Old August 19th, 2006, 18:53   #1
redtdi966
Default 99 jetta AC compressor clutch pulley locked
99.5 jetta AC compressor clutch pulley locked up:
I replaced the serp belt because it failed, then noticed the AC outer pulley was locked up. I could turn the inner clutch assembly with the 14 mm nut with no problem. So do I need to replace compressor, or can he clutch assm. be repaired on car?
Bruce
bruce
2003 jetta wagon 4-cyl , 2012 jetta sedan auto gassers -- Done with diesels "cost of ownership"
redtdi966 is offline   Reply With Quote
Old August 22nd, 2006, 17:56   #2
Big Red
Default Compressor?
I have a compressor for sale if you need one. Did you say you could turn the center? If so the pulley must be binding somewhere. Maybe a broken clutch surface jamming inside. That still would just engage the clutch. Not sure . ..
2012 Passat TDI 6M - 64k miles - stock so far!
Big Red is offline   Reply With Quote
Old August 25th, 2006, 18:47   #3
redtdi966
too bad I just bought a A4 compressor on Vortex. It has not shipped yet so I don't know if it is for real or not.
My e-mail is
bsemanchik@yahoo.com
Please send details, it needs to fit a 2000 jetta
Bruce
bruce
Page generated in 0.16821 seconds with 9 queries
[Output: 52.69 Kb. compressed to 47.41 Kb. by saving 5.28 Kb. (10.03%)]
