Old July 25th, 2006, 12:28   #1
VWRobb
VWRobb's Avatar
Default A/C Help on a 2000 Jetta...
I have been reading some post re. A/C problems others are having...however I have yet to find a similar problem...
The problem I'm experiencing with my 2000 Jetta TDI is when I am idling...I'm not getting cold air blowing...The fan is blowing…however it is not cold (or even cool)…
Once the car starts moving the air cools down...and stays cold...as long as I'm driving...(ok for the highway...not good in stop and go traffic).
Can anyone help me diagnose the problem and avoid a high repair cost...
Cheers!
VWRobb is offline   Reply With Quote
Old July 25th, 2006, 12:31   #2
dieseldorf
top post dawg
dieseldorf's Avatar
I would check to see if your electric fans are working.
Old July 25th, 2006, 13:29   #3
wakeboarder_shawn
wakeboarder_shawn's Avatar
yes i have the same problem and my a/c fan is not working, that is what i have been assuming was the cause. I haven't really looked into fixing it yet though
2009 Jetta TDI Highline| 18" RS4's
wakeboarder_shawn is offline   Reply With Quote
Old July 25th, 2006, 20:08   #4
VWRobb
VWRobb's Avatar
I started up the car and turned on the A/C...Checked under the hood...and the fans did not come on...
After I drove home from work...I checked the fans before I turned off the engine (and A/C)...and the fans were on...
Old July 26th, 2006, 21:12   #5
TurBoLover
was the radiator or aux fan working when you came back from work???
TurBoLover is offline   Reply With Quote
Old July 31st, 2006, 18:51   #6
ninedee_golf_tdi
Running your a/c without having the fans operating correctly is asking for the compressor to blow itself up. The fans reduce the head pressure which otherwise would get up to over 400+ psi. There is probably a pressure relief valve somewhere that will eventually pop, then it's time for more costly repairs. Get the fans fixed.
ninedee_golf_tdi is offline   Reply With Quote
Old August 2nd, 2006, 17:01   #7
Michael_Akamatsu
Michael_Akamatsu's Avatar
Do not run the a/c unless the condensor/radiator fan is working. The system will over pressurize, and you will loose your refrigerant charge. It happened to me once in my Corrado of yesteryear. I was doing some work under the hood and forgot to plug the fan connector back in.
Michael_Akamatsu is offline   Reply With Quote
Old August 7th, 2006, 05:40   #8
VWRobb
VWRobb's Avatar
Default A/C help in Ontario
OK...I need to have the fan repaired or replaced...
I don't have the skills to fix this problem myself...so does anyone know a good and "reasonably priced" place to have this repair done in the GTA...Niagara Region...or the South Simcoe Region (I travel to these area of Ontario frequently).
Also...what fan or parts do I tell them I need repaired/replaced?
Old August 7th, 2006, 22:13   #9
jhedrich
Default self repair
Listen, if you can spell fan...then you can replace your auxilliary fan. Just order the aux fan from 1stvwparts.com and look how it is bolted to plastic shroud. It comes as a big unit, ready to go.
PS...this must be the programmed limit life of the 99.5 series A/C. Mine is rumbling like crazy...fan is fine, but the hotter it gets, the more it rumbles. Anybody know why?
jhedrich is offline   Reply With Quote
Old August 10th, 2006, 18:36   #10
VWRobb
VWRobb's Avatar
Thanks for the info!!
Does anyone have the VW Part # for the Auxillary Fan?...This will help me with my search...
Old August 10th, 2006, 19:16   #11
Fortuna Wolf
Fuel Economy: 36 mix
Which fans are supposed to come on when? The fan on the driver's side of my car doesn't ever seem to come on, though the passenger's side fan is always spinning away. This is when A/C on any time I look under the hood with the engine running.
2002 Jetta Sedan ALH-01M: 2 um Cat FF, Wingnut-3 CCV filter, polyurethane fuel lines, 5 brake light mod, Ventectomy, Polysiloxane vacuum tubing, Pioneer DEH-3800MP w/ KFC-1389ie, Panzer Plate, EGT+Boost+Oil Temp Gauges, Boost Valve, KERMA Line Pressure Mod, LED Lighting, HC-12a refrigerant, Optima 75/35 AGM, .187 nozzles, Hawk HPS pads.
Coming Soon: ESP retrofit, Custom Greasecar.
Wish List: Tow Bar, DSG or CVT transmission, or even a 5 speed manual. To hit 42+ mpg
Fortuna Wolf is offline   Reply With Quote
Page generated in 0.13395 seconds with 9 queries
[Output: 96.47 Kb. compressed to 80.70 Kb. by saving 15.77 Kb. (16.35%)]
