TDIFest 2013 Registration is now open!
Old August 17th, 2006, 17:41   #1
Ray_G
Ray_G's Avatar
TDI(s): 97 B4V
Default A3 B4 A4 timing belt tool dimensions
If you can't read the dimensions off of these photos I have nice higher res photos in my gallery. Timing belt tools.
03 E320 Benz
97 B4V TDI 94 F250 Powerstroke 76 911s
Ultimate cup holder for B4's Dimensions for A3/B4 and A4 timing belt tools Injection pump head how-to
Ray_G is offline   Reply With Quote
Old August 17th, 2006, 17:54   #2
whitedog
TDI Scholar
Fuel Economy: 42 Jetta, 47 Beetle
Thanks. I was looking at a dusty tool the Snap-On Stealer had on his truck and was wondering if it would fit. According to this, it won't.
Also I have a pin for a VP44 pump that is basically the same thing and I was wondering if it would work, but according to this, the pim is too big at ~ .234 in. whereas I have been told by some that they use a 15/64 drill bit which is .234 inches...
So now I'm all confused on the pin. Obviously the Dusty tool I saw won't work but now I'm curious about the pump pin.
whitedog is online now   Reply With Quote
Old August 17th, 2006, 17:57   #3
Ray_G
Ray_G's Avatar
TDI(s): 97 B4V
Yeah, good catch on the pin. I suck with Canvas. I spent so much time trying to get the program to work that I made a typo that I did not catch. You are right, .236 on the pin diameter. I will get the photo corrected.
Ray
03 E320 Benz
Old August 17th, 2006, 17:59   #4
whitedog
TDI Scholar
Cool, next question, how deel is that measurement? Ithink the pin I have may have an issue there. I measured it yesterday, but I forgot what it was...
Really need to reload that photographic memory.
Old August 17th, 2006, 18:03   #5
Ray_G
Ray_G's Avatar
TDI(s): 97 B4V
Ok, fixed, sorry for the goof, nice catch. Not sure what you mean by deel? maybe how long the pins are? The pin depth is .150, they are not that long. Oh, something else to correct!
03 E320 Benz
Old August 17th, 2006, 18:07   #6
Ray_G
Ray_G's Avatar
TDI(s): 97 B4V
Fixed the pin length too. Anything else that I messed up on?? Yeah, I would think that a 15/64 drill bit would work fine at .234 for the A4 pump pin. Now, I if I could just get someone to post the measurements of the cam pulley tool.......
03 E320 Benz
Old August 17th, 2006, 20:18   #7
whitedog
TDI Scholar
OOOps. I meant how long is that .234 part of the pin? It shoulders up, so how long from the end to that shoulder.
And on the cam holding tool, it looks like an E, right. Lay that E so the three points are down on a table. What is the distance from the table to the center leg?
Old August 17th, 2006, 20:21   #8
Ray_G
Ray_G's Avatar
TDI(s): 97 B4V
The part of the pin that necks down is a piece of plastic slipped on the straigh steel rod. Skip it you don't need it. The center measurement I will get for you tomorrow.
03 E320 Benz
Old August 17th, 2006, 20:31   #9
whitedog
TDI Scholar
The thing is I have the correct diameter pin, but it has a metal shoulder partway up. It's actually offset to set the timing with the offset part, of a size that fits in a much larger hole in the gear.
Old August 18th, 2006, 05:21   #10
Ray_G
Ray_G's Avatar
TDI(s): 97 B4V
Updated the figure.
03 E320 Benz
Old November 9th, 2006, 22:34   #11
mtbr297
mtbr297's Avatar
Default Pump lock pin
[quote=Ray_G]
[/quote
I have found a snap on 3/8" drive 11mm chrome deep socket works very well as a pump lock pin for a3,b4 injection pumps.
Steve in Fort Worth, TX
TDI club trusted mechanic.
TechnicalDieselInnovations
mtbr297 is offline   Reply With Quote
Old January 18th, 2007, 06:05   #12
gawelnj
How wide are the pins on the tensioner wrench?
gawelnj is offline   Reply With Quote
Old January 18th, 2007, 15:58   #13
gawelnj
neeeeeevermind *sheepish grin
Old April 24th, 2009, 12:34   #14
billyboy
TDI(s): Golf
Default 2001 Golf TDI Timing Belt Change Tools
Are the Passat and Golf Cam lock plate and Fuel pump pin the same. Where can I get the tool to hold the Cam gear while removing the bolt?
billyboy is offline   Reply With Quote
Old April 24th, 2009, 15:16   #15
paramedick
paramedick's Avatar
Metalnerd.com
An all TDI Family!!
paramedick is online now   Reply With Quote
Page generated in 0.15714 seconds with 9 queries
[Output: 123.80 Kb. compressed to 102.22 Kb. by saving 21.58 Kb. (17.43%)]
