Old August 21st, 2006, 17:33   #1
BigRigger
Fuel Economy: 40 to 42 @ 80-90mph
Default Rod Bearing Spun
Hello all, i took my 99.5 Tdi Jetta to NHIS this past weekend and tracked it, had a blast to say the least . Unfortunately i think i hurt the motor over the course of the day. It ran flawlessly all day at the track and on the way home, but when i left for work this AM the motor started making a rather distinct sound i do believe is a rod bearing . I pulled the dipstick and i think i see small metal fragments in the oil. Not exactly what i had in my mind that would happen when i went to NHIS to say the least.. Now the question is can i pull the crank and rods out from underneath or do i have to pull the whole entire motor, that would suck..
Secondly i work 60 hours a week and i really don't have the time to mess with this anyone interested in this repair?? I live in Dartmouth,MA. I was thinking maybe GeWilli might be interested, i also called Chris in Braintree,MA and he is way to busy to even look at it. Let me know what you all think. SAUL
BigRigger is offline   Reply With Quote
Old August 21st, 2006, 18:00   #2
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Hi. I can always look at it....no problem. May not be a rod either.....just may sound like one. I'll give you a call tomorrow.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old August 21st, 2006, 18:12   #3
bugablue
bugablue's Avatar
TDI(s): 98 beetle
Fuel Economy: 50 mpg metric. average
If I were you I would redo the entire engine right away. I know that isn't always in a budget. But, if there is a bearing gone, it will push metal fragments all the way down the line and start to wear all your main and con rod bearings, and might also get into the cam bearings.
Its your call though, I would just personally be worried about the life of the rest of my engine after this.
bugablue is offline   Reply With Quote
Old August 21st, 2006, 18:53   #4
whitedog
Pull the filter out and cut a section of the material. Put that in a vice so you are squeezing it like an accordian and squeeze, squeeze, and squeeze some more.
Wipe off the oil on the outside and loosen the vice to remove the piece. Now open it and look at the dirty side. This is a good way to see if there is metal in the oil.
Can pump my own gas.
Old August 21st, 2006, 19:11   #5
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Cool
This sounds like a job for Herm TDI.
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Member SSBMWO
Why DIESEL is better:
http://webpages.charter.net/lmarz/emissions.html
http://webpages.charter.net/lmarz/efficiency.html
http://webpages.charter.net/lmarz/performance.html
http://webpages.charter.net/lmarz/emissions2014.html
http://webpages.charter.net/lmarz/emissions2016.html
n1das is offline   Reply With Quote
Old August 21st, 2006, 19:15   #6
whitedog
If he suspects a spun rod, I suggest he doesn't drive it though. Pulling the filter and cutting/squeezing is easy enough though. It will be a bit dirty, but it all washes off eventually.
Page generated in 0.13359 seconds with 9 queries
[Output: 70.74 Kb. compressed to 61.53 Kb. by saving 9.21 Kb. (13.02%)]
