Old August 28th, 2006, 15:39   #1
tobsav
Default Jetta rear brakes
I need to do rotors and pads on the rear brakes of my 03 Jetta wagon.
What is the special tool needed?... and do I really need it?
thanks
T
2003 Jetta TDI GL Wagon
Almost as cool as my '91 Festiva...RIP
tobsav is offline   Reply With Quote
Old August 28th, 2006, 15:45   #2
Andrewh
There are a couple of choices for tools. The caliper "piston' needs to be turned as it is pressed in. The one I see listed has a spreader and rotate part built in.
With a little skill, you can use the cube turner from autozone or napa, and push as you turn to get the piston back in. They may also rent them there, but the cube was like 12 bucks. Works on multiple applications. Not sure how much the "correct" tool costs.
Also you should open the bleeder when you do this and let the old fluid out that way. You should not push old fluid back into the system if you can help it.
Andrewh is offline   Reply With Quote
Old August 28th, 2006, 15:47   #3
rjr311
Fuel Economy: 45 mpg
An easier way to state the fluid comment is:
If you are replacing pads, change the fluid as well.
You are already in the right positions for 50% of the work.
rjr311 is offline   Reply With Quote
Old August 28th, 2006, 17:32   #4
pruzink
Fuel Economy: 42
Default Just a few other quick things on doing the brakes
I just changed the pads front and rear on my daughter's Jetta this past weekend. I'm used to working on American cars and there are a few other things that you should be aware of. The bolts that you remove to get the rear calipers off are only about 1" long (The head is 13MM), you need to put a wrench on the slide bolt to stop them from turning as you remove these bolts (I think it was a 15mm wrench, or maybe 14). Normally, I clamp off the hose going to the rear caliper when I screw the piston back in, but I just could find a pliable rubber hose to do so so I just went with opening the bleeder valve as I screwed the piston back in. Being as that VW recomends flushing the brake fluid every 20K miles that is a good time to do so (they tell you to use DOT4 fluid, there have been previous posts where the newer synthetic Low Moisture Absorbance fluids are ok too, they say they meet & exceed DOT4). You definitely need a tool to screw the piston as it is compressed back into the cylinder.
If you do the front pads as you do the rear be aware of one thing. Only the front driver side inboard pad has the wear sensor. If you look at the other 3 pads they all look pretty much the same. They are not. The retaining clip for the inboard pad on the passenger side is just a tad bigger than the outboard pad retaining clips (as I found out the hard way). If you install that pad into one of the outer pad slots it will not fit quite right and you will not get the slide bolt holes lined up. There are plastic protector tubes around the front slide bolt heads, the plastic end to this tube pops off to allow access to the torx head slide bolts.
pruzink is offline   Reply With Quote
Old August 28th, 2006, 17:42   #5
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
The inside of the slides is a NARROW 15mm. Most normal box wrenches don't fit in there. Oh, and change the brake fluid FIRST. Never just leave the bleeder open, you risk too much air getting in the system.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old August 28th, 2006, 17:56   #6
TDI_NC
You can find rear break tool on tdiparts.com.
http://www.tdiparts.com/catalog/prod...roducts_id=402
TDI_NC is offline   Reply With Quote
Old August 28th, 2006, 18:02   #7
tobsav
thanks everyone for the info....
couldn't quite tell what the "tool" did, and wondered if I could do it with my usual vise-grips and coat hanger technology!
all your input greatly appreciated!
cheers
T
Old August 28th, 2006, 18:05   #8
jasonTDI
jasonTDI's Avatar
No, you can't but others here have tried. Sometimes it works but it usually destroys the boot or the piston. Much cheaper to get the tool than the $130 caliper.
Old August 28th, 2006, 18:11   #9
tobsav
I hear that!
Old August 28th, 2006, 22:13   #10
chromeBuddha
chromeBuddha's Avatar
Fuel Economy: 47 mpg @ 75 mph
check metalnerd.com for the VW specific tool or harborfreight.com and search "brake tool" for a generic that will work on various makes...
2002 Golf TDI, 5-speed, 2-door
White w/ Tan interior (get the Scotchguard!!!)
47 mpg @ 75 mph
"El Bonbon" - The Marshmallow
chromeBuddha is offline   Reply With Quote
Old August 28th, 2006, 22:27   #11
BleachedBora
BleachedBora's Avatar
If you haven't bought them yet, check out these:
http://cgi.ebay.com/ws/eBayISAPI.dll...MESE:IT&ih=019
I just forced the rears without the tool (using blocks of wood), but it's a bit more work.
Cheers,
-BB
BleachedBora is offline   Reply With Quote
Page generated in 0.15705 seconds with 9 queries
[Output: 98.22 Kb. compressed to 82.53 Kb. by saving 15.68 Kb. (15.97%)]
