Old July 16th, 2006, 09:31   #1
VDubbing
VDubbing's Avatar
Default slow fuel pump
I was filling up the other day at a now bio place as I miscalculated a side trip and wasnt able to get to where i normally get my bio 100. Anyway the pump is pumping at probably a quarter the speed a fuel pump would normally pump at. I mention this to the attendant and he says its cause the tank is almost empty. Does anyone know if this is true or if this guy is giving me the gears? Ive never experienced this before.
Rob
2003 Jetta TDI Galactic Blue
235,000 K PP764 injectors, RC stage 3 VR6 clutch kit. Aluminum skid plate, GTI fogs .658 gear
VDubbing is offline   Reply With Quote
Old July 16th, 2006, 12:52   #2
wny_pat
Fuel Economy: 48 mpg
Rob
Could be any number of problems from what he told you to vapor lock to plugged filter, along with some others.
'02 Jetta TDI GLS. Bosio Sprint 520. Hella E-Codes. HiddenHitch and rear suspension air bags. Evolution Skid Plate.
wny_pat is offline   Reply With Quote
Old July 16th, 2006, 15:17   #3
VDubbing
VDubbing's Avatar
Old July 17th, 2006, 19:12   #4
Old Navy
Old Navy's Avatar
Fuel Economy: 28 mpg on PU, 33 on Car
That is a common when a tank gets low and stars sucking the stuff up from the bottom of the tank. What causes it is the height of the lift to the pump, same happens in a water well or oil well. Oh and it means you will be getting all the trash from the bottom of the tank if it gets low enough.
2013 Chrysler 200 Touring Cherry Red Metallic 32 mpg. Grannies ride
2014 Dodge 1500 V6 Turbo Diesel Crew Cab Cherry Red Metallic 28 mpg plus. Grandpa's ride.
Old Navy is offline   Reply With Quote
Page generated in 0.13920 seconds with 9 queries
[Output: 60.43 Kb. compressed to 53.61 Kb. by saving 6.83 Kb. (11.30%)]
