Fix_Until_Broke
Trips from Home to Work on a Sunday on the interstate. Set cruise at 50 indicated (~48 actual per VagCom) once on the interstate which is ~2 miles from home, very little wind on either trip ~70F and very humid. Engine started cold and it was raining on the way to work. The engine was mostly warm and it was not raining (dry roads) on the way home. I changed the max reported MPG from 100 to 200 on the trip home as I was spending a lot of time with it pegged out at 100 on the trip there which may also be a contributing factor to the return trip showing higher MPG
Screen Shots of VagScope
Overall MPG is 44.8 Miles/(0.3062 + 0.2478) gallons for 80.86 MPG with an average speed of 43.25 MPG.
I don’t know how accurate the VagScope thing is, but I checked on my normal commute to/from work before and it returned low 60’s which is what I typically get using the trip miles and fill up method so it’s not way off. I’m still amazed at how much the instant MPG can change with a small change in throttle position (20’s to 50’s) and a very small change in acceleration performance.
I know this does not have much statistical significance - would need a few tanks full to do that. Just a see what I could do on a slow easy drive and to check out the cool VagComScope MPG Tool.
It’s going to be a while before I get a good MPG tank again, this partial one should be good (60’s), have a road trip with the trailer and family next weekend and Labor day weekend. Hoping for mid 40’s with the trailer.
