guess would be when the engine can't produce enough power to accelerate in a given gear. My drive to and from work is all at 35 mph and I am in 5th once I hit 35 and cruise at 40 the whole way, even up that small hill, some might think I am lugging it, but the car doesn't seem to mind.
I am seriously considering the 5th gear swap for highway driving, but since have this drive I am a bit concerned the lower 5th might be to close to lugging on that hill or maybe even 40 mph with the lower gear?
Brock - 03 Jetta Wagon GLS, 5 Speed, silver, cold weather package, window tint, euro switch, ventectomy, trailer hitch, TDI heater, scangauge II
Brock_from_WI is offline   Reply With Quote
Old September 11th, 2006, 15:13   #7
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
What we described sounds what you're describing too.
What are your RPMS at 35 MPH in 5th?
Old September 11th, 2006, 15:17   #8
TurboBenz
TDI(s): Jetta
i wanna know how you can possibly be lugging the engine at 1500 rpm lol
Usually you feel it at around 1250 ish rpm (on flat ground and crusing of course).
TurboBenz is offline   Reply With Quote
Old September 11th, 2006, 16:30   #9
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
1500 RPM, 5th gear. Try and accelerate at a reasonble speed. Feel and listen to the motor.
Old September 11th, 2006, 17:01   #10
wjdell
Bob is telling you correct - if you get caught with your RPM's low you must accelerate very gradual. If it groans at all you needed to shift gears. Some areas I can roll along at 1500 in town with no grade. The minute you start to encounter that grade either you anticipated and starting getting those RPM's up or you better shift. You can feel it the seat of your pants when that crankshaft is lugging. If you are real sensative you feel the vibration, thats the clutch load on the crank.
Old September 11th, 2006, 17:48   #11
40X40
Experienced
Fuel Economy: 42,with a best of 47
Lugging an Engine......
http://www.cartalk.com/content/colum...August/07.html
Kinda geared toward a gasser but the basic theory still holds...Symptoms
may differ for a diesel. (above link)
Lugging an engine is laboring an engine in too high a gear.
If an engine cannot accelerate smoothly when requested then it
is being lugged.
The solution is to downshift, then accelerate.
HTH.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// You still cannot magnetize silver.// If you admire K. Marx, do not include ME in your WE// If you were the only entry, there wasn't a race.// Grammar and spelling really are important.// Typical drivers can't.//Sigs with ads are tacky.
40X40 is offline   Reply With Quote
Old September 11th, 2006, 20:04   #12
Fix_Until_Broke
All good responses/descriptions of what is felt/conditions during lugging. Having the 0.681 5th and a lot of 40-45 mph driving during my commute, I'm familiar with the feeling.
Why does the engine do this? What causes the excess vibration, shuttering, noise, etc? What is happening in the cylinder(s)? Why is what happens more pronounced at lower engine speeds? Why when pulling a trailer up a hill at ~2000 RPM in 5th at 100% throttle and loosing RPM does this not happen (or I don't feel it) and with no trailer at 1400 rpm and 15% throttle it "lugs"?
Sorry for all the questions, I appreciate all your replies, but am looking for something a bit more detailed/theoretical/conceptual.
Old September 11th, 2006, 20:07   #13
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
No that this helps...but I think lugging is bad for the motor mounts too.
Google might have some answers
http://www.google.com/search?hl=en&q...=Google+Search
Old September 11th, 2006, 20:08   #14
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: 48.6
Default Engine lugging
Is when the car bucks and the engine shakes. Short of that, it's not lugging, but still, it is not advised to request lots of power where the potential to lug is great.
As to what is happening inside the cylinders to cause the motor to shake? Hmmm...good question.
Guess: the maximum amount of fuel that can be *safely* combusted depends on how much air is ingested. At slow engine speeds, there isn't much air. At light cruising this is perfectly fine since you are burning less than maximum fuel. As you reach that limit where load is greater than the amount of power you can generate (based on that fueling limit), the motor protests because it is basically being asked to run in reverse. The load (say, a steep hill) is acting to bring your motor to a stop...if you let it, it would bring your motor to a complete stop and then turn it in reverse (ignoring gearing and the physical possibility for this particular engine...some engines can run in reverse) as you rolled haplessly downhill, backwards, screaming in your rearview mirror. And, since you are not injecting enough fuel to argue sucessfully with the hill, it wins.
Think of arm wrestling...if you are not as strong or stronger than your opponent, he wins and your arm hurts from exerting effort but being overwhelmed by load.
Constant Speed Road Load Power(v, others) =1/2*rho(T, rH)*CdA*cross product*(Vtrue air)^3 + Crr*M*g*Vroad + parasitic_load(Tengine, oil_visc, other)
Red is for Vector, Bold is for things you can change.
A few favorite things:..EnviroFit.. Modest Needs..NIST applet.. SHPEGS Project
Originally Posted by Testy_SOB
I discovered long ago that putting a rolled up sock in my pants is cheaper then buying more vehicle then I need.
nicklockard is online now   Reply With Quote
Old September 12th, 2006, 06:28   #15
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: Which car? There have been nine of them!
My opinion is that the condition is related to the duration of the combustion process within the cylinder and the amount of piston stroke possible in that amount of time at some given engine rpm.
At 1200 rpm the piston moves from TDC to BDC in .05 seconds. At 3000 rpm the time becomes .02 seconds. I believe the volume of fuel injected per stroke is related to the accelerator pedal command less than it is to the rpm signal. A foot on the floor acceleration request will have nearly the same fuel injected per stroke at 1200 as as 3000.
If that is true, then the pressure of the combustion is higher in the more slowly moving piston than in the faster one. The combustion event is in effect occuring in a more restricted volume. I believe the description of "lugging" is related to the relatively large combustion events in a more limited volume or in a shorter percentage of the piston's down stroke.
There are two quick resolutions to the condition: More piston speed (down shift for higher rpm) or less chamber pressure (reduce the volume of fuel injected by adjusting the accelerator pedal position).
2005 Passat B5.5 BHW (w/ factory toof deletions and RC-1)
1995 Cabrio A3 AHU (.9k Evry, 20 psi boost, Sprint 520)
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.14016 seconds with 9 queries
[Output: 135.97 Kb. compressed to 113.83 Kb. by saving 22.14 Kb. (16.28%)]
