Old September 1st, 2006, 08:14   #1
Kerri
Default How much further will an engine with 150K miles go?
I'm looking to buy a TDI (in the Austin area, if any one has one to sell). I've looked at several with over 100 thousand miles on them.
How many miles can I expect to get out of a TDI engine?
How about when running on bio?
What sort of mechnical issues should I start to expect with higer mileage?
Kerri is offline   Reply With Quote
Old September 1st, 2006, 08:24   #2
gardentender
RIP, Gone But Not Forgotten
Fuel Economy: 53+/46/41
depends on how well the engine was taken care of in the first 150K. regular oil changes with a good quality oil, regular timing belt changes, other maintenance, all documented? if so, you can count on another 150K or more. if not, your mileage may vary proportionally.
good maintenance ain't cheap, but expensive maintenance at a dealer is not always the best, either. spend some more time in here, noodle around and learn. don't expect to get a good car for cheap.
i lurked in here for several months before i bought my 2000 Jetta TDi, and it has over 211K miles on it now. never had a failure of anything in the drive train (engine, clutch, transmission) that affected reliablilty. i did have the plastic drain on the bottom of the fuel filter crack and prevent me from starting one morning. was fixed with a replacement filter in about 3 hours. this was around 30K miles or so, since then i've changed my own fuel filters in addition to oil, oil filters, engine and cabin air filters. Have used BioDiesel in varied mixtures for about 100K miles now without a problem. If used conservatively, I think BD keeps an engine running well considering the fuel's lubricating and detergent/cleansing nature.
little nicky nacky things might occur, such as broken glove box hinges, but how often do you use the glove box??
don't be in a hurry, do your research and you'll find a good car, maybe not in Austin, maybe further away.
. . . on the bus.
gardentender is offline   Reply With Quote
Old September 1st, 2006, 09:03   #3
Drivbiwire
Zehntes Jahr der Veteran
1,350,000 miles till VW thinks it will need an overhaul PROVIDED you follow the maintenance guidelines in the ownersmanual, no joke.
DB
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old September 1st, 2006, 10:03   #4
ScorpionBoy
DB
that is frickin' amazing. would that be just a top end overhaul or do you need to replace the crank too? what an awesome number.
2003 Jetta TDI, Auto
Coolant Migration Mod
Provent CCV Filter
Panzer Plate
Vented
ScorpionBoy is offline   Reply With Quote
Old September 1st, 2006, 10:51   #5
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
If you turn around now and head back, you should get back to the start with no problems and ready for another go around.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old September 1st, 2006, 11:45   #6
MikeS_18
MikeS_18's Avatar
I agree with the Gardentender. I lurked here for about 6 months and then started shopping. It took another 5 months to get my car which has 73,000 on it. Knew what I was doing and thus had no hesitation at all.
Read about timing belts, coolant migration, turbo failures, injection pumps. Those seem to be the big ticket items (more than $600 installed) but those that frequent the dealers get to spend hundreds/thousands on things that the people in the forum would drive an hour to your house to help you do yourself. Example - friend with a jetta gasser had the car at the dealer today for an oil change. "Maam, your emergency brake cable is sticking and needs to be replaced." $240 quoted. It's a $30 part and an hour or two under the car if you have no clue what you are doing. No thank you Mr Dealer.
So, read read read, and ask lots of questions and use the support of this forum to ensure that you get the value out of the car and it will go as long a you want it to. I know I will get bored of it before it dies.
'03 Wagon, 5spd,17/22 turbo, RC3+, PP520s, Stage 1 clutch, Old Man Intake, Lift Pump, TT Short Shifter, EGR Cooler Deleted, 800 Mile/tank club
2013 Passat SE and a '64 Ford Econoline Travel Wagon, 200ci straight six, 3 spd, 17mpgs "If it's got a hood, it ain't no good!"
6 Garages?! It's still not enough!
MikeS_18 is offline   Reply With Quote
Old September 1st, 2006, 12:31   #7
v_lombardi
v_lombardi's Avatar
Fuel Economy: 44-48 mpg
i got my car in dec 2005 with 133,000mis. it was well maintained and they provided all the records. the only thing i have done is oil changes, wiper blades and put in 4 new engine glow plugs last night.
vince
2001 golf m/t (second owner), 227,000 mis, 44-48 mpg.
v_lombardi is offline   Reply With Quote
Old September 1st, 2006, 12:55   #8
gardentender
vince
and you probably didn't even have to do that. most of the time glow plugs just get dirty and need cleaning. but, sometimes it is simpler and more reassuring to remove and replace.
. . . on the bus.
Old September 1st, 2006, 12:56   #9
TXBilll
Default A Better Car
If anyone is interested there is a 2002 or 2003 NB TDI with 45,000 miles for sale at Momentum VW of Jersey Village (NW Houston). I think they'll take about 15K for it, silver, loaded leather/sunroof 5 speed, etc.
TXBilll is offline   Reply With Quote
Old September 1st, 2006, 13:25   #10
TDIfor
Fuel Economy: TotalCar 70.5K mile avg: 49.5 MPG
DB
DBW - do you know on what that figure is based? The 10,000 hours of use has been tossed around, based on what.. the marine iteration of the engine? But I figure that would amount to 300,00 - 400,000 miles, assuming an average speed of 30 MPH (ranging from 5 MPH pulling out of the driveway to 65 MPH on the hiway).
Don
Dear aging NB
Exhaust pipe leaks and rattles
Like nebulizer.
TDIfor is offline   Reply With Quote
Old September 1st, 2006, 13:53   #11
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Cool
It's still way too early for me to tell as I'm "only" at 227k miles on my 2002 Golf TDI.
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Member SSBMWO
Why DIESEL is better:
http://webpages.charter.net/lmarz/emissions.html
http://webpages.charter.net/lmarz/efficiency.html
http://webpages.charter.net/lmarz/performance.html
http://webpages.charter.net/lmarz/emissions2014.html
http://webpages.charter.net/lmarz/emissions2016.html
n1das is offline   Reply With Quote
Old September 1st, 2006, 14:16   #12
ScorpionBoy
i didn't do a search to see if there is a thread, but anyone know who holds the high mileage record aroudn here?
Provent CCV Filter
Panzer Plate
Vented
Old September 1st, 2006, 14:28   #13
Drivbiwire
Don
The design life is actually 25,000 hours. Typical average speed of a road going vehicle is 45mph. city only vehicles fall around 40 mph.
My car is coming up on 5,000 hours of engine time (measured by Hobbs meter since new). I now have 220,000 miles and all cylinders were still pulling 550psi (new is 475 on an unbroken in crate motor) on all 4 at 200,000 miles.
I have repeat customers with over 400,000 miles still pulling 550 psi... I laugh when people say they expect 300,000 miles out of these cars.
DB
Old September 1st, 2006, 15:21   #14
hkbladelawhk
Fuel Economy: 32, last time I checked
DB
yea, world record was a 1988 Volvo P1800S with 2 MILLION miles + and its still going...no overhaul...
Check Guiness World Records
hkbladelawhk is offline   Reply With Quote
Old September 2nd, 2006, 10:36   #15
Kerri
Default No maintanence recods on 77K mi - how wary should I be?
All good info, thanks everyone.
I'm looking at a 2002 Jetta w/ 77K mi that is just about what I want - but it was a trade in and the dealership doesn't have the maintenance records. How wary of this should I be?
Page generated in 0.17367 seconds with 9 queries
[Output: 124.67 Kb. compressed to 103.23 Kb. by saving 21.44 Kb. (17.20%)]
