Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old April 26th, 2015, 18:35   #226
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Originally Posted by 3turboz View Post
Sorry if this is a repost, but here is an great video showing how the DSG works.
http://www.modifiedcars.com/551722
Thanks for the video. They lost me a little in the middle but seeing the thing in "action" really helps.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old April 28th, 2015, 15:23   #227
fancy_dancer
TDI(s): 2009 JSW DSG
Default How long SHOULD a DSG last?
DATE: April 28, 2015
Year: 2009
Make: VW
Model: Jetta Sportwagen
Date of auto production: November, 2008
Engine code: CBEA
Transmission Code: 02E
Date of DSG Production: July 22, 2008
Purchased, New or Used: New
Miles when purchased: 18
Current miles: 167,000
Area of country: Central Ohio
Fuel Statistics: Lifetime average is 38.3 mpg
Well, folks, I now know how long a DSG will last. Or, at least, how long the DSG in my JSW DID last. After 6 1/2 years and 164,473 miles, in the middle of Nevada, I was cruising at 70 when the transmission unexpectedly shifted down (to 4th?), and the PRNDS light on the dashboard started flashing, I pulled over, let the engine cool off for a bit, and shut it off. After restarting, I drove maybe 100 feet when the flashing started again. Called AAA. Waited a long time (middle of Nevada, remember?). Took it to Las Vegas for diagnosis. Two hour drive from where we were.
The VW dealer worked his magic, and found three codes (all bad): P2789 ($4B15 / 19221 001) Clutch Adaptive Learning at limit, Upper limit exceeded; P2723 ($4AD3 / 19155 000) Pressure Control Solenoid "E" Performance or Stuck Off, tbd, and; P2711 ($4AC7 / 19143 004) Unexpected Mechanical Gear Disengagement, no signal/communication. Hmm.
Their recommendation was a new DSG, including the Mechatronics unit and clutches. One week and a pile of money later, I left in a car that drove just about the same as it did just before the failure, which was actually very good. I do really like the way that the DSG behaves.
But was this the necessary cure? Would just replacing the clutches have cured the problem, or maybe the Mechatronics unit and the clutches? I find it very upsetting that there seems to be no warning that this was coming, so that I could have had the clutches replaced when the system was, say, at 90% of the limit, rather that waiting for catastrophic failure. And then replace the mechatronics unit too, if need be. If this was primarily a clutch wear issue, is that data available the OBD2 port?
2009 TDI SportWagen DSG Arrived Nov 16, 2008
1998 Ducati 900SS arrived Mar 14, 2009
1995 Toyota Previa AWD - occasional driver
1940 Ford Convertible Sedan - project
1992 Acura Legend Sedan L 5-speed (2001-2009)
1984 Mercedes 300SD (1997-2001)
1984 Camry TurboDiesel (1984-1997)
1978 Rabbit Diesel (1977-1984)
1967 Mercedes 200 Diesel (1967-1977)
fancy_dancer is offline   Reply With Quote
Old April 29th, 2015, 06:01   #228
South Coast Guy
Fuel Economy: Good
If you ask around, you may find that automatic transmission failures are usually fixed by a new or remanufactured replacement rather than repair. I doubt if many dealers or independent shops have the know-how to rebuild an automatic transmission.
South Coast Guy is offline   Reply With Quote
Old April 29th, 2015, 06:10   #229
kjclow
In agreement with South coast Guy but adding that even fewer tranny shops will know what to do with a dsg. it is probably less time consuming for the shop to just replace it.
Old May 3rd, 2015, 05:13   #230
Rico567
Post #226 is the best video I've seen on how the DSG works (apart from the really detailed stuff for mechanics, etc.). Thanks, "kjclow."
[URL=http://www.fuelly.com/driver/rico567/passat]
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old May 3rd, 2015, 07:44   #231
kjclow
Your welcome but 3turboz actually posted it a few above mine.
Old May 24th, 2015, 15:47   #232
kalaskastdi
TDI(s): 2004 beetle
ATE: May 24, 2015
Year: 2004
Make: VW
Model: New Beetle TDI
Engine code: BEW
Transmission Code: 02E, per VWoA GYS, Per Autobahn Transmission Exchange 02E automatic transmission, code HQN or HXU.
Purchased, New or Used: used
Miles when purchased: 87777
Current miles: 97800
Area of country: Virginia
Fuel Statistics:
Replaced DMF May 2015 - It exploded and machined tranny bell housing. Also had mechatronic replaced May 2014.
kalaskastdi is offline   Reply With Quote
Old May 29th, 2015, 06:28   #233
redbarron55
I don't know how long one will last since my 2009 JSW only has 235,000 miles and is one of the only things tha has not yet given trouble.
There may be a little rattle from the DMF starting, however.
redbarron55 is offline   Reply With Quote
Old May 29th, 2015, 07:36   #234
scooperhsd
DATE: 5/29/2015
Year: 2015
Make: VW
Model: Golf SE
Date of auto production: - " usually month and year " unless you know the day
Engine code:CRUA
Transmission Code: - “located in owners manual next to engine code”
Date of DSG Production: - “ located on top of trans just below and beside the battery – is visible with flashlight”
Miles when purchased: 42
Current miles: - 5100
Area of country: - Central NC
Fuel Statistics: - " best/average/worst only please "
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old June 3rd, 2015, 21:44   #235
stevedar
Fuel Economy: 42 MPG (Mixed Driving)
Exclamation 2006 VW Jetta TDI - Mechatronic Bites The Dust
DATE SHE BLEW: 04/23/2015
Date of auto production: - 10/2005
Engine code: Could not find it? Sticker says Made in Poland.
Transmission Code: - ???? Sticker says Made in Germany.
Assembled in: Mexico
Date of DSG Production: - I can look if it really matters...
Purchased, New or Used: Used
Miles when purchased: 48,000
Current miles: - 107,000
Area of country: - Pacific NW, USA
Fuel Statistics: - usually gets just under 40 MPG, higher w/freeway miles
I've loved having this Jetta despite a decent amount of repair bills. The MPG was cool, the car felt "solid" like when you closed the doors they went "Thunk" instead of "Whump". The DSG transmission with it's cute little manual shift mode and the sunroof and the navigation system, just made it seem so "fun". It is in fact a fairly heavy & safe car with an excellent ride and all of that with almost 40 miles to the gallon and the longevity of a diesel engine, what's not to love?
Then I found out about the flashing MFD of Death or whatever that is? I had just come up a small hill (< 2 blocks, but steep grade) after exiting the freeway. The car revved high, but it wasn't hardly going. Pulled off, caught a ride home, read up on it, went back 2 hours later and was able to drive it 4+ miles home before flashing started again. Check engine light was on all the way.
I read the codes and it seemed like it was throwing PO761 (Shift Solenoid C Performance or Stuck Off) two separate times? At any rate, I knew I could not fix it myself and had it towed to an independent transmission shop (which turned out to be a horrible mistake!) and it ended up costing me $3,000 to get the mechatronic unit replaced. The car itself is only worth about $7K (if I'm lucky), but its more or less paid for so I thought I would fix it and keep it even though that's an absurd repair bill. The Mechatronic thingee all by itself costs $1,500.
So, it's back up and running, but another long standing problem is starting to bother me. I believe I've had some camshaft work done, but never any flywheel work and the dealership that finally finished fixing the car noted it has a "noisy flywheel". I know that diesels can be noisy, but this is not the same kind of rattle, it's more like someone's shaking a can full of bolts inside the engine, although it tends to become less pronounced once the engine comes up to temp. Although now I'm beginning to wonder if I'll next face an exploding dual mass flywheel? This is not even to mention the window controls on the driver's door that occasionally flame out and quit working. That's another one that I missed the recall on, but so far they are still working about 98% of the time.
I am not a big fan of working on cars, but I just now fixed a broken windshield washer line. I replaced the windshield washer pump thinking that was the problem, but finally my wife saw the hose was split right at the hood hinge where it goes to the sprayers. Then about a year or so ago one of the coolant hoses broke in the most obscure place and I spent an entire weekend under that thing trying to make it right.
I probably should just dump the old rattle trap and get a nice reliable Japanese automobile? Or just drive it 'til it dies since it probably isn't going to fetch much in a trade-in at this point?
stevedar is offline   Reply With Quote
Old June 6th, 2015, 09:56   #236
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
Thats my plan. LoL. Just hate to waste all the money ive invested in my mkv. Thanks for the laugh though.
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old December 25th, 2015, 19:06   #237
Reverend6252
Don't know how true this is but HPA Motorsports site it states that dealers aren't even allowed to do anything but eithe a fluid/filter change or r/r. This may refer to the newest as I have a '15 w 1800mi. I need to pull all the info for this page when she's broken in a little more and right or wrong I've already got Malone stage 1 & 2 and am waiting on HPA's DSG tune and flash tool (2nd week of Jan '16). All reports so far state the tune makes "the DSG the way it should have come from the factory".
http://www.hpamotorsports.com/dsgtuning.html
TDI Tune at bottom of page.
Reverend6252 is offline   Reply With Quote
Old October 29th, 2017, 07:28   #238
redznb1
TDI(s): golf
ATE: May 26, 2014
Year: 2006
Make: VW
Model: New golf TDI
Engine code: vef
Miles when purchased: 75000
Current miles: 87500
Area of country: colorado
Fuel Statistics:
volkswagen
redznb1 is offline   Reply With Quote
Old September 1st, 2018, 06:31   #239
TDI321
TDI321's Avatar
Fuel Economy: 50mpg@75mph, 68@50, 37@95
DATE: Sept 2018
Year: 2015
Make: Passat
Model: SEL Prem TDI
Engine code: CVCA
Date of DSG Production: - 2015
battery – is visible with the flashlight”
Purchased, USED
Miles when purchased: 12K
Current miles: - 13k
Area of country: - “ southeast USA, Florida "
Fuel Statistics: - " best57/average42/worst 33 "
TDI321 is offline   Reply With Quote
Old September 4th, 2018, 09:48   #240
kjclow
Had this thread pop up with TDI321s add. I had to replace the mechatronics unit in March/April. Took it in the fix and 120k service. Once they completed the fix, they noticed that it was leaking tranny fluid and said it was coming from the mechatronics unit. Took most of my $5200 fix money.
Page generated in 0.14588 seconds with 9 queries
[Output: 126.20 Kb. compressed to 105.51 Kb. by saving 20.69 Kb. (16.39%)]
